Has anyone managed to connect any GL.iNet router model to a DFS wifi?
Currently I have a GL-AR750 and have not managed to connect to a DFS wifi which I am trying to repeat.
So at the moment I’m using an old mobile to connect to the DFS wifi and USB tethering into the GL-AR750 but I’m thinking about getting a new router maybe another brand… or if there are any other GL.iNet router models which can connect to DFS wifi I would consider it?
At the moment I think it is not possible for the GL-AR750 to connect to DFS wifi but if anyone has managed to with ssh uci etc I may take another couple of hours trying to!
Hi Alzhao thank you for your care about this matter.
I have seen these posts and the guide you made and tried the following:
root@GL-AR750:~# uci set wireless.radio0.doth=‘1’
root@GL-AR750:~# uci set wireless.radio0.country=‘US’
root@GL-AR750:~# uci set wireless.radio0.channel=‘104’
root@GL-AR750:~# uci commit wireless
root@GL-AR750:~# wifi
root@GL-AR750:~# logread | grep DFS
Wed Oct 9 12:04:19 2019 daemon.notice hostapd: wlan0: interface state HT_SCAN->DFS
Wed Oct 9 12:04:19 2019 daemon.notice hostapd: wlan0: DFS-CAC-START freq=5520 chan=104 sec_chan=-1, width=1, seg0=106, seg1=0, cac_time=60s
Wed Oct 9 12:05:23 2019 daemon.notice hostapd: wlan0: DFS-CAC-COMPLETED success=1 freq=5520 ht_enabled=0 chan_offset=0 chan_width=3 cf1=5530 cf2=0
Wed Oct 9 12:05:23 2019 daemon.notice hostapd: wlan0: interface state DFS->ENABLED
… So far so good.
But then when it gets to trying to connect, firstly the scan does not complete it only finds some of the wifis. I have to do the scan so to follow the guide and get to the “other” and enter in the DFS wifi I want to connect to. When I go to other and enter in the ssid and try to connect it times out. This is the logread of when I have tried to do this 2 times at 12:12 and then a 2nd time a few minutes later. Can you see why this does not work? Many thanks
Wed Oct 9 12:12:08 2019 user.err : [ 265] Scanning not possible
Wed Oct 9 12:12:26 2019 user.info : [ 617] gl-sdk>> bIsSaved=0, ssid=_Link Free, encryption=none, bssid=, wds=0, device=radio0, identity=, channel=
Wed Oct 9 12:12:26 2019 user.info : [ 1424] gl-wifi-core>> FirewallConfiged
Wed Oct 9 12:12:28 2019 user.info : [ 2040] gl-wifi-core>> bIsStaEnabled=1
Wed Oct 9 12:12:28 2019 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Wed Oct 9 12:12:28 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Wed Oct 9 12:12:28 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Wed Oct 9 12:12:28 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Wed Oct 9 12:12:28 2019 kern.info kernel: [ 715.318827] device wlan0 left promiscuous mode
Wed Oct 9 12:12:28 2019 kern.info kernel: [ 715.323577] br-lan: port 3(wlan0) entered disabled state
Wed Oct 9 12:12:28 2019 daemon.notice netifd: Network device ‘wlan0’ link is down
Wed Oct 9 12:12:30 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Wed Oct 9 12:12:31 2019 kern.info kernel: [ 717.775090] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Oct 9 12:12:31 2019 kern.info kernel: [ 717.795963] br-lan: port 3(wlan0) entered blocking state
Wed Oct 9 12:12:31 2019 kern.info kernel: [ 717.801493] br-lan: port 3(wlan0) entered disabled state
Wed Oct 9 12:12:31 2019 kern.info kernel: [ 717.807440] device wlan0 entered promiscuous mode
Wed Oct 9 12:12:31 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Oct 9 12:12:31 2019 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Wed Oct 9 12:12:31 2019 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->ACS
Wed Oct 9 12:12:31 2019 daemon.notice hostapd: wlan0: ACS-STARTED
Wed Oct 9 12:12:50 2019 daemon.notice hostapd: wlan0: ACS-COMPLETED freq=5660 channel=132
Wed Oct 9 12:12:50 2019 daemon.notice hostapd: wlan0: interface state ACS->HT_SCAN
Wed Oct 9 12:12:50 2019 daemon.notice hostapd: wlan0: interface state HT_SCAN->DFS
Wed Oct 9 12:12:50 2019 daemon.notice hostapd: wlan0: DFS-CAC-START freq=5660 chan=132 sec_chan=1, width=1, seg0=138, seg1=0, cac_time=60s
Wed Oct 9 12:13:00 2019 user.info : [ 1370] gl-wifi-core>> Restart wifi…
