Flint firmware 4.1.0 release6 is out
.TAR
https://fw.gl-inet.com/firmware/snapshots/20221102_4.1.0_release6/ax1800/openwrt-ax1800-4.1.0-1114-1668412657.tar
.IMG
https://fw.gl-inet.com/firmware/snapshots/20221102_4.1.0_release6/ax1800/openwrt-ax1800-4.1.0-1114-1668412657.img
GL.iNet Firmware Download: https://dl.gl-inet.com/
Release Notes:
V4.1.0 - Nov 14,2022
UI
Optimize the structure of the side feature menu bar
Fix the occasional error message
Internet
Add VLAN ID setting entry in PPPoE mode
Fix unplugging the cable in Static mode will reset the static IP Settings
Add support for EM160R/EM060k/EM120K/RM520N modems
Nginx
Fix Nginx memory leak
Repeater
Fix issue to ensure that deleting saved Wi-Fis does not cause crash
Fix for repeating Wi-Fi with WPA2 EAP will fail
Add error message that repeating fails due to MAC Clone
Fix repeater fails to connect with an incorrect password message after router reboot
Wireless
Fix occasional non-broadcast of Guest Wi-Fi after router reboot
Fix incorrect display of Guest Wi-Fi in Bridge/AP/Extender/WDS mode
Fix memory leaks
Fix Guest Wi-Fi will fail when repeating
Clients
Add device type and name modification feature
Add device list sorting feature
Optimize the speed display to show the average speed of the last 3 minutes
VPN
Add Tor feature
Optimize the display of the proxy mode switch button to make it more eye-catching
Added a wizard to setup VPN Client
Add the start VPN button to the list of configuration files on the VPN Client page
Add the restriction rule to prevent the upload of OpenVPN configuration files with different encryption methods to the same group
Fix uploading larger zip files that would fail
Add a limit on the number of configuration files within an upload zip file, not more than 1000 per zip file
Fix the failure to add the same routing rule as the deleted one
Add error message for failure to decompress uploaded files
GoodCloud
Fix multiple MQTT processes appearing
Fix router cannot refresh the binding information after GoodCloud is bound
Fix RTTY cannot connect
Network Storage
Add quick setup share feature
Fix the WAN interface not getting the address due to network storage
Add support for exFAT.
Network
Add Multi-WAN feature
Add IGMP Snooping feature
Fix DDNS not working in Bridge/AP/Extender/WDS mode
Fix the Extender mode does not work when Override DNS Settings for All Clients is enabled.
Fix WDS mode not working when WAN port is used as LAN port
Fix the WAN/LAN mode of WAN port can not be switched in MAC Clone status
Fix Wi-Fi exception after modifying the LAN IP
Fix for IPv6 settings being lost when upgrading firmware with kept settings
System
Add Overview feature
Add Scheduled Tasks feature
Add reminder dialog for new version upgrade
Fix web logout exception after synchronization timezone
I have been doing clean installs with GL.iNet UI upgrade using .tar files and not keeping settings. I then install packages(SQM sqripts, Netdata, collectd ). I will load a config file I generated from the previous release and go see what happens.
OpenWRT 22.03.x changed FW3 to FW4 which is causing firewall rules to break. I posted on release 5 forum some links but best advice is to set everything up fresh.
:gl_emoji_dizzy:I do not work for and I am not directly associated with GL.iNet :gl_emoji_shacking:
Smooth upgrade for me with my config. Been up and running about 30 minutes.
Screenshot 2022-11-14 124619
In each update, without resetting the settings, I have to reactivate the samba server because it does not work.
Same for me on Slate AX
Updated from beta 5 to beta 6 keeping user settings, all seems stable after 12 hours.
Flint AX-1800.
Memory usage seems to have dropped by around 8-10% for me.
I noticed that too but cache went up by 10% in the the First 24 hours and dropped to where it is now.
I have Adguard Home running OISD full list, WireguardVPN client, Mac address exclusion VPN policy 15 devices 3 of which are another Flint, Beryl and Slate AX:
It 92% and I am sure if I through SAMBA file share into it it might crash.
Its stable so I will let it run
84-85% for me with 22% in cache. Running Adguard, WireGuard.
I also see that Slat AX AXT1800 beta release7 is now the 4.1.0 Stable release
https://dl.gl-inet.com/?model=axt1800
I can’t get into Luci after the upgrade. It just loads the Luci login page with no error shown when entering the correct credentials.
