This is by default. 443 is already in use by the GL GUI.
Since 4.5.7 uses new drivers all features (channel analysis, changing radio power, etc. etc.) don’t work yet.
Thanks. Even changing the port, Adguardhome does not save the settings. Regarding the others, I think it’s important to warn them before they release the stable version with these bugs.
It would also be interesting to change the description on the MT6000 on the official website (Flint 2 (GL-MT6000) | High-Performance VPN Router - GL.iNet), as it says that “flint 2’s proprietary firmware is built on OpenWrt (v23 .05 Kernel version 5.15), designed to give you full control of your network and devices. Over 5,000 ready-made plug-ins and applications are at your disposal.”
AGH is not an really official product, keep that in mind.
The issue there is different from the router itself. Pretty sure you will be able to save the settings if you provide a key and pem file for the certificate.
If you still have trouble, feel free to create an dedicated thread just for the AGH issues.
I didn't quite understand what this description meant, but on the MT6000 page, Gl.inet states that it supports AGH: Flint 2 (GL-MT6000) | High-Performance VPN Router - GL.iNet
AdGuard Home
Does this fix these random disconnections on some devices? This only happens on my phone and I need to set it to automatically connect in it’s WIFI settings as a temporary fix. Running 4.5.2 on the Flint 2.
Tue Feb 13 21:10:12 2024 daemon.info hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: disassociated
Tue Feb 13 21:10:13 2024 daemon.info hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Feb 13 21:10:14 2024 daemon.info hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authenticated
Tue Feb 13 21:10:14 2024 daemon.info hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: associated (aid 1)`
Yes it is.
Just little bit modification with GL UI (direct login and iframe graphs). Adguard Home is not made by GL inet.
You don’t need to worry about Encrypt setting page in adguard home. Router security page already used these port.
Personally for me, yes - when moving further away from the router I would get latency or freezes on Zoom calls accompanied by the STA errors. Perhaps the increased range/noise brought my device under the “low” threshold for ACKs.
I might have to try it out. I get the disconnection while in the same room as the Flint 2.
The same thing happens to me with version 4.5.7
Is it a known bug on 4.5.4 for the device to lose the WAN gateway connection and require a restart? LAN and Wifi were still routing fine.
I have not seen that issue since I went to 4.5.6 , you might want to attach some system / kernel logs when that happens though.
The Flint 2 also has the error:
Integrated Nordvpn app has errors. (a button for Surfshark would be cool)
If you go to VPN - Openvpn - press the NORDVPN button and enter your access data on the right, everything works.
If you then look for your respective servers from that country (the quantity doesn’t matter), it reads them in too.
If you then want to connect to a server via: VPN Dashboard - Openvpn, it will be highlighted in yellow but that’s it. It remains yellow and the entire network is blocked.
If I enter each openvpn config manually it works immediately.
Well, I got my first ever Flint 2 crash log today under beta FW 4.5.7.
Oops#1 Part1
<7>[985804.878814] ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_nat ip6t_NPT nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb ip6_udp_tunnel udp_tunnel tun vfat fat ntfs nls_utf8 nls_iso8859_1 nls_cp437 shortcut_fe_ipv6 shortcut_fe mtdoops mtk_warp mtkhnat leds_gpio uhci_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl kmwan ehci_hcd gpio_button_hotplug gl_sdk4_tertf gl_sdk4_black_white_list f2fs ext4 mbcache jbd2 conninfra crc32c_generic crc32_generic gl_sdk4_hw_info [last unloaded: shortcut_fe_cm]
<7>[985805.025655] CPU: 2 PID: 0 Comm: swapper/2 Tainted: P 5.4.238 #0
<7>[985805.033121] Hardware name: GL.iNet GL-MT6000 (DT)