Wed Oct 9 12:13:00 2019 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Wed Oct 9 12:13:00 2019 daemon.notice hostapd: wlan1: AP-DISABLED
Wed Oct 9 12:13:00 2019 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Wed Oct 9 12:13:00 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Wed Oct 9 12:13:00 2019 kern.info kernel: [ 746.765083] device wlan1 left promiscuous mode
Wed Oct 9 12:13:00 2019 kern.info kernel: [ 746.769793] br-lan: port 2(wlan1) entered disabled state
Wed Oct 9 12:13:00 2019 daemon.notice netifd: Network device ‘wlan1’ link is down
Wed Oct 9 12:13:01 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 747.489371] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 747.550274] br-lan: port 2(wlan1) entered blocking state
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 747.555835] br-lan: port 2(wlan1) entered disabled state
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 747.561886] device wlan1 entered promiscuous mode
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 747.566902] br-lan: port 2(wlan1) entered blocking state
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 747.572415] br-lan: port 2(wlan1) entered forwarding state
Wed Oct 9 12:13:01 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e4:95:6e:43:42:44 and ssid “GL-AR750-244”
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 747.784650] br-lan: port 2(wlan1) entered disabled state
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 748.119661] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 748.126462] br-lan: port 2(wlan1) entered blocking state
Wed Oct 9 12:13:01 2019 kern.info kernel: [ 748.131955] br-lan: port 2(wlan1) entered forwarding state
Wed Oct 9 12:13:01 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Wed Oct 9 12:13:01 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Wed Oct 9 12:13:01 2019 daemon.notice netifd: Network device ‘wlan1’ link is up
Wed Oct 9 12:13:10 2019 daemon.notice hostapd: wlan0: DFS-CAC-COMPLETED success=0 freq=5660 ht_enabled=0 chan_offset=0 chan_width=3 cf1=5690 cf2=0
Wed Oct 9 12:13:10 2019 daemon.notice hostapd: wlan0: INTERFACE-DISABLED
Wed Oct 9 12:13:10 2019 kern.info kernel: [ 756.906797] br-lan: port 3(wlan0) entered disabled state
Wed Oct 9 12:13:10 2019 kern.info kernel: [ 756.949737] device wlan0 left promiscuous mode
Wed Oct 9 12:13:10 2019 kern.info kernel: [ 756.954402] br-lan: port 3(wlan0) entered disabled state
Wed Oct 9 12:13:11 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Wed Oct 9 12:13:13 2019 daemon.notice hostapd: wlan0: INTERFACE-ENABLED
Wed Oct 9 12:13:13 2019 kern.info kernel: [ 759.428818] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Oct 9 12:13:13 2019 daemon.notice hostapd: wlan0: INTERFACE-DISABLED
Wed Oct 9 12:13:13 2019 daemon.err hostapd: nl80211: Could not configure driver mode
Wed Oct 9 12:13:13 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Wed Oct 9 12:13:13 2019 daemon.err hostapd: nl80211 driver initialization failed.
Wed Oct 9 12:13:13 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->DISABLED
Wed Oct 9 12:13:13 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Wed Oct 9 12:13:13 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Wed Oct 9 12:13:13 2019 daemon.err hostapd: hostapd_free_hapd_data: Interface wlan0 wasn’t started
Wed Oct 9 12:13:13 2019 daemon.notice netifd: radio0 (15760): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 8016 path ()
Wed Oct 9 12:13:13 2019 daemon.notice netifd: radio0 (15760): Device setup failed: HOSTAPD_START_FAILED
Wed Oct 9 12:13:24 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Wed Oct 9 12:13:25 2019 kern.info kernel: [ 772.107217] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Oct 9 12:13:25 2019 daemon.notice hostapd: wlan0: INTERFACE-ENABLED
Wed Oct 9 12:13:25 2019 daemon.notice hostapd: wlan0: INTERFACE-DISABLED
Wed Oct 9 12:13:25 2019 daemon.err hostapd: nl80211: Could not configure driver mode
Wed Oct 9 12:13:25 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Wed Oct 9 12:13:25 2019 daemon.err hostapd: nl80211 driver initialization failed.