When entering incorrect credentials, I still get the standard user/pass is wrong error. I have an A1300 Slate.
Thats the wrong firmware for your device Slate AX GL-AXT1800 is based more on the Flint GL-AX1800.
!!!SLATE PLUS GL-A1300!!!:GL.iNet download center
You will probably need to Uboot:
yes, can restart the system maybe, the samba server can work.
Flint Tethering with Huawei 3372 almost works. Connects or appears to sometimes but won't route packets. Log here:
Mon Nov 28 20:41:44 2022 daemon.notice netifd: tethering (3953): udhcpc: received SIGTERM Mon Nov 28 20:41:44 2022 daemon.notice netifd: tethering (3953): udhcpc: unicasting a release of 192.168.8.144 to 192.168.8.1 Mon Nov 28 20:41:44 2022 daemon.notice netifd: tethering (3953): udhcpc: sending release Mon Nov 28 20:41:44 2022 daemon.notice netifd: tethering (3953): udhcpc: entering released state Mon Nov 28 20:41:44 2022 daemon.notice netifd: tethering (3953): Command failed: Permission denied Mon Nov 28 20:41:44 2022 daemon.notice netifd: Interface 'tethering' is now down Mon Nov 28 20:41:44 2022 daemon.info avahi-daemon[3911]: Withdrawing address record for 192.168.8.144 on eth5. Mon Nov 28 20:41:44 2022 daemon.info avahi-daemon[3911]: Leaving mDNS multicast group on interface eth5.IPv4 with address 192.168.8.144. Mon Nov 28 20:41:44 2022 daemon.notice netifd: Interface 'tethering' is disabled Mon Nov 28 20:41:44 2022 daemon.info avahi-daemon[3911]: Interface eth5.IPv4 no longer relevant for mDNS. Mon Nov 28 20:41:44 2022 daemon.notice netifd: Interface 'tethering' has link connectivity loss Mon Nov 28 20:41:44 2022 daemon.info avahi-daemon[3911]: Interface eth5.IPv6 no longer relevant for mDNS. Mon Nov 28 20:41:44 2022 daemon.info avahi-daemon[3911]: Leaving mDNS multicast group on interface eth5.IPv6 with address fe80::21e:10ff:fe1f:0. Mon Nov 28 20:41:44 2022 daemon.info avahi-daemon[3911]: Withdrawing address record for fe80::21e:10ff:fe1f:0 on eth5. Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: reading /tmp/resolv.conf.d/resolv.conf.auto Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain test Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain onion Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain localhost Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain local Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain invalid Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain bind Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain lan Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: using nameserver 198.142.152.164#53 Mon Nov 28 20:41:44 2022 daemon.info dnsmasq[7102]: using nameserver 198.142.152.165#53 Mon Nov 28 20:41:44 2022 user.notice mwan3[21259]: Execute ifdown event on interface tethering (unknown) Mon Nov 28 20:41:45 2022 user.info mwan3track[8198]: Detect ifdown event on interface tethering (eth5) Mon Nov 28 20:41:45 2022 user.notice mwan3track[8198]: Stopping mwan3track for interface "tethering" Mon Nov 28 20:41:51 2022 kern.err kernel: [63692.978993] cdc_ether 1-1:1.0 eth5: kevent 12 may have been dropped Mon Nov 28 20:41:51 2022 kern.err kernel: [63692.979073] cdc_ether 1-1:1.0 eth5: kevent 12 may have been dropped Mon Nov 28 20:41:51 2022 kern.err kernel: [63692.984110] cdc_ether 1-1:1.0 eth5: kevent 12 may have been dropped Mon Nov 28 20:41:51 2022 daemon.notice netifd: Interface 'tethering' is enabled Mon Nov 28 20:41:51 2022 daemon.notice netifd: Network device 'eth5' link is up Mon Nov 28 20:41:51 2022 daemon.notice netifd: Interface 'tethering' has link connectivity Mon Nov 28 20:41:51 2022 daemon.notice netifd: Interface 'tethering' is setting up now Mon Nov 28 20:41:51 2022 daemon.notice netifd: tethering (22175): udhcpc: started, v1.33.2 Mon Nov 28 20:41:51 2022 daemon.notice netifd: tethering (22175): udhcpc: sending discover Mon Nov 28 20:41:51 2022 daemon.notice netifd: tethering (22175): udhcpc: sending select for 192.168.8.145 Mon Nov 28 20:41:51 2022 daemon.notice netifd: tethering (22175): udhcpc: lease of 192.168.8.145 obtained, lease time 86400 Mon Nov 28 20:41:51 2022 daemon.info avahi-daemon[3911]: Joining mDNS multicast group on interface eth5.IPv4 with address 192.168.8.145. Mon Nov 28 20:41:51 2022 daemon.info avahi-daemon[3911]: