Firmware 3.201_beta3
Software library has been fixed.
MT300N-v2 uses MTK private driver and does not support WPA3 yet.
Some end device don’t fully support WPA3 yet, so WPA3 is only an option that you can set yourself
Hi, thanks for answering so fast.
I knew MT300N-v2 uses a mtk blob as driver, what I mean is whether they are currently providing updates to the blob or they are concentrated in newer systems (wifi 5 & wifi 6) leaving the current blob as it is. Is there any real expectation of wpa3 support in 1y-2y?
Thanks
Installed with no glitch on E750. Luci working 100% fine
Just noticed that the cellular strength signal bar bug is still there (full bars always displayed on LCD although less bars in web interface)
Has been fixed in the Beta4.
Thanks for reminding.
All looking good here, except the VPN shield behavior for OpenVPN client is stuck on the “!”
IGMP and DLNA are not for the MT1300? Of no consequence to me but curious.
Does this beta address the issue mentioned here on Slate? As it wasn’t fixed in the beta2…
Also, where can I get the *.tar for the AR300m with the 128 MB nand?
The MT1300 already supports both of these functions in the 3.200 firmware.
Yes, the problem was fixed in the beta4 version, the beta4 version of ar300m is here.
Has been fixed in version 03.19
Any way to continue to use DLNA media server and network shares on AR750 and MT300N-v2 (or other limited flash devices) with latest firmware? Trying to download them results in a “not enough flash space” message… Time to think of using exroot?
just want to draw attention to a serious regression I’ve noticed on the latest betas:
EDIT:
at least with beta 4 there is some information showing up in the logs:
Fri Mar 19 10:37:48 2021 daemon.err pppd[9265]: Connect script failed
Fri Mar 19 10:37:49 2021 daemon.info pppd[9265]: Exit.
Fri Mar 19 10:37:49 2021 daemon.notice netifd: Interface ‘modem_1_1’ is now down
Fri Mar 19 10:37:49 2021 daemon.notice netifd: Interface ‘modem_1_1’ is setting up now
Fri Mar 19 10:37:51 2021 daemon.notice netifd: modem_1_1 (9315): Trying to set mode
Fri Mar 19 10:37:52 2021 daemon.notice netifd: modem_1_1 (9315): cat: can’t open ‘/tmp/modem.1-1/signal’: No such file or directory
Fri Mar 19 10:37:52 2021 daemon.notice pppd[9520]: pppd 2.4.7 started by root, uid 0
Fri Mar 19 10:37:53 2021 local2.info chat[9530]: abort on (BUSY)
Fri Mar 19 10:37:53 2021 local2.info chat[9530]: abort on (NO CARRIER)
Fri Mar 19 10:37:53 2021 local2.info chat[9530]: abort on (ERROR)
Fri Mar 19 10:37:53 2021 local2.info chat[9530]: report (CONNECT)
Fri Mar 19 10:37:53 2021 local2.info chat[9530]: timeout set to 10 seconds
Fri Mar 19 10:37:53 2021 local2.info chat[9530]: send (AT+CGDCONT=1,“IP”,“orange”^M)
Fri Mar 19 10:37:53 2021 local2.info chat[9530]: timeout set to 30 seconds
Fri Mar 19 10:37:53 2021 local2.info chat[9530]: expect (OK)
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: “orange”^M^M
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: OK
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: – got it
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: send (ATD991#^M)
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: expect (CONNECT)
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: ^M
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: ATD
99
**1#^M^M
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: NO CARRIER
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: – failed
Fri Mar 19 10:37:54 2021 local2.info chat[9530]: Failed (NO CARRIER)
Fri Mar 19 10:37:54 2021 daemon.err pppd[9520]: Connect script failed
Fri Mar 19 10:37:55 2021 daemon.info pppd[9520]: Exit.
Fri Mar 19 10:37:55 2021 daemon.notice netifd: Interface ‘modem_1_1’ is now down
sqm won’t install–fails kernel dependency
this is the 3.18 build at 14:21 gmt for MT1300 (3.19 snapshot)
Working on beta4 released Mar 18th, AR750s and sqm is OK.
With update qsdk-s1300-3.201-0319.img on S1300, nothing changed at all. Still version 3.105. Also same version of Adguard Home as before (v0.105.2).
I can confirm this. Tethering is not usable using Slate and beta4!
Have you installed all the optional plugs at the same time? Or do you have too many VPN profiles taking up space?
It looks like a problem with the power supply. Can you tell me the specification of the power adapter?
Is it Android or iOS, can you tell me the system version?
