When you updated versions you need to check firewall adguard TCP and UDP. After that full restart adguard home (switch off then on).
Thank you very much for your reply.
I did an U-boot to downgrade my A1300 to Version 4.2.0 firmware and just enable AdGuard which work fine with default AdGuard DNS filter list loaded, the AdGuard version is V0.107.8.
After update to Version 4.2.1 firmware, AdGuard is running but not loading the default AdGuard DNS filter list. Count stays at “0”. The new 4.2.1 updates AdGuard to V0.107.26.
Same as above U-boot A1300 to 4.2.0 but update to latest firmware 4.5.17, which also update AdGuard from V0.107.8 to V0.107.26. It fails to load DNS filter list.
Wonder any GL.inet experts help to give us instructions to downgrade AdGuard to V0.107.8 from V0.107.26 so that we can update A1300 to latest firmware version 4.5.17 but use old version V0.107.8 of AdGuard.
Thanks & Best Regards,
ver.4.2.1
RELEASE NOTES
Bug Fixes
Fixed a problem where the WiFi configuration page showed unavailable channel options.
Fixed a problem where NordVPN could not resolve DNS after keeping settings upgrade.
Fixed a problem where GL-MT3000 failed to recognize USB3.0 modem.
Fixed a problem where the IPV6 rate limiting does not take effect.
Fixed a problem where GL-MT3000 failed to repeat to iPhone 13 and TP-LINK ACR700.
Fixed a memory leak problem in GL-MT3000 when using QCM protocol.
Fixed a probabilistic issue where GL-MT3000 could not apply OpenVPN username and password.
Fixed switch button not taking effect when parental control is enabled on GL-A1300.
Fixed a BUG where clients could not access the internet after failover.
Optimizations
Disabled nginx access logs.
Optimized the MWAN3 online detection threshold.
Optimized the synchronization of configuration files in abnormal situations.
Optimized the repeater scan time of GL-MT3000.
Software Upgrade
Upgraded AdguardHome to V0.107.26.
Thank you, I will submit this information to evaluate if it available to merge in the newer router firmware.
Are there any updates on this topic? Upgraded to 4.5.19 but AdGuard still downgraded version V0.107.26...
J33Bee,
I get around the problem by downgrade A1300 to V.4.2.0, set up AdGuard. After complete then upgrade firmware to V.4.5.19. Hope it works for you.
Best Regards
Thank you for assisting with this! Very appreciated. Can I do a downgrade and restore config or will the config be intact after a downgrade?
Never did a downgrade and it's the other way around to fix something in AdGuard which is broke in a newer version... @bruce any updates on this topic?
On downgrade to V.4.2.0 firmware, the configuration will be reset to default reset firmware state. As my setup is quite simple sorry I never tried to restore the config. On firmware V.4.5.19, AdGuardVersion: v0.107.26 seems more stable, I can update the blocklist daily.
Regards,
Due to hardware limitations, currently, it is suggested to downgrade the ADG version in the latest firmware.
Or refer to ymlee's method.
Is there a manual to downgrade ADG from GL.inet? You guys advertise with ADG but give a workaround in order to have it fully functional working.
If I knew this up front I never bought this hardware limited router...
If you required to downgrade the ADG in the latest firmware, please PM me to get the ADG ipk and method.
It's to much trouble for me.
Can I restore my config to a better/faster router like the GL-AXT1800?
Backup config of different router models may be incompatible (hidden). Brand-new config is recommended.
Did you ever get this figured out? The default adguard block list added fine but I can't add OISD large on the GL-A1300.
Nope. I sold mine and bought the Slate AX (AXT1800) which still has firmware issues… see;
So you can’t connect to VPN with the slate AX? Are you able to at least add filters in AdGuard Home? That sucks you’ve had issues with both models.
I actually have a Flint 2 arriving tomorrow to be my main router (currently using router from ISP). My goal was to use the Slate as a portable router. Hoping I can get AdGuard and VPN server working on the Flint 2 so I can just set up the Slate as the VPN client.
Thanks I’ll look into that. I’m not sure I know how to do that though
I can connect to my VPN server with the Slate AX as a client, but the 4.6.4 & 4.6.8 firmware generates errors in the "get-status". This should be an easy fix (hopefully).
Adding and updating AdGuard blocklists works just fine on the Slate AX as well on my Brume 2. It's just the Slate Plus can't do it...
Could you provide ADG ipk and method please?
