GL-iNet AX1800 OpenWrt firmware
Sure DM me the address and I will crack on with it.
Hello! Are you in possession of a vanilla OpenWrt image specifically designed for the Flint router? I’m interested in flashing it onto my router as I would like to remove the stock GL.iNet web admin interface. However, I’m uncertain about the process of compiling the firmware myself.
His latest Open-WRT version for the AX1800 (Flint) andAXT-1800 (Slate AX) is available here…
Thanks motox22a
Just testing another build compiled last night if it boots and works well I will push it to snapshots folder.
Please only use snapshots folder for downloading images.
Unfortunately the WiFi is crashing very fast under high load (public network):
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.154064] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.154088] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.157779] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.165885] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.172063] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.181160] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.186431] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.194786] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.200882] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.209969] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:19:54 2023 kern.warn kernel: [71988.215283] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.671426] ath11k_warn: 86 callbacks suppressed
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.671449] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.675139] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.682800] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.689376] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.695937] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.702430] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.708557] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.715800] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.722398] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:20:01 2023 kern.warn kernel: [71994.729053] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.739567] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.739590] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.743318] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.750984] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.757515] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.764068] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.770538] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.776729] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.783959] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.790503] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:20:07 2023 kern.warn kernel: [72000.797210] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.810452] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.810473] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.814169] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.821845] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.828398] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.834984] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.841454] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.847577] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.854812] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.861426] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:20:13 2023 kern.warn kernel: [72006.868074] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.880534] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.880556] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.884247] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.891902] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.898484] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.905056] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.911537] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.917664] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.924899] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.931502] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:20:19 2023 kern.warn kernel: [72012.938159] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.153606] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.153629] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.157322] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.165508] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.171600] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.180871] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.185972] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.194333] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.200459] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.209468] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:24 2023 kern.warn kernel: [72018.214823] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:31 2023 kern.warn kernel: [72024.952145] ath11k_warn: 86 callbacks suppressed
Thu May 25 19:20:31 2023 kern.warn kernel: [72024.952169] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:31 2023 kern.warn kernel: [72024.955860] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:31 2023 kern.warn kernel: [72024.963527] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:20:31 2023 kern.warn kernel: [72024.970097] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:20:31 2023 kern.warn kernel: [72024.976660] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:20:31 2023 kern.warn kernel: [72024.983156] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:20:31 2023 kern.warn kernel: [72024.989277] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:20:31 2023 kern.warn kernel: [72024.996521] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:31 2023 kern.warn kernel: [72025.003117] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:20:31 2023 kern.warn kernel: [72025.009773] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.020205] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.020228] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.023918] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.031572] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.038153] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.044728] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.051208] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.057336] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.064580] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.071168] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:20:37 2023 kern.warn kernel: [72031.077829] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.085243] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.085265] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.088955] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.096606] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.103238] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.109717] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.116224] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.122405] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.129585] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.136196] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:20:43 2023 kern.warn kernel: [72037.142918] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.156133] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.156157] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.159847] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.167519] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.174118] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.180632] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.187104] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.193306] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.200512] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.207069] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:20:49 2023 kern.warn kernel: [72043.213772] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.223194] ath11k_warn: 86 callbacks suppressed
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.223217] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.226907] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.234597] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.241184] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.247670] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.254176] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.260356] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.267537] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.274147] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:20:55 2023 kern.warn kernel: [72049.280851] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.293215] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.293237] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.296928] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.304585] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.311198] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.317689] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.324195] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.330378] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.337558] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.344162] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:01 2023 kern.warn kernel: [72055.350860] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.362081] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.362104] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.365795] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.373459] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.380063] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.386557] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.393062] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.399212] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.406459] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.413041] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:07 2023 kern.warn kernel: [72061.419707] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.427215] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.427237] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.430959] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.438593] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.445206] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.451727] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.458181] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.464376] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.471596] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.478148] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:13 2023 kern.warn kernel: [72067.484854] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.498105] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.498127] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.501835] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.509450] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.516090] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.522605] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.529069] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.535255] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.542475] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.549035] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:19 2023 kern.warn kernel: [72073.555736] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.565153] ath11k_warn: 86 callbacks suppressed