Wed Oct 9 12:13:25 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->DISABLED
Wed Oct 9 12:13:25 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Wed Oct 9 12:13:25 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Wed Oct 9 12:13:25 2019 daemon.err hostapd: hostapd_free_hapd_data: Interface wlan0 wasn’t started
Wed Oct 9 12:13:25 2019 daemon.notice netifd: radio0 (16095): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 8016 path ()
Wed Oct 9 12:13:25 2019 daemon.notice netifd: radio0 (16095): Device setup failed: HOSTAPD_START_FAILED
Wed Oct 9 12:13:31 2019 user.info : [ 623] gl-sdk>> wifi_join return=-5, channel=-1
Wed Oct 9 12:13:31 2019 user.info : [ 1370] gl-wifi-core>> Restart wifi…
Wed Oct 9 12:13:32 2019 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Wed Oct 9 12:13:32 2019 daemon.notice hostapd: wlan1: AP-DISABLED
Wed Oct 9 12:13:32 2019 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Wed Oct 9 12:13:32 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Wed Oct 9 12:13:32 2019 kern.info kernel: [ 778.821580] device wlan1 left promiscuous mode
Wed Oct 9 12:13:32 2019 kern.info kernel: [ 778.826392] br-lan: port 2(wlan1) entered disabled state
Wed Oct 9 12:13:32 2019 daemon.notice netifd: Network device ‘wlan1’ link is down
Wed Oct 9 12:13:34 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Wed Oct 9 12:13:35 2019 kern.info kernel: [ 782.004384] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Oct 9 12:13:35 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Wed Oct 9 12:13:35 2019 daemon.notice hostapd: wlan0: INTERFACE-ENABLED
Wed Oct 9 12:13:35 2019 daemon.notice hostapd: wlan0: INTERFACE-DISABLED
Wed Oct 9 12:13:35 2019 daemon.err hostapd: nl80211: Could not configure driver mode
Wed Oct 9 12:13:35 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Wed Oct 9 12:13:35 2019 daemon.err hostapd: nl80211 driver initialization failed.
Wed Oct 9 12:13:35 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->DISABLED
Wed Oct 9 12:13:35 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Wed Oct 9 12:13:35 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Wed Oct 9 12:13:35 2019 daemon.err hostapd: hostapd_free_hapd_data: Interface wlan0 wasn’t started
Wed Oct 9 12:13:35 2019 kern.info kernel: [ 782.218657] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Oct 9 12:13:35 2019 daemon.notice netifd: radio0 (16397): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 8016 path ()
Wed Oct 9 12:13:35 2019 kern.info kernel: [ 782.277609] br-lan: port 2(wlan1) entered blocking state
Wed Oct 9 12:13:35 2019 kern.info kernel: [ 782.283110] br-lan: port 2(wlan1) entered disabled state
Wed Oct 9 12:13:35 2019 kern.info kernel: [ 782.289135] device wlan1 entered promiscuous mode
Wed Oct 9 12:13:35 2019 kern.info kernel: [ 782.294078] br-lan: port 2(wlan1) entered blocking state
Wed Oct 9 12:13:35 2019 kern.info kernel: [ 782.299615] br-lan: port 2(wlan1) entered forwarding state
Wed Oct 9 12:13:35 2019 daemon.notice netifd: radio0 (16397): Device setup failed: HOSTAPD_START_FAILED
Wed Oct 9 12:13:35 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e4:95:6e:43:42:44 and ssid “GL-AR750-244”
Wed Oct 9 12:13:36 2019 kern.info kernel: [ 782.796499] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Oct 9 12:13:36 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Wed Oct 9 12:13:36 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Wed Oct 9 12:13:36 2019 daemon.notice netifd: Network device ‘wlan1’ link is up
Wed Oct 9 12:13:42 2019 daemon.err rmmod: module is not loaded
Wed Oct 9 12:13:46 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Wed Oct 9 12:13:48 2019 kern.info kernel: [ 794.963888] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Oct 9 12:13:48 2019 daemon.notice hostapd: wlan0: INTERFACE-ENABLED
Wed Oct 9 12:13:48 2019 daemon.notice hostapd: wlan0: INTERFACE-DISABLED
Wed Oct 9 12:13:48 2019 daemon.err hostapd: nl80211: Could not configure driver mode
Wed Oct 9 12:13:48 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Wed Oct 9 12:13:48 2019 daemon.err hostapd: nl80211 driver initialization failed.
