I agree you.
It doesn’t need to expose in UI, as it only support OPEN/WPAPSK/WPA2PSK/WPAPSKWPA2PSK on ui, but I think it should be configured to WPA2 PSK by default which is the most security at present.
I agree you.
We will develop it in the future.
Thanks for the suggestion.
Good idea! We will evaluate this feature.
Customers don’t need to configure it.
Providing secured time source like:
What’s the use-case for requiring secured time? Do you find NTP Stratum 1/2 servers giving out false time info?
I don’t really see the point of the TLS based ones. They all add some latency so the time won’t be exact after a sync, worse than a “non secure” way.
The hardware solutions are also even worse, they are totally not secure at all.
I can sit by your window and spoof GPS and DCF77 just with a micro controller, maybe even another GL router ![]()
There are more important features required at the moment, like captive portal detection so that you don’t need to disable the VPN and leak data while you accept the captive portal TOS.
The normal NTP by UDP can easy used to set a wrong time (pe. the right time +2year). The result of this are, the most certificates will be invalide. Certificate based things wil stopp working.
Secured time source will fix this. I am not a programmer, I dont no how complicated to implement like this. In the past i have seen how to how to install the existing tlsdate on openwrt. One other how too was describing how to get time by GPS mouse on openwrt.
The uncerternly of NTP is perfect for the most thinks. The problem of 40 years old NTP protocol is, its easy to replace the time by a man in the middle.
I’d like to see some sort of page where i can see a list of broadcasting APs near the router, their signal strengths, 2.4 or 5g, and possibly what kind of encryption is used… a site survey by the firmware… not just the dropdown showing the connection possibilities…
It is already possible to export the router configuration from Luci, so this feature won’t be added.
GL will only add features that don’t already exist in Luci.
What is Luci ? Where to find export of router config ? Its on advanced admin menue ?
Feature request:
Yes Luci is the “advanced admin menu” ![]()
Can you sort the VPN profiles alphabetically like it used to? I have 141 OpenVPN profiles - its just a jumble now - no apparent order.
I have PrivateInternetAccess sorted into
IP - Germany
TCP - Germany
UDP - Germany
for all locations.
I would like the ability to drop a single OVPN file instead of a compressed folder.
Thats works works since V 3.003.921 on GL-AR750 white
Yup this has worked since forever ![]()
DNS wishes:
st and 2nd DNS over TLS serverOther wishes:
Johnex, pls set on top of thisFeatures Request thread a link to:
THX
