Introducing Spitz Plus (GL-X2000) 4G LTE Wi-Fi 6 Router
Okay, I will take option 1 into consideration.
Still option 1 (which I am already using - home made).
For example, my router is right next to its power supply, so I use a 20cm USB cable. For those with a power supply 2 or even 3m away, this is still possible by using a long USB cable.
Why looks like male to male power connector?
at this point 3 will be the first choice, and 1 the second one!
Because the the male barrel connector goes on the Spitz, the male USB-C goes in the Power Supply. Same as the old iPhone cable, from Lightning to USB-C or -A.
I assume you are talking about the variant 3.
Variant 1: Male Barrel, 2 cm flexible cable, female USB-C. Enough for a 90 or 180° setup.
Variant 2: Male Barrel, fix 90° corner, female USB-C. Good for very special setups. Else you will have the cable above the top or nearer the antennas than necessary.
Variant 3: Male barrel, 10 cm flex cable, male USB-C. Short cable, for direct plug into a power supply nearby. I have not seen a lot USB-C extensions.
As everyone with a classic USB-C travel router may have recognized, the power will go down for a moment, if something is connected or disconnected to the Power Supply. This is normal behaviour for PD (Power Delivery).
I was glad to avoid this for my Spitz, and now we are adding this back.. But okay, it is an option.
It's a good length. It's the WITRN brand. I can't find it on Amazon anymore but it's good quality.
Hi will this router load balance sim1 and sim2 to get higher lte speed. When sim1 i have 20mb download and sim2 50mb download
No. Only 1 SIM can be active at a given time.
Power Adapter Cable -Type-C PD to DC 5.5mm x 2.5mm (65W Max)
Compatibility: Spitz Plus (GL-X2000), Spitz AX(GL-X3000)
GL.iNet is about to launch a travel bag specifically designed for the Spitz Plus (GL-X2000) and Spitz AX (GL-X3000). Stay tuned!
Recieved my x2000 today and wanted to install Beta Firmware with eSim support. When uploading the local image i get the error "Cant upload File".
Whats the problem?
Mostly wrong Fileformat.
Mh what should be wrong?
User this .img: GL.iNet download center
Edit: As .tar archive upload was working but i get the error:
The firmware is not compatible with this device.
Seems Local Upgrade is broken. Stable releases are getting the same error...
Maybe Uboot will work.
Did you login to the page to upgrade through the cloud platform?
No, no cloud. Direct wired connection.
Uboot flash was working.
Now next issue: Tailscale is not working:
tailscale up
failed to connect to local tailscaled; it doesn't appear to be running (sudo systemctl start tailscaled ?)
Could not found a solution via google so far.
Is it possible to run ‘free’ in the background of the device to see the memory size?
Can I access the device remotely?
When you tell me how to do that? :slight_smile:
Do you have anydesk?
No, but i can install. See PM.
