My new Mudi 7 has serious cellular reconnection and network transition problems.
DEVICE INFORMATION
Model: GL-E5800EU (Mudi 7)
Router firmware: 4.10.0 release5
Modem: Quectel RG650V-EU
Modem firmware: QRM650VEU00ADR02A04G8G_OCPU_RGH_01.005.01.005
Cellular package: gl-sdk4-cellular git-2026.236.25843-46bcc41-1
Operator: Turk Telekom Turkey
PLMN: 28603
APN: internet
Network mode: Auto
3GPP release: R15/R15, confirmed with AT+QNWCFG
SIM: Currently SIM1 only
Band lock: Disabled
Cell/tower lock: Disabled
Operator lock: Disabled
PROBLEM
When the signal becomes weaker or the modem transitions between 5G and 4G, the connection frequently drops.
The modem may go from 5G to 4G, then to 3G or No Service. After this happens, it can take 1–3 minutes to reconnect. Sometimes the GL.iNet interface says that cellular is connected, but there is still no Internet access.
When the modem successfully connects to 5G, it reaches approximately 200–250 Mbps. Therefore, the problem is not simply low throughput. The main problem is losing the connection and taking an extremely long time to recover.
The same Turk Telekom SIM works normally in my smartphone. In the same locations, my smartphone and Xiaomi 5G CPE Pro remain connected. They may lose speed when the signal becomes weaker, but they do not normally lose Internet access for several minutes.
I also tested Vodafone. Vodafone generally recovered faster than Turk Telekom in the Mudi 7, although it also experienced a “connected but no Internet” condition at least once.
STEPS ALREADY COMPLETED
- Installed the latest stable 4.10.0 firmware
- Performed a factory reset
- Did not restore an old configuration
- Tested both SIM slots
- Tested the SIM in other devices
- Tested R15 instead of R17
- Tested Auto, LTE and 5G network modes
- Disabled all band, operator and cell/tower locks
- Confirmed the APN is correct
The same problem occurred immediately after the factory reset, before changing any connection-detection timings.
LOGGED FAILURE
I captured one complete failure in the system logs:
08:21:24 – Cellular interface went offline
08:21:29 – Cellular Manager attempted to redial
08:21:37 – The first redial failed with CallendCode=202
08:22:54 – Cellular Manager finally attempted another redial
08:22:55 – The redial succeeded
08:23:07 – The interface was reported online again
There was approximately a 76-second delay between the failed first redial and the next attempt. The total Internet outage was approximately 103 seconds.
This long retry delay matches the 1–3 minute outages I experience during normal mobile use.
SIMILAR REPORTS
QUESTIONS FOR GL.INET
- Is the failed redial with CallendCode=202 a known issue?
- Why does Cellular Manager wait approximately 76 seconds before retrying?
- Is there a newer gl-sdk4-cellular package than git-2026.236.25843-46bcc41-1?
- Is there a newer Quectel RG650V-EU modem firmware available?
- Can GL.iNet provide a test/hotfix package for this issue?
- Can GL.iNet inspect the device through GoodCloud?
- If no software fix is currently available, should this unit be replaced or returned?
Please note that factory reset, updating to the latest firmware, changing SIM slots and using R15 have already been tested. The issue still occurs.
This is a mobile router, so losing Internet access for several minutes during normal cell or signal transitions makes the device unreliable for its intended use.
Thank you.
