I’m not miles apart from your use case so, I wonder if the risk of going to the V4.11 beta is low for me. I use a 1Gb/s SFP module to connect to my broadband service. The router has WiFi disabled, I use AdGuard Home and Tailscale and that’s about it, other than reserving IP addresses for all my networked devices and IPv6.
I don’t want to start from scratch on the config so, I’d want to perform an upgrade, and maintain settings. How much of a risk that presents is anyone’s guess I’d expect.
Because you use Tailscale and want to preserve the existing configuration, I would not consider the 4.11 beta a low-risk upgrade. The beta thread already documents a Tailscale/IP Masquerade firewall-ordering issue, as well as configuration-preservation problems in some setups.
If rebuilding the configuration is unacceptable, remain on stable 4.9.2 for now. If you choose to test the beta, first export a LuCI backup, record critical settings separately, download the stable recovery firmware, and be prepared to factory-reset and configure manually—restoring an older backup onto a substantially different firmware branch may reintroduce incompatible settings.
I am loving the the FLINT 4 and MESH (F4 as well). Now is the time to try and break things... lol..
I have docker and a container on the node already which is working well, and now I want to expand the containers but am becoming limited by my uneducated SSH commands and knowledge etc.
I would like to add the Jason Cox Powerwall-Dashboard and need some assistance please.
This is the link to what I am trying to do:-
All is good, I have installed Git and Git-HTTP from Plug-ins and then I have SSH'd into the NODE ok and then I run the install command (sorry I am a monkey see, monkey do person) :-
The next step is I need to setup a few parameters and I enter this command:-
cd Powerwall-Dashboard
That works and I CD to the Directory and with the LS command I can see all the files in that directory - so far so good and then I need to run the setup with the command
./setup.sh
And here is my problem that I do not know how to resolve.....
After running the setup I get this message:-
Powerwall Dashboard (v5.3.0) - SETUP
ERROR: Running this as root will cause permission issues.
Please ensure your local user is in the docker group and run without sudo.
sudo usermod -aG docker $USER
./setup.sh
root@FLINT_4_Node:~/Powerwall-Dashboard#
And here endeth my install and my knowledge on the next step to get this setup working.
It seems I need to login to the F4 node as a user - can I get some guidance on how to do this or how to continue with the setup.
I do have the same script (?) / install running on a RasPI 5 docker container but as I have the u-beaut Flint 4 I would like to use it to the max and remove the Pi 5 / docker from the network.
The installer is stopping intentionally because Flint 4’s normal SSH session runs as root, while setup.sh requires a conventional non-root Linux user with access to Docker. Do not bypass the check or run the displayed sudo usermod command yet—OpenWrt may not provide sudo/usermod, and its user and Docker-socket setup differs from the Linux distributions targeted by this project.
Please run these non-destructive checks on the node and share only their output:
grep '^docker:' /etc/group
ls -ln /var/run/docker.sock
command -v adduser
command -v usermod
docker compose version
They will show whether this firmware has the necessary user-management tools, Docker group/socket permissions, and Compose support. That determines whether a non-root account can be configured safely or whether the project’s documented manual-install method—or continuing to host it on the Raspberry Pi—is the practical option. Powerwall-Dashboard is a third-party project and this installation on Flint 4 is not officially supported by GL.iNet; any guidance is best-effort, and GL.iNet Technical Support may not be able to troubleshoot or maintain it. Do not post Tesla credentials or tokens.
I’m trying to update my Flint 4 to 4.11.0 beta 3; I currently have 4.11.0 beta 1 installed.
The process seems to be going smoothly, but once the router restarts, beta 1 is still installed.
Has anyone else had the same problem?
First verify the complete firmware version and build date under System → Upgrade; the “beta1” label alone may not reliably distinguish builds. If both are unchanged, please state whether you used Online Upgrade or uploaded a local file, and provide the exact firmware filename (but do not upload the firmware itself). This will distinguish an incorrect image/channel from an upgrade or boot failure.
Before retrying, confirm that the image is specifically for GL-BE14000 and compare its SHA-256 checksum with the download-page value if one is provided. Back up the configuration first, but do not factory-reset yet. Since beta firmware may contain upgrade and configuration-migration issues, avoid repeatedly flashing until the image and method are confirmed.
