GL-MT300N-V2 unable to be repeater for wifi network channel 13
Up to today I’ve been successfully using my GL-MT300N-V2 as a repeater for a Mifi device. The GL-MT300N-V2 connects to the Mifi’s wifi network in ‘repeater’ mode, and then I connect a device (Cisco VOIP phone) that only supports ethernet to the GL-MT300N-V2. This means the Cisco desk phone can effectively use the Mifi device’s network through the GL-MT300N-V2.
This suddenly didn’t work today because the GL-MT300N-V2 can’t find the Mifi’s wifi network anymore. If found the reason is that the Mifi has decided to go onto 2.4Ghz channel 13. The Mifi is provided by my work so I have no access to its settings to change what channel it chooses. I’m in Australia where ch 13 is legal, but my GL-MT300N-V2 came from Amazon so might’ve originally been shipped from the US (Australia’s Amazon actually ships a lot of things from the US directly).
My question is can I change the wifi regulatory domain to support channels 12-13 in repeater mode?
I’ve tried lots of things but no luck:
Setting the wifi regulatory domain on Linux and OpenWRT
https://openwrt.org/docs/guide-user/network/wifi/basic
https://medium.com/openwrt-iot/lede-openwrt-setting-regulatory-domain-b18da03f9126
https://openwrt.org/docs/guide-user/network/wifi/wifi_countrycode
https://forum.gl-inet.com/t/does-it-work-on-channel-13/4214/2
https://forum.gl-inet.com/t/wifi-country-setting-in-mango/8495
https://forum.gl-inet.com/t/gl-ar150-channel-13-needed-for-upstream-router-wisp/1581/3
You can ssh to the router and change the wifi settings.
For Japan you can use up to channel 14.
uci set wireless.mt7628.country='JP'
uci set wireless.mt7628.region='5'
uci set wireless.mt7628.channel='13'
uci commit wireless
wifi
Thanks! That fixed it
