GL-E750/Mudi - 4.2 Firmware (Snapshot/Beta)
Hey,
As the snapshot version of 4.2 firmware for Mudi has surfaced (thanks to the dev team!), let’s have this thread for feedbacks and development of the upcoming firmware update.
I personally haven’t installed the snapshot just yet (will do so very soon and share my experience), but top 3 features that I would like to see in 4.2 update for Mudi are as follows:
  1. eSim support (discussed the possibilities in a separate thread, link below)
  2. Native suport for Multi-WAN (Load Balancing): currently kind of possible with some tweaks with luci-app-mwan3 plugin, but it would be great to see a native support of Load Balancing in the main pannel (similar to GL-MT3000 Beryl).
  3. WebDAV support for Micro SD file transfer. It currently only supports unsecured SMBv1 which is quite slow, making it not so much practical.
eSim support discussion thread:
我更新了3.18日的版本,无法正常启动。
Updated via Web Admin Panel from 3.216 and stuck on System Updating. Rebooted after 15 min and now stuck on rebooting (90%) :roll_eyes:
You can always revert back to the older firmware using UBoot:
Same happened to me. Had to uboot recover. But did not find downloadable 4.2 images anywhere. They vanished and OTA update is no longer offered to me. My Mudi is back on 3.2.15
Downloadable 4.2x images for Spitz also disappeared.
Edit: Spitz is back. Mudi was definitely pulled.
Correct, the 4.2 Snapshot build disappeared from the firmware download page.
