Hello
I got a GL-X3000 and would like to connect it directly to the 12V electrical system in my motorhome (Fiat Ducato model 2019). Is this possible or do I need a voltage converter?
How much voltage difference does the GL-X3000 work without errors?
Youâre good with a direct connection to your 12v system. The X3000 accepts 9-36V. The prototype case for the X3000 actually had 9-36V DC written on it, but GL was concerned that it would confuse consumers.
Could you let us know how you connect X3000 on motorhome 12V DC? A picture showing it would be appreciated.
To help our customers to connect with motorhome battery easily, we are preparing some power cable samples, showed as below picture, 1 meter power cable with 3A fuse. And we can sent one sample to you after the samples are ready.
Unfortunately I canât take a picture of the installation, because otherwise I would have to dismantle the panel again, but it was connected with so-called âWago clampsâ!
Thanks for this information. May I ask an addtional question? Do this Wago clamps already exist on the vehicle, or if we supply such Power cable, itâs better the Power cable with Wago clamps ? Thanks.
You can buy these Wago clamps at our hardware store in Germany! Some motorhomes already have these, we had to buy them! I still have a picture of the installation! However, Iâm wondering, I had problems with the built-in modem in the router, it was always online and then offline again, an colleague from gl-inet wrote to me, that I an only use the original power supply with 230V, otherwise the router would not working correctly??? Since I installed the beta firmware (Saturday December 30th) I havenât had any more failures!
Thanks. X3000 can connect with the power on vehicle, but need to assure the DC range is 9~36V, while XE3000ďźwith embeded battery ďźonly supports 9~16V. And the maximum power consumption is ~20W, i.e. ~12V/2A.
If you still meet offline issue, we will analyze it. Thanks a lot.
I have connected my X3000 directly to my RV 12v wiring (it is a constant 13.6 volts) and have no issues with connectivity. Itâs been wired this way for a few months now.
I just snipped the cord that came with it and installed spade connectors so that I can easily switch between the wall wart and the hard wired 12v connection if I need to make it portable for any reason.
Modem is always offline, it runs stable for a few days and then it fails, so I always have to unplug the router! Donât any of you have a problem like that? I have O2 Germany as a provider!
I just made a recent order of GL-X3000 and refurbished Beryl from you and they are arriving today and my order number was #EU9826. I wasnât able to register to forum with the same email as I used in the purchase so they are different.
Can you check my address from that order so I donât need to share it publicly?
