admon
May 14, 2024, 6:36pm
1996
Yep, can confirm that MT6000 on 4.6 won't connect to GoodCloud anymore.
2024/05/14 20:35:35 info gl-cloud[22133]: (gl-cloud:698) lua-eco version: 3.3.0
2024/05/14 20:35:35 err gl-cloud[22133]: (gl-cloud: 29) /usr/local/lib/lua/5.3/eco/mqtt.lua:118: bad argument #1 to 'new' (string expected, got table)
Edit: Solved this issue by downgrading the application:
Resolved the issue by downgrading the gl-cloud application.
/etc/init.d/gl-cloud stop && rm /usr/bin/gl-cloud && wget https://github.com/Admonstrator/glinet.forum/raw/main/upload/gl-cloud -O /usr/bin/gl-cloud && /etc/init.d/gl-cloud start
After update 4.6.0, adguard was updated to version .46 After that, the print problem started to appear, but even with the admon script it already presented the error, it is related to adguard…
admon
May 14, 2024, 6:52pm
1998
Dondi
May 18, 2024, 10:09am
2000
Disappointed that the 23.05 line does not appear to be maintained. 4.6 is on the not supported 21.02 base.
admon
May 18, 2024, 10:18am
2001
If you follow this thread you will know that there will be a new firmware based on 23.05 - but it's not top priority since the OpenSource drivers aren't totally stable.
are planning to release a version based on 24.xx with kernel 6.6.30
Today's snapshot feels smoother with better WiFi handle and most impotantly with GoodCloud working again. Will continue to test.
Costas
May 18, 2024, 2:48pm
2004
Installing luci-app-upnp on latest snapshot gives errors.
Goodcloud working again.
Collected errors:
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nf-reject6
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nf-ipt
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nf-log
* pkg_hash_fetch_best_installation_candidate: Packages for kmod-nf-log found, but incompatible with the architectures configured
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nf-log6
* pkg_hash_fetch_best_installation_candidate: Packages for kmod-nf-log6 found, but incompatible with the architectures configured
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nf-ipt6
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-ipt-core
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-ip6tables
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nfnetlink
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nf-conntrack
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nf-conntrack6
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nf-nat
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-crypto-hash
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-crypto-crc32c
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-lib-crc32c
* pkg_hash_fetch_best_installation_candidate: Packages for kmod-lib-crc32c found, but incompatible with the architectures configured
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nft-core
* pkg_hash_fetch_best_installation_candidate: Packages for kmod-nft-core found, but incompatible with the architectures configured
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nft-compat
* pkg_hash_fetch_best_installation_candidate: Packages for kmod-nft-compat found, but incompatible with the architectures configured
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.30~a5739d6127118fcd7aa0064290509e1b-r1) for kmod-nf-conntrack-netlink
oly
May 19, 2024, 4:20am
2006
Snapshot Firmware 2024-05-18 openwrt-mt6000-4.6.0-0519-1716057111 it runs without problems, better than the stable version 4.6.0!
as information, change it in luci /system/software and click on configure opkg and then change the option /etc/opkg/distfeeds.conf to the path below and update the packages and everything works again.
src/gz glinet_core https://fw.gl-inet.com/releases/mt798x/kmod-4.5.7/aarch64_cortex-a53/mediatek/mt7986
src/gz glinet_gli_pub https://fw.gl-inet.com/releases/mt798x/packages-4.5/aarch64_cortex-a53/glinet
src/gz glinet_gli_packages https://fw.gl-inet.com/releases/mt798x/packages-4.5/aarch64_cortex-a53/packages
Costas
May 19, 2024, 5:02pm
2008
I can confirm everything work with latest snapshot and above changes.
i wish team gives us a manual entry DoT DNS resolver.
If you use AdGuard Home you could do that but yeah
admon
May 19, 2024, 8:44pm
2010
Even if you don't use it you can simply start to use it on Flint 2.
You can even disable filtering, so it's just some DoT forwarder
admon
Split this topic
May 20, 2024, 11:54am
2011
A post was split to a new topic: Flint 2 looses AP connection
oly
May 20, 2024, 9:06pm
2012
Snapshot Firmware 2024-05-19 openwrt-mt6000-4.6.0-0520-1716143724.bin it runs without problems
bonez
May 21, 2024, 1:35am
2013
Yeah, it's absolute rubbish. I'm still on 4.5.6 as it's the most stable I've come across so far without having to take a step back into the dark ages and use an ancient version of OpenWRT.
Really seriously considering pulling the trigger on an Asus router at the moment. I'm getting 50Mbit over 5GHz WiFi to a PC that's no more than 3 metres away from the router (and it's got a modern WiFi 6 PCIe card in it), as well as random dropouts on my OnePlus 9RT phone via 5GHz WiFi.
But I won't go back to an old version of OpenWRT for minor speed improvements, I think I'll just put this Flint 2 in the cupboard or sell it on eBay.
hob
May 21, 2024, 8:07am
2014
Installing NFS v4 nfs-kernel-server does not work. NFS is crucial for me. Should I report this on a separate thread ?
root@GL-MT6000:~# opkg install nfs-kernel-server
Installing nfs-kernel-server (2.5.2-1) to root...
Downloading https://fw.gl-inet.com/releases/mt798x/packages-4.5/aarch64_cortex-a53/packages/nfs-kernel-server_2.5.2-1_aarch64_cortex-a53.ipk
Collected errors:
* pkg_hash_check_unresolved: cannot find dependency kmod-dm for libdevmapper-selinux
* pkg_hash_fetch_best_installation_candidate: Packages for libdevmapper found, but incompatible with the architectures configured
* satisfy_dependencies_for: Cannot satisfy the following dependencies for nfs-kernel-server:
* kmod-dm
* opkg_install_cmd: Cannot install package nfs-kernel-server.
admon
May 21, 2024, 8:09am
2015
Did you try this already?
src/gz glinet_gli_packages https://fw.gl-inet.com/releases/mt798x/packages-4.5/aarch64_cortex-…
