I agree with you, if the product arrives set correctly to where I live. That wasn't my personal experience.
It's changing just the labels, not the settings.
Try to change between USA and Germany...
The TX-Power LABEL will change (but the power will keep exactly the same whatever country you set, even the label saying it's different)
I'm throwing in the towel for now. I'll check back in six months to see how things are going.
This product needs some ironing out before it's truly reliable. Feels like I've paid for an alpha version of this product.
In the changelogs, include a list of known issues that haven’t been fixed yet.
This will make it easier for customers to decide when it’s worth testing the product again.
True. Tried now with speed test, no more than 100Mbps/sec
Screenshot from 2024-03-20 18-02-55
Yeah, I don’t blame you. It’s frustrating to deal with issues while the hardware is great. I’m going to try my best to wait it out at least until the end of the summer. I don’t want to spend a lot on hardware that doesn’t support Wi-Fi 7. I went with the Flint 2 despite it being Wi-Fi 6 because of the price and built-in AdGuard Home + VPN.
Anyway, I was wondering if we can update to 4.5.7 from 4.5.6 or 4.5.4 with the keep settings option selected. Will it break anything or is it better to start from scratch?
Why is my Flint 2 set to Germany by dafault when I had bought it from Amazon UK in the UK?
A post was split to a new topic: Flint 2 - 4.5.7 - IPv6 issues
Maybe some late invasion from the Krauts, I don’t know.
fw 4.5.7 with wan/lan only 1gbe ???
Don’t do it, just don’t, it can always lead to bug’s especially now that the firmware is based on OpenWrt 21 and not 23
Agree with you @Anaron the hardware is great. The firmware really sucks though. And right now there is no light at the end of the tunnel. 21.02 base is horrible with the proprietary MediaTek drivers. 23.05 base actually functions much better with limitations on the opensource WIFI drivers. MediaTek needs a good kick in the pants.
I did it and its working fine, when I was factory resetting and setting up from scratch I was having all sorts of problem, so this time I kept settings and everything is great…so far…touch wood.
Before upgrading:
Backup all your packages using the opkg script.
Backup all your config through the luci gui
Perform the upgrade.
Restore all your packages with opgk previosuly backuped. Please note that some packages will refuse to install due to different package name in OpenWRT version (21<->23). Check and see if there are packages compatible with OpenWRT version 21 (if you see my previous post, something is already there)
Restore the config (previously backuped) through Luci gui.
:frowning: Noticed this only now…
Yes the wan port is now only 1GB as per speedtest confirmation.
Sorry for asking, but how this firmware can be considered stable? (question for GL staff)
The problem with low speed may be that hardware acceleration is not enabled correctly. Execute ‘dmesg | grep hook’ to check the output, or manually set the web page to hardware acceleration for comparison testing.
Did you find any difference? :thinking:
The hardware acceleration didn’t change absolutly nothing on my side.
With it on or off, the 2.4GHz (20MHz) is still limiting at 100 Mbps
They developed the hardware but they forgot the software/firmware.
GL-iNet will need to start from the beginning instead of trying to find workarounds.
They should put an warning on their website saying this is an experimental product that will be ready not before the Q3
Thanks for that. I won’t be updating to 4.5.7 but it’s good to know for future updates.
I hope that these issues will get resolved soon.
[   28.391606] hook is going to be enabled !
[   52.298529] mtk_ppe_dev_register_hook : ineterface apcli0 register (3)
[   52.505037] mtk_ppe_dev_register_hook : ineterface apclix0 register (4)
Then disabled it:
[87384.933486] hook is going to be disabled !
But the 2.4Ghz WiFi speed is still poor (a little bit better then before)
Screenshot from 2024-03-21 15-13-32
2.4GHz (20 MHz): 100 Mbps
2.4GHz (40 MHz): 150 Mbps
I’m using 20/40 in the config.
Hey guys,
is someone having issues with 160MHz 5GHz speed?
With firmware version lower than 4.5.5, I was able to reach 1500 Mbps over the Wi-Fi, now with the new 4.5.7 “stable” there is no way to go over 1000-1050 Mbps.
Also, with the new stable we completely lost the possibility to adjust Wi-Fi power.
