I can just say that I never had big trouble with any of the Flint2.
Sometimes Wi-Fi isn't that fast, but for being a router 1 floor under my workplace, it's all good.
So mostly it highly depends on your needs and your wishes. If your internet speed is 500 Mbps and above, you might not be pleased so far, if it's below you will not even feel any differences. (As long as you don't want to transfer big data to your NAS by Wi-Fi for example)
Wi-Fi is a bad technology all in all. It's getting better and better, but it still sucks because it highly depends on many many factors. Like your end device, your walls, your router and even your country, bla bla bla. That's why it's often a mess. Some routers can handle Wi-Fi better, some worse. That depends on the price you want to spend. A real "enterprise-ready" Wi-Fi solution is far behind 1000 $.
That's interesting about the wifi. I have 1000/115 and I can get quite high speeds with 160mhz wide channels. But for me shouldn't be a problem to use the flint 2 without the wireless stuff.
IP & MAC Binding, namely, ARP (Address Resolution Protocol) Binding, is used to bind network device's IP address to its MAC address. This will prevent ARP Spoofing and other ARP attacks by denying network access to a device with matching IP address in the Binding list, but unrecognized MAC address.
I have got to say that I have, so far, been quite disappointed by the instability of my Wireguard client connection (I try and be permenantly connected to Windscribe Wireguard). For me, this is by far the most important functionality of this router but it unfortunately could not keep the connection to wireguard for more than a few days at a time before VPN client needed to be restarted. Still hopefull that this might get resolved with the newer firmware releases.
I would call this an issue with either Windscribe or your internet connection itself.
I am running Mullvad via WireGuard on my Flint2 since day one, without any disconnections or hiccups.
(That's not entirely true: There was 1 major outage ... because I forgot to renew my subscription. )
I really wish that was the case and I keep getting back and forth between the Flint2 and my Asus to see if the situation improves with every firmware but alas to no avail. No such problem with my Asus router I have had to revert to again and which can only lead me to believe that it is the fault with the GL.iNET system:
Hi. I just want to ask if someone mentioned a problem with WAN port speed. Maybe it is a known issue or I have to look on my side. Basically, It takes a few days when randomly my 1Gbps connection will be limited to 100Mbps. I mean speed via Wi-Fi. After I need to manually disconnect cable from WAN port to make it back to 1Gbps. No other manipulations are needed. After, I will get around 800Mbps via WI-FI.
I use PPPoE connection and firmware 4.5.8. I didn't try any other versions of the firmware. Currently, I don't use any features or VPN.
The only non default setting I have is that in Luci, in LAN interface I changed DHCP to my pi-hole instance.
Same story here. Flint2/Mulvad/Wireguard client. Great speed, great reliability.
Also running Wireguard server. No problems there either.
Anyone experiencing Wireguard/VPN problems should maybe check their provider and connection.
No problems at all with this build on Surfshark VPN for me. I've never had a VPN issue on any of the
Flint2 firmware with Surfshark. I use Wireguard primarily but OpenVPN works as well without issue.
I have the same problem. I replaced a Google Nest Router with the Flint 2. With the Nest router I get consistent 900/800Mbps from my 1Gbps connection. With the Flint 2 the upload is always cap at 150Mbps via WIFI and 300Mbps via Cat5e.
This issue happens with default firmware, latest stable, and v4.6 beta release. I even tested using my Nest Router again, and I get 700-800 Mbps consistent upload speeds, Flint 2 never goes above 300Mbps.
I just installed May 28 snapshot -> "openwrt-mt6000-4.6.0-0529-1716928659". Same issue, the upload speed is limited.
for me, as soon as I update to -op24 version, vpn stops working (wireguard connects but no traffic from clients on the lan). I downgrade to 4.5.8 or 4.6.0 (beta 21.x based) and everything resumes normally
Hi. During speed tests, both Speedtest and Fast tests consistently show speeds in the range of 88-92Mbps, without any significant spikes. It doesn't reach higher numbers before dropping down. That why I think it is limited with 100Mbps.
I didn't find in plugins speedtest-go, instead I installed python3-speedtest-cli. I believe both use speedtest. For unknown reasons on router, this test shows really poor results. Maybe it is because of poor server selection. But still it shows like 400Mbps
I'm from Ukraine, I don't think that my ISP will tell you a story. I don't use VPN. I have only pi-hole. I have static IP not from NAT pool.
I don't use Network Acceleration. But when it enabled, I can reach 900Mbps via Wi-Fi.
In my case I have the speedtest-ui by LinuxServer running on a Rasp Pi4 connected via Cat6 to the Flint. It runs a speed test every 1hr. I disconnected the Flint and plugged the Nest Router last night and upload went back up to 900Mbps.
The Flint is connected directly to the Verizon Fios ONT box ethernet port.
I did swap for new cables for WAN and LAN ports, cables are Cat6. Both Flint and Nest router are connected using the same cable/port, I just swap one device for the other.
Hardware Acceleration is Enabled in GL-Inet dashboard.
Software offloading is enabled in Luci.
Changing both of these settings made 0 difference. I even tried turning WIFI off.