I had the same problem, I had to try three or four times before the upgrade worked (the last time I shut down Adguard home and DPI, then made a restart before upgrading), I also had a problem with the Flint 4’s password after upgrade, it was gone, and I could not login to the portal without a password, but loggin in with SSH worked, and as soon as i had logged in with SSH the Flint 4 told me how to set a password.
I tried it as you described: I turned off AdGuard, disabled network quality, and DPI isn’t active, but I haven’t sorted it out yet...
To be honest, I can’t be bothered to go through the whole configuration process again...
If reconfiguring from scratch is not acceptable, do not use U-Boot recovery or factory-reset the router merely to install beta 3. Since the normal upgrade is not applying, remain on beta 1 for now and avoid repeated flashing until GL.iNet staff confirm whether this beta image has an upgrade-path issue or provide a corrected build.
Keep a current configuration backup, but note that restoring a backup across beta builds may also restore incompatible settings.
There is not yet enough Flint 4 beta 3 feedback to treat the absence of reports as evidence that it is issue-free. In the reports available so far, the main Flint 4-specific problem is the unreliable upgrade from beta 1 to beta 3; one user also reported losing the Admin Panel password after upgrading. Other users completed the upgrade successfully. The Hardware Flow Offloading crash reported elsewhere was on beta 1, so it should not be assumed to affect beta 3 without a new test.
Anyone reporting beta 3 results should include the complete build date and test the features relevant to their setup—especially Mesh stability, VPN throughput, Network Acceleration, AdGuard Home, DPI/Network Quality, IPv6, Docker, and configuration retention. Current reports can be followed in the SDK v4.11 beta thread.
I have 2x different copper SFPs that do not work in 4.11.0 beta 1 or 4.11.0 beta 3.
The same SFPs work fine in 4.9.1 and 4.9.2.
The SFP devices are reported in the dmesg log the exact same as in 4.9.x but in 4.11.0 builds the gl-inet web ui always say they are not inserted.
Beyond that I had attempted to upgrade 4.9.1 to 4.11.0 beta 1 with keep settings which failed. After upload the router did not reboot, the gl-inet web ui became inaccessible the Luci web ui remain available. On router reboot 4.9.1 remained and was again fully functional.
The upgrade succeeded, excluding the above sfp issue, when I selected to not keep settings.
I haven't noticed other issues with either 4.11.0 beta yet.
Because both modules work on 4.9.1/4.9.2 but fail after a clean 4.11 installation, retained configuration is unlikely to explain the SFP issue. This is strong evidence of a 4.11 beta regression, although it is not yet clear whether the failure is limited to the GL.iNet interface/status service or also affects the underlying link setup.
Please provide the exact manufacturer/model and supported speeds of both modules, the complete beta 3 build date, and a short redacted dmesg excerpt covering module insertion. These details will show whether modules on the Flint 4 compatibility list are affected and give staff a focused reproduction case. Your failed “keep settings” upgrade also matches the upgrade-path problem reported by other users.
This log confirms that beta 3 reads the module EEPROM and identifies it as a copper SGMII module, then selects the 1G/2.5G autonegotiation path. However, the SFP state remains waitdev:detached:down, so this is not merely an incorrect Admin Panel status—the module is detected, but the firmware does not attach it to the network device/link path.
Please share the output of these commands, along with the second module’s exact model:
ubus call system board
ip -d link show
This will identify the precise beta 3 build and whether the expected SFP network interface exists. Please also edit or redact the module serial number (sn ...) from the public log if possible.
The 4.9.2 comparison corrects the earlier interpretation: waitdev:detached:down is not sufficient evidence that the module failed to attach, because the working firmware reaches the same SFP state. The meaningful evidence is that the same module works on 4.9.2 but not after clean installations of 4.11 beta 1 and beta 3. The ubus output identifies beta 3’s OpenWrt base as 25.12-SNAPSHOT with kernel 6.12.94.
There is no need to post the full ip -d link show output publicly. For a focused reproduction report, please provide only the complete GL.iNet firmware version/build shown under System → Upgrade and the exact model of the second module. Any full interface output can instead be sent privately to a GL.iNet technical support member.