New relevant interface eth5.IPv4 for mDNS. Mon Nov 28 20:41:51 2022 daemon.info avahi-daemon[3911]: Registering new address record for 192.168.8.145 on eth5.IPv4. Mon Nov 28 20:41:51 2022 daemon.notice netifd: Interface 'tethering' is now up Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: reading /tmp/resolv.conf.d/resolv.conf.auto Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain test Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain onion Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain localhost Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain local Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain invalid Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain bind Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using only locally-known addresses for domain lan Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using nameserver 198.142.152.164#53 Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using nameserver 198.142.152.165#53 Mon Nov 28 20:41:51 2022 daemon.info dnsmasq[7102]: using nameserver 192.168.8.1#53 Mon Nov 28 20:41:52 2022 user.notice mwan3[22226]: Execute ifup event on interface tethering (eth5) Mon Nov 28 20:41:52 2022 daemon.info avahi-daemon[3911]: Joining mDNS multicast group on interface eth5.IPv6 with address fe80::21e:10ff:fe1f:0. Mon Nov 28 20:41:52 2022 daemon.info avahi-daemon[3911]: New relevant interface eth5.IPv6 for mDNS. Mon Nov 28 20:41:52 2022 daemon.info avahi-daemon[3911]: Registering new address record for fe80::21e:10ff:fe1f:0 on eth5.*. Mon Nov 28 20:41:52 2022 user.notice mwan3[22226]: Starting tracker on interface tethering (eth5) Mon Nov 28 20:41:54 2022 user.info mwan3rtmon[3799]: Detect rtchange event. Mon Nov 28 20:41:55 2022 user.notice firewall: Reloading firewall due to ifup of tethering (eth5) Mon Nov 28 20:42:01 2022 daemon.warn dnsmasq[7102]: nameserver 198.142.152.165 refused to do a recursive query Mon Nov 28 20:42:11 2022 daemon.warn dnsmasq[7102]: nameserver 192.168.8.1 refused to do a recursive query
Copyright © 2022 GL.iNet. All Rights Reserved
That is unfortunate that it does not work, but you don’t need to show your displeasure by posting the log in the most obnoxious way possible( I know you just copied and pasted, maybe use notepad or wordpad next time or download the log). It makes it really difficult to follow the timeline
Is there something else to it like a vpn running or adguardhome. It seems that its having a issue with ipv4 switching to ipv6.
mwan3 also seems to be doing something, is it set-up to load-balance or for fail-over?
Anyone know if it’s normal for upgrading via Local Upgrade? I don’t see a new version under “Online Upgrade” So I downloaded the .img from the Download Centre
I got an error where the Version Number is unknown…
.img is meant for Uboot .tar is for local upgrade
When I use .tar, it throws error
“ERROR: Incorrect firmware format!”
I see you are talking to cafebug to.
The latest stable firmware for version 3.x is 3.214 this was based on chaos calmer 15.05 a deprecated version of openwrt
4.x is the newest firmware and GL.iNet User Interface is based on openwrt 21.02 and LuCi 22.03
You will need to use uboot to upgrade past 3.214 to 4.10.0
Also will want to update uboot before
hansome
Oct 20
That’s a uboot bug, the fixed version can be downloaded here .
Upgrade uboot by the following steps:
  1. connect LAN and PC by ethernet, the PC’s ip should be 192.168.1.x
  2. push the reset button and power it on, about 10 seconds later release the button, until the wifi led stops flashing and the white led turns on.
  3. access http://192.168.1.1/uboot.html to flash uboot.
Thanks a lot. I guess I’ll just hang on 3.214 until I have the motivation to reconfigure my router, haha :joy:
Thanks~~
So you can save a config file in LuCi upgrade to 4.x install the SQM package in LuCi and then load the Config file. It seems to have worked with no issue. The key is installing the sqm package becuase it writes a rudimentary ipv4 to ipv6 iptable NFtable swap.
You could also install iptables-nft (assuming that’s in the gli repo) which does a full translation between iptables and nftables. This is the easiest way to get various non-nftables aware software working right now.
