Slate AX Wireless Section inaccessible "Unknown error occurred" since updating
Hello, not sure if it's related to the update, but I can no longer access the Wireless menu of my router. It says "Unknown error occurred. Please check the Network environment or reboot device" Rebooting doesn't work. How do I fix it? version is: 4.6.4
Thanks for your feedback.
Please try to execute these commands in the SSH:
uci set wireless.default_radio0.ifname='wlan1'
uci set wireless.default_radio1.ifname='wlan0'
uci set wireless.guest5g.ifname='wlan1-1'
uci set wireless.guest2g.ifname='wlan0-1'
uci commit wireless
reboot
That worked. Thanks.
I have the same problem when trying to access Wireless section.
Where do I go and what do I click to execute those commands?
you have to go into your windows laptop cmd.exe and type: ssh.exe root@192.168.8.1 then password then do the commands above
@guestgulkan
Thank you very much. It worked.
Now I know little bit about SSH.
thanks it works for me too
This worked for me too, thanks.
Update:
This issue caused by repeater and channel.
We have submitted it and trying to improve this issue.
I had a power blip and the upstream wifi power cycled and changed channel. after that I got the error above and the uci comands provided resolved the wireless page issue.
maybe related to this error:
Sun Oct 13 04:15:56 2024 daemon.err hostapd: 20/40 MHz: center segment 0 (=38) and center freq 1 (=5755) not in sync
when the gl axt-1800 is connected to this network it does not repeat on this channel 149. I believe I have had it configured to do so prior. so its quite odd.
Let me know if you have something I can test
This is a known issue, the codes had been submitted.
Waiting for the next version firmware to be merged and released.
This does not fix the issue overhere. Bought this router because of the hardware limits of the Slate Plus. When going to the VPN section, this error also shows...
Seems you opened a new discussion here.
The wireguard list seems has problems. Can you explain a little bit how this is caused?
Firmware version? Upgrade from old version?
Wireguard configuration details?
I just hide the configuration file with 1337 paint skills, because it gives info which I don't want to share. VPN works just fine.
I just keep on getting this error when browsing to the VPN section on my new GL-AXT1800. These errors where already all over the place (not only VPN section) when powering on the router from the beginning. First updated to v4.6.4 and the above errors where less, not sure if they only popped up on the VPN section after completing the update.
Configured my router, but error still keeps showing after booting (1 time). It looks after that, the error is not showing anymore, but when I reboot I can reproduce it again in the VPN section. I also run above commands to make sure this may fix my issues, because I had no errors on the Wireless section after upgrading.
Maybe you and clear the list and add again. Generally it fixes the error
You mean my WireGuard configs? So deleting and adding them again?
Yes. That is right.
Okay, will do. Let you guys know the outcome
Nope, still get this same error. Did remove all WireGuard profiles, reboot and re-add all the configs, again reboot, build up VPN but error shows up again in VPN section.
It also happens when using OpenVPN. So disconnect WireGuard, connect via OpenVPN and the error shows again (1 time).
Funny thing, I get this error on an iPad with iPadOS 18.0.1 and Safari. When using my MacBook Pro with Sonoma this error also occurs in Safari* but using FireFox as browser, these errors are not there anymore...
*there it keeps on coming in the VPN section, so not only 1 time.
I also have OpenVPN config (1 profile). Should I have removed that one too? What does the error mean? Doesn't feel I have a proper working router with these kind of errors :frowning:
It is usually caused if you have a lot of profiles so the browser cannot rendor or have some special things in the profile names.
Do you observe anything special?
