New firmware version 4.7 being released for beta testing
uboot debricked... I would probably take this firmware off stable and let it be tested a little bit more.
/cc: @alzhao , @bruce
Which router?
Flint 2 , sorry. I updated my first post.
:+1: No worries!
The other thing I just realized I had upgraded to 4.7 beta a few weeks ago and there were some issues and I rolled back to the previous version. It's possible I had some left over software causing issues during latest upgrade.
if downgrade the firmware, it does not recommend to 'keep settings' to.
I think this was probably the issue for me as I probably had kept the settings during downgrade.
When will there be a firmware update for ax1800?
So I guess the trusty A1300 is just being dropped given the latest firmware is 4.5.19. Pretty disappointing that you seem to churn out new products left right and center instead of supporting the entire line with updates.
Marble B3000 is also on 4.5.19, we were promised a 4.7 beta in a week's time just over 7 days ago, but still nothing.
A1300 Slate Plus has not been dropped.
Does the 4.7 included the fixes that 4.6.10 have? For MT2500
@bruce
When 4.7 is finally released, will it be a simple single-click upgrade from 4.6.8? I hate to think I would have to clear settings first!
Thanks
Mostly yes, if you did not any additional configurations using SSH or luci.
When its available 4.7 firmware on Flint and Slate AX as well? It's taken very long.........to appear in the download page :thinking:
I have done some via Luci. Will these need to be deleted and re-keyed when upgrading?
Depends on what you did. Custom modifications might break, depends.
Ok, understood. Bruce sent me some CLI commands to create two new WiFi ssids with WAN access only using different subnets on 2.4 and 5g. Otherwise, I segregated 2 x LAN ports out to be dedicated ports WAN only for xbox and a VOIP telephone. Oh, and SQM but that should be OK. It was the commands that Bruce sent me that I don't know about.
Create an backup using luci before, do the update and if it does not work and you can't get it back working, revert to old firmware and reload the backup.
OK, will try that.
What's the current expectations on a release date for 4.7 given it's been in the wild for a little while now?!!
What does the issue you mean? I will check it out.
