Yes, but it need more time, which product do you want to use? If you purchase our esim physical sim card, tell me your product type, I will ask our engineers to develop a test firmware for you.
Yes, it support.
Beryl AX, I'm UK based so not likely to see your esim card until 30th September to test in my M2.
It will only work with your esim? Or esim from 5ber or esim.me should work with your app aslo?
Bery AX don't support esim now, we need to upgrade the firmware, for the normal router(without cellular module)+M2, we don't have plan to support esim, I suggest you can buy our cellular router to use esim.
Maybe,but we don't test their sim card, so we do not guarantee compatibility.
For a better experience in the future, we suggest you purchase our esim card on our official website.
I can confirm! Works with esim.me card.
Succesfully downloaded and installed profile.
I needed to connect router to internet other way than gsm modem because without internet profile cannot be downloaded.
App not connecting only to:
LPA:1$consumer.e-sim.global
but connecting to:
esimdownload.eiotclub.com
what this connection is for? Its not done in the app? We are using other service? It is and will be free?...
Yes, the eiotclub service is free, we tests found that some DP+ servers had problems downloading, so we used a proxy server to download esim profile files.
Any news when shipping in Europe will start? My order from 6th of sep is not shipped yet..
The esim card have arrived EU warehouse, we will start to ship today.
Perfect, i can Test the esim in
Mauritius next Week
I think you are going to Mauritius for your holiday. I hope you will have a good holiday with our esim and cellular router.
Thank you very much ![]()
My Travel companion will be the Mudi V2
I tried to upload airalo esim - without success. Tried two times:
Log from lpa:
https://bin.ar-it.pl/log_airalo.txt
After that tried to install this esim successfully on Samsung S24 and works well.
Tried on esim.me card but there is not problem with installation but with downloading profile.
Can you check on your side? You can get one free esim on their website.
Yes, we are checking, if we find the reason, we will give you feedback as soon as possible.
Hi seal, we find the reason, the err message is -5, so it shows you used profile have been downloaded other device, you can't download this esim profile in our device again.
I know how this works. It wasn't downloaded!
I downloaded this profile after unsucessfull download to esim.
what device?
Router: gl-e750v2
@hecatae:
Can you give me link (maybe via pm) where you found on aliexpress possibility to program esim?
Sorry, I don't understand your mean, can you give me more information?