Wed Oct 9 12:13:48 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->DISABLED
Wed Oct 9 12:13:48 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Wed Oct 9 12:13:48 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Wed Oct 9 12:13:48 2019 daemon.err hostapd: hostapd_free_hapd_data: Interface wlan0 wasn’t started
Wed Oct 9 12:13:48 2019 daemon.notice netifd: radio0 (16822): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 8016 path ()
Wed Oct 9 12:13:48 2019 daemon.notice netifd: radio0 (16822): Device setup failed: HOSTAPD_START_FAILED
Wed Oct 9 12:14:32 2019 user.info : gl_health start->
Wed Oct 9 12:15:08 2019 daemon.notice hostapd: wlan0: INTERFACE-ENABLED
Wed Oct 9 12:15:08 2019 kern.info kernel: [ 874.865211] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Oct 9 12:15:33 2019 user.info : [ 617] gl-sdk>> bIsSaved=0, ssid=_Link Free, encryption=none, bssid=, wds=0, device=radio0, identity=, channel=
Wed Oct 9 12:15:33 2019 user.info : [ 2040] gl-wifi-core>> bIsStaEnabled=1
Wed Oct 9 12:16:03 2019 user.info : [ 1370] gl-wifi-core>> Restart wifi…
Wed Oct 9 12:16:04 2019 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Wed Oct 9 12:16:04 2019 daemon.notice hostapd: wlan1: AP-DISABLED
Wed Oct 9 12:16:04 2019 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Wed Oct 9 12:16:04 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Wed Oct 9 12:16:04 2019 kern.info kernel: [ 930.725248] device wlan1 left promiscuous mode
Wed Oct 9 12:16:04 2019 kern.info kernel: [ 930.729963] br-lan: port 2(wlan1) entered disabled state
Wed Oct 9 12:16:04 2019 daemon.notice netifd: Network device ‘wlan1’ link is down
Wed Oct 9 12:16:04 2019 daemon.notice hostapd: wlan0: INTERFACE-DISABLED
Wed Oct 9 12:16:06 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Wed Oct 9 12:16:06 2019 kern.info kernel: [ 932.613912] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Oct 9 12:16:06 2019 kern.info kernel: [ 932.672428] br-lan: port 2(wlan1) entered blocking state
Wed Oct 9 12:16:06 2019 kern.info kernel: [ 932.677998] br-lan: port 2(wlan1) entered disabled state
Wed Oct 9 12:16:06 2019 kern.info kernel: [ 932.684028] device wlan1 entered promiscuous mode
Wed Oct 9 12:16:06 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e4:95:6e:43:42:44 and ssid “GL-AR750-244”
Wed Oct 9 12:16:06 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Wed Oct 9 12:16:08 2019 kern.info kernel: [ 934.596546] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Oct 9 12:16:08 2019 daemon.notice hostapd: wlan0: INTERFACE-ENABLED
Wed Oct 9 12:16:08 2019 daemon.notice hostapd: wlan0: INTERFACE-DISABLED
Wed Oct 9 12:16:08 2019 kern.info kernel: [ 934.754121] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Oct 9 12:16:08 2019 kern.info kernel: [ 934.760924] br-lan: port 2(wlan1) entered blocking state
Wed Oct 9 12:16:08 2019 kern.info kernel: [ 934.766458] br-lan: port 2(wlan1) entered forwarding state
Wed Oct 9 12:16:08 2019 daemon.err hostapd: nl80211: Could not configure driver mode
Wed Oct 9 12:16:08 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Wed Oct 9 12:16:08 2019 daemon.err hostapd: nl80211 driver initialization failed.
Wed Oct 9 12:16:08 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->DISABLED
Wed Oct 9 12:16:08 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Wed Oct 9 12:16:08 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Wed Oct 9 12:16:08 2019 daemon.err hostapd: hostapd_free_hapd_data: Interface wlan0 wasn’t started
Wed Oct 9 12:16:08 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Wed Oct 9 12:16:08 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Wed Oct 9 12:16:08 2019 daemon.notice netifd: radio0 (18359): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 8016 path ()
Wed Oct 9 12:16:08 2019 daemon.notice netifd: radio0 (18359): Device setup failed: HOSTAPD_START_FAILED
Wed Oct 9 12:16:08 2019 daemon.notice netifd: Network device ‘wlan1’ link is up
Wed Oct 9 12:16:19 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Wed Oct 9 12:16:20 2019 daemon.notice hostapd: wlan0: INTERFACE-ENABLED
Wed Oct 9 12:16:20 2019 kern.info kernel: [ 947.341556] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Oct 9 12:16:21 2019 daemon.notice hostapd: wlan0: INTERFACE-DISABLED
Wed Oct 9 12:16:21 2019 daemon.err hostapd: nl80211: Could not configure driver mode
Wed Oct 9 12:16:21 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Wed Oct 9 12:16:21 2019 daemon.err hostapd: nl80211 driver initialization failed.