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.565176] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.568867] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.576515] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.583151] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.589660] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.596125] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.602318] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.609531] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.616090] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:25 2023 kern.warn kernel: [72079.622796] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:31 2023 kern.warn kernel: [72085.636032] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:21:31 2023 kern.warn kernel: [72085.636053] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:31 2023 kern.warn kernel: [72085.639762] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:31 2023 kern.warn kernel: [72085.647377] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:31 2023 kern.warn kernel: [72085.653998] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:32 2023 kern.warn kernel: [72085.660530] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:32 2023 kern.warn kernel: [72085.666996] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:32 2023 kern.warn kernel: [72085.673184] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:32 2023 kern.warn kernel: [72085.680401] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:32 2023 kern.warn kernel: [72085.686962] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:32 2023 kern.warn kernel: [72085.693662] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.705290] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.705313] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.709004] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.716672] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.723293] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.729783] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.736262] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.742463] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.749662] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.756226] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:38 2023 kern.warn kernel: [72091.762932] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.770461] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.770484] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.774175] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.781829] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.788412] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.794996] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.801466] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.807592] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.814834] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.821431] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:44 2023 kern.warn kernel: [72097.828087] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.839299] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.839320] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.843007] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.850641] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.857244] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.863815] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.870296] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.876426] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.883666] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.890264] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:50 2023 kern.warn kernel: [72103.896921] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.906327] ath11k_warn: 86 callbacks suppressed
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.906350] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.910073] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.917709] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.924316] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.930842] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.937294] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.943490] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.950704] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.957262] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:21:56 2023 kern.warn kernel: [72109.963963] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:22:02 2023 kern.warn kernel: [72115.977469] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:22:02 2023 kern.warn kernel: [72115.977490] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:22:02 2023 kern.warn kernel: [72115.981206] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:22:02 2023 kern.warn kernel: [72115.988814] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:22:02 2023 kern.warn kernel: [72115.995456] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:22:02 2023 kern.warn kernel: [72116.001976] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:22:02 2023 kern.warn kernel: [72116.008434] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:22:02 2023 kern.warn kernel: [72116.014618] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:22:02 2023 kern.warn kernel: [72116.021840] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:22:02 2023 kern.warn kernel: [72116.028399] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:22:02 2023 kern.warn kernel: [72116.035100] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.047394] ath11k_warn: 70 callbacks suppressed
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.047417] ath11k c000000.wifi: failed to send WMI_PDEV_BSS_CHAN_INFO_REQUEST cmd
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.051136] ath11k c000000.wifi: failed to send pdev bss chan info request
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.058774] ath11k c000000.wifi: failed to send WMI_PDEV_SET_PARAM cmd
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.065369] ath11k c000000.wifi: Failed to set beacon mode for VDEV: 1
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.071912] ath11k c000000.wifi: failed to send WMI_BCN_TMPL_CMDID
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.078362] ath11k c000000.wifi: failed to submit beacon template command: -108
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.084554] ath11k c000000.wifi: failed to update bcn template: -108
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.091768] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.098329] ath11k c000000.wifi: failed to set BA BUFFER SIZE 256 for vdev: 1
Thu May 25 19:22:08 2023 kern.warn kernel: [72122.105032] ath11k c000000.wifi: failed to send WMI_VDEV_SET_PARAM_CMDID
Thu May 25 19:22:14 2023 kern.warn kernel: [72128.112547] ath11k_warn: 70 callbacks suppressed
Which device?
Thanks for the logs. WiFi seems to be an issue as of late.
I use a AX1800 Flint, i also noticed a 200Mbit Wifi throughput drop compared to the stock firmware.
Thanks for heads up will look into it.
Would this be the appropriate image to install if I prefer a clean version of OpenWrt without any extra packages? Specifically, the image is “openwrt-ipq60xx-generic-glinet_gl-ax1800-squashfs-nand-factory.ubi.”
When you say without extra packages in what manner are we talking about?
Included in all my builds there is a openwrt-ipq60xx-generic.manifest file which shows what is installed in the image.
What I mean was no extra packages like luci_app_sqm, etc.
All good. That answers my question. Thanks!
There is extra packages such as sqm,qos etc included in my builds however you can either remove them after install or compile the firmware to your liking from my repo solidus1983/openwrt at ipq60xx_devel (github.com) just please note that the repo is currently being worked on right now.
Thank you so much! I guess I’ll go ahead and remove those unnecessary packages after flashing your image.
@solidus1983 You are welcome. Also thank you very much for your work which you put into this firmware.
How long does this uboot flash to complete? It’s over 5 minutes already.
Edit: More than 10 minutes now.
Edit: After 30 minutes I gave up.
Unit flashes in seconds
Not sure why but it stuck on flashing. Waited for about 30 minutes twice. Good thing it didn’t wipe the device.
There is no flashing progress indicator. Flashing and booting shouldn’t take longer than 2- 3/min.
The routers IP will be: 192.168.1.1
That’s the thing. I’ve waited for the router to restart but didn’t. I was pinging the router before I started the flash so I can tell if the router has restarted.
Hi right which URL did you use to flash uboot.
http://192.168.1.1/index.html / http://192.168.1.1 or http://192.168.1.1/uboot.html ?
Also on the snapshot folder over at R23155 (solidus1983.duckdns.org) are some new images.