<7>[985805.037898] pstate: 00000005 (nzcv daif -PAN -UAO)
<7>[985805.042794] pc : term_ipv6_update+0x120/0x1b8 [gl_sdk4_tertf]
<7>[985805.048618] lr : term_ipv6_update+0x44/0x1b8 [gl_sdk4_tertf]
<7>[985805.054348] sp : ffffffc010013b70
<7>[985805.057735] x29: ffffffc010013b70 x28: ffffffc010013da8
<7>[985805.063119] x27: 0000000000000000 x26: 00000000e9ca0d61
<7>[985805.068504] x25: ffffff8030379ca0 x24: 0000000000000000
<7>[985805.073887] x23: 0000000000000000 x22: 0000000000000001
<7>[985805.079271] x21: ffffffc00891d000 x20: ffffff801c8cfe60
<7>[985805.084655] x19: ffffff8030379c60 x18: 0000000000000000
<7>[985805.090038] x17: 0000000000000000 x16: 0000000000000000
<7>[985805.095422] x15: 0000000000000000 x14: 0000000000000000
<7>[985805.100806] x13: 0000000000000000 x12: 0000000000000000
<7>[985805.106189] x11: 0000000000000000 x10: 0000000000000840
<7>[985805.111573] x9 : ffffffc010b8bed0 x8 : ffffff80030b9420
<7>[985805.116957] x7 : 0000000000000000 x6 : 00000ba2bee8172c
<7>[985805.122340] x5 : ffffffc00891d0d0 x4 : fc39093811b00120
<7>[985805.127724] x3 : 3548d6dbb58e08e5 x2 : dc82db254aefcde9
<7>[985805.133108] x1 : 0000000000000000 x0 : dc82db254aefcde9
<7>[985805.138493] Call trace:
<7>[985805.141034] term_ipv6_update+0x120/0x1b8 [gl_sdk4_tertf]
<7>[985805.146509] term_ipv6_create+0x2d4/0x370 [gl_sdk4_tertf]
<7>[985805.151983] 0xffffffc0089170d4
<7>[985805.155201] br_handle_frame+0x15c/0x388
<7>[985805.159200] __netif_receive_skb_core+0x538/0xcc0
<7>[985805.163977] __netif_receive_skb_one_core+0x24/0x50
<7>[985805.168927] __netif_receive_skb+0x14/0x60
<7>[985805.173096] process_backlog+0xb8/0x1b0
<7>[985805.177005] __napi_poll+0x38/0x140
<7>[985805.180567] net_rx_action+0xd4/0x228
<7>[985805.184304] __do_softirq+0x124/0x260
<7>[985805.188040] irq_exit+0xb8/0xc8
<7>[985805.191257] handle_IPI+0xe0/0x100
<7>[985805.194733] gic_handle_irq+0x154/0x158
<7>[985805.198641] el1_irq+0xb8/0x140
<7>[985805.201858] arch_cpu_idle+0x10/0x18
<7>[985805.205510] do_idle+0x120/0x148
<7>[985805.208812] cpu_startup_entry+0x24/0x60
<7>[985805.212807] secondary_start_kernel+0x148/0x158
<0>[985805.217414] Code: 14000004 f9400021 eb19003f 54000320 (a9410820)
<4>[985805.223581] ---[ end trace ae878b5d69e331a2 ]---
Panic#2 Part1
<0>[985805.235915] Kernel panic - not syncing: Fatal exception in interrupt
<2>[985805.242343] SMP: stopping secondary CPUs
<0>[985805.246340] Kernel Offset: disabled
<0>[985805.249903] CPU features: 0x00002,20002008
<0>[985805.254071] Memory Limit: none
Can you provide an overview of your configuration when this was occurring?
My Flint 2 configuration is simple:
PPPoE WAN x 2 with failover flavor
WiFI 5GHz(80Mhz)/2.4GHz(20/40Mhz) in WPA2/WPA3 SAE mixed
Network Acceleration : Auto / IPv6 Native
SQM with Simplest queue
CollectD / Stubby+NextDNS running
This crash seem new to me and different than the others i have seen with eth_soc or hostapd, it looks related to ipv6 this time.
Maybe @alzhao or @alex_zheng can note it down internally, or maybe later since of the lunar new year, i just tag them so it will not get lost. ![]()
Just got the Flint 2, updated to the latest (stable?) firmware.
When switching to AP mode, you can’t configure the WAN IP address from the web GUI, just from the iOS app.
When switching to AP mode, you can’t configure guest SSID. You can enable it on the app, but you it’s also enable a DHCP server, and the client can’t access the internet.
The web interface in AP mode is way too basic, and without the guest SSID I can’t really use it ![]()
Will send it back to Amazon, and keep the ASUS RT AX86U…
Routers in general do not function as “routers” in Access Point mode. That is the case with any router that I have used and nothing to do with GL.iNET.
Professional AccessPoints are totally able to have multiple SSIDs with different VLANs. But they are way more expensive and not very easy to use.
Guest SSID in AP mode should work without issues by using luci. Since the GL interface is for easy use you can simply do whatever you like using luci or SSH.