Wed Oct 9 12:16:21 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->DISABLED
Wed Oct 9 12:16:21 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Wed Oct 9 12:16:21 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Wed Oct 9 12:16:21 2019 daemon.err hostapd: hostapd_free_hapd_data: Interface wlan0 wasn’t started
Wed Oct 9 12:16:21 2019 daemon.notice netifd: radio0 (18782): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 8016 path ()
Wed Oct 9 12:16:21 2019 daemon.notice netifd: radio0 (18782): Device setup failed: HOSTAPD_START_FAILED
Wed Oct 9 12:16:36 2019 user.info : [ 623] gl-sdk>> wifi_join return=-5, channel=-1
Wed Oct 9 12:16:36 2019 user.info : [ 1370] gl-wifi-core>> Restart wifi…
Wed Oct 9 12:16:36 2019 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Wed Oct 9 12:16:36 2019 daemon.notice hostapd: wlan1: AP-DISABLED
Wed Oct 9 12:16:36 2019 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Wed Oct 9 12:16:36 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Wed Oct 9 12:16:36 2019 kern.info kernel: [ 963.147439] device wlan1 left promiscuous mode
Wed Oct 9 12:16:36 2019 kern.info kernel: [ 963.152351] br-lan: port 2(wlan1) entered disabled state
Wed Oct 9 12:16:36 2019 daemon.notice netifd: Network device ‘wlan1’ link is down
Wed Oct 9 12:16:38 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Wed Oct 9 12:16:40 2019 kern.info kernel: [ 966.383564] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Oct 9 12:16:40 2019 daemon.notice hostapd: wlan0: INTERFACE-ENABLED
Wed Oct 9 12:16:40 2019 daemon.notice hostapd: wlan0: INTERFACE-DISABLED
Wed Oct 9 12:16:40 2019 daemon.err hostapd: nl80211: Could not configure driver mode
Wed Oct 9 12:16:40 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Wed Oct 9 12:16:40 2019 daemon.err hostapd: nl80211 driver initialization failed.
Wed Oct 9 12:16:40 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->DISABLED
Wed Oct 9 12:16:40 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Wed Oct 9 12:16:40 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Wed Oct 9 12:16:40 2019 daemon.err hostapd: hostapd_free_hapd_data: Interface wlan0 wasn’t started
Wed Oct 9 12:16:40 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Wed Oct 9 12:16:40 2019 kern.info kernel: [ 966.628062] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Oct 9 12:16:40 2019 daemon.notice netifd: radio0 (19141): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 8016 path ()
Wed Oct 9 12:16:40 2019 kern.info kernel: [ 966.734050] br-lan: port 2(wlan1) entered blocking state
Wed Oct 9 12:16:40 2019 kern.info kernel: [ 966.739605] br-lan: port 2(wlan1) entered disabled state
Wed Oct 9 12:16:40 2019 kern.info kernel: [ 966.745490] device wlan1 entered promiscuous mode
Wed Oct 9 12:16:40 2019 kern.info kernel: [ 966.750433] br-lan: port 2(wlan1) entered blocking state
Wed Oct 9 12:16:40 2019 kern.info kernel: [ 966.755965] br-lan: port 2(wlan1) entered forwarding state
Wed Oct 9 12:16:40 2019 daemon.notice netifd: radio0 (19141): Device setup failed: HOSTAPD_START_FAILED
Wed Oct 9 12:16:40 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e4:95:6e:43:42:44 and ssid “GL-AR750-244”
Wed Oct 9 12:16:41 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Wed Oct 9 12:16:41 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Wed Oct 9 12:16:41 2019 kern.info kernel: [ 967.512282] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Oct 9 12:16:41 2019 daemon.notice netifd: Network device ‘wlan1’ link is up
So it is possible for the GL-AR750 to connect to DFS wifi. I think the problem was low signal strength. Since moving it to a better position it works. Thank you for encouraging me to continue trying.
