[Feature Request] Ability to Create a New WLAN for VPN
I would love to see an option in the GL.iNet firmware that allows users to create a separate WLAN specifically for VPN use. This would be extremely helpful for those who need distinct networks with different VPN configurations.
Currently, the only way to achieve this is by manually configuring OpenWRT, which means losing the user-friendly features that GL.iNet provides. Adding this functionality natively to the firmware would make it easier for users to manage multiple networks with varying VPN needs.
Is this something that could be considered in future updates?
Probably this one?
I think it will be grat feature. I have same roblem, I am new in this, and thats very difficult :slight_smile:
Hi, When my below request gets implemented (in 4.8 firmware I'm told) I think that will cover what you want and you'll be able to set it up in seconds with easy GUI mouse clicks:
For example in the below mock up image I did for my Flint which is more involved than you asked about but maybe a more realistic example of what many people are after:
LAN 1, LAN 2 and Guest Wifi = Use VPN connection 1 (eg a Surfshark connection to Seattle)
LAN 3 = Use VPN connection 2 (eg an ExpressVPN connection to Miami)
LAN 4 and (non Guest) Wifi are not assigned to a VPN connection so would get direct local internet access without using VPN:
Basically can very easily assign any physical network port (or built in gl.inet wifi SSID) to any VPN connection and run multiple OpenVPN connections at the same time, what you wanted would be even simpler than this easy example.
I'm really excited for when this arrives but sadly it's not available yet, no 4.8 test build for my Flint v1 (only Beryl AX), I'm hoping they prioritise a 4.8 build for Flint (version 1) ASAP since such features need to be tested with a device that has multiple network ports, Beryl AX has 2 so can't give any useful testing feedback for gl.inet...
cc: @uegia
Strangely, no GL-iNet staff commented on this great feature request.
When you enable Guest WiFi and disable the option "Guest" in VPN Policy "Based on the VLAN", Guest WiFi will not use VPN, and the Private (LAN) WiFi will use VPN.
v4.7 and before:
v4.8 and later:
Currently in Luci or uci commands, new WiFi radio can be created manually.
More WiFi SSIDs is expected to be implemented on the v4.9 firmware.
