New firmware version 4.7 being released for beta testing
@alzhao, a plea to add or integrate PureVPN like others ?
Yeah, much better than GL mobile app . But I noticed there PIA VPN on mobile has different config wireguard than GL page.
So is the 4.7.0 beta for MT2500 a new version as it states a release date of 18th October 2024, but is still version 4.7.0
https://dl.gl-inet.com/router/mt2500/beta
Seeing as this thread started in September so is it new or not?
@alzhao other request to allow auto connect between selected vpn profiles if anyone get downs. For example 1 have 3 vpns profile configured the first one should always be used even if the other two are available to connect and if the 1 profile connection goes down the next prefered profile i.e. 2 sould be used and in meanwhile if the 1 profile server is back online then it should be connect back the 1 profile.
Connecticity should be check with tcp or udp connect
Not icmp. This will be more accurate when using dynamic dns.
This would be awesome for wireguard.
4.7 beta4 on mt6000
Been having very full logs since moving to the latest beta.
This has been flooding my logs sometimes upwards of 2000 times a second. Google searches haven't turned up much and I'd really like to figure out whats happening there
[376830.805281] Unknown case of dp, iif=b --> rax0
[376830.809919] Unknown case of dp, iif=b --> rax0
[376831.185819] Unknown case of dp, iif=b --> rax0
[376831.190422] Unknown case of dp, iif=b --> rax0
[376831.195287] Unknown case of dp, iif=b --> rax0
[376831.199942] Unknown case of dp, iif=b --> rax0
[376831.204594] Unknown case of dp, iif=b --> rax0
[376831.209251] Unknown case of dp, iif=b --> rax0
[376835.920312] skb_to_hnat_info: 107 callbacks suppressed
[376835.925542] Unknown case of dp, iif=b --> rax0
[376835.930082] Unknown case of dp, iif=b --> rax0
[376835.934839] Unknown case of dp, iif=b --> rax0
[376835.939400] Unknown case of dp, iif=b --> rax0
[376836.287688] Unknown case of dp, iif=b --> rax0
[376836.292283] Unknown case of dp, iif=b --> rax0
[376836.297525] Unknown case of dp, iif=b --> rax0
[376836.302181] Unknown case of dp, iif=b --> rax0
[376836.306843] Unknown case of dp, iif=b --> rax0
[376836.311497] Unknown case of dp, iif=b --> rax0
[376841.016450] skb_to_hnat_info: 146 callbacks suppressed
[376841.021681] Unknown case of dp, iif=b --> rax0
[376841.026484] Unknown case of dp, iif=b --> rax0
[376841.031067] Unknown case of dp, iif=b --> rax0
[376841.035656] Unknown case of dp, iif=b --> rax0
[376841.040187] Unknown case of dp, iif=b --> rax0
[376841.394641] Unknown case of dp, iif=b --> rax0
[376841.399241] Unknown case of dp, iif=b --> rax0
[376841.404337] Unknown case of dp, iif=b --> rax0
[376841.408878] Unknown case of dp, iif=b --> rax0
[376841.413551] Unknown case of dp, iif=b --> rax0
[376873.434619] skb_to_hnat_info: 7 callbacks suppressed
[376873.439675] Unknown case of dp, iif=b --> rax0
[376874.634688] Unknown case of dp, iif=b --> rax0
[376874.639230] Unknown case of dp, iif=b --> rax0
[376874.643757] Unknown case of dp, iif=b --> rax0
[376874.648281] Unknown case of dp, iif=b --> rax0
[376874.652805] Unknown case of dp, iif=b --> rax0
[376874.657330] Unknown case of dp, iif=b --> rax0
[376874.661854] Unknown case of dp, iif=b --> rax0
[376874.666377] Unknown case of dp, iif=b --> rax0
[376874.670902] Unknown case of dp, iif=b --> rax0
[376882.783720] skb_to_hnat_info: 119 callbacks suppressed
[376882.788947] Unknown case of dp, iif=b --> rax0
[376882.793475] Unknown case of dp, iif=b --> rax0
[376882.797999] Unknown case of dp, iif=b --> rax0
[376882.802525] Unknown case of dp, iif=b --> rax0
[376882.807147] Unknown case of dp, iif=b --> rax0
[376882.811681] Unknown case of dp, iif=b --> rax0
[376882.816211] Unknown case of dp, iif=b --> rax0
[376882.820740] Unknown case of dp, iif=b --> rax0
[376882.825271] Unknown case of dp, iif=b --> rax0
[376882.829798] Unknown case of dp, iif=b --> rax0
[376893.684302] skb_to_hnat_info: 270 callbacks suppressed
[376893.689530] Unknown case of dp, iif=b --> rax0
[376895.144345] Unknown case of dp, iif=b --> rax0
[376895.148890] Unknown case of dp, iif=b --> rax0
[376895.153415] Unknown case of dp, iif=b --> rax0
[376895.157940] Unknown case of dp, iif=b --> rax0
[376895.162464] Unknown case of dp, iif=b --> rax0
[376895.166989] Unknown case of dp, iif=b --> rax0
[376895.171513] Unknown case of dp, iif=b --> rax0
[376895.176037] Unknown case of dp, iif=b --> rax0
[376895.180561] Unknown case of dp, iif=b --> rax0
[377011.158293] skb_to_hnat_info: 115 callbacks suppressed
[377011.163519] Unknown case of dp, iif=b --> rax0
[377011.168048] Unknown case of dp, iif=b --> rax0
[377011.172571] Unknown case of dp, iif=b --> rax0
[377011.177094] Unknown case of dp, iif=b --> rax0
[377011.181616] Unknown case of dp, iif=b --> rax0
[377011.186138] Unknown case of dp, iif=b --> rax0
[377011.190659] Unknown case of dp, iif=b --> rax0
[377011.195180] Unknown case of dp, iif=b --> rax0
[377011.199702] Unknown case of dp, iif=b --> rax0
[377011.204224] Unknown case of dp, iif=b --> rax0
[377035.598452] skb_to_hnat_info: 299 callbacks suppressed
[377035.603686] Unknown case of dp, iif=b --> rax0
[377035.608230] Unknown case of dp, iif=b --> rax0
[377035.612763] Unknown case of dp, iif=b --> rax0
[377035.617300] Unknown case of dp, iif=b --> rax0
[377035.621828] Unknown case of dp, iif=b --> rax0
[377035.626354] Unknown case of dp, iif=b --> rax0
[377035.630880] Unknown case of dp, iif=b --> rax0
[377035.635405] Unknown case of dp, iif=b --> rax0
[377035.639929] Unknown case of dp, iif=b --> rax0
[377035.644456] Unknown case of dp, iif=b --> rax0
[377314.896043] skb_to_hnat_info: 1402 callbacks suppressed
[377314.901357] Unknown case of dp, iif=b --> rax0
[377314.905888] Unknown case of dp, iif=b --> rax0
[377314.910410] Unknown case of dp, iif=b --> rax0
[377315.543181] Unknown case of dp, iif=b --> rax0
[377315.547721] Unknown case of dp, iif=b --> rax0
[377315.552246] Unknown case of dp, iif=b --> rax0
[377315.556769] Unknown case of dp, iif=b --> rax0
[377315.561294] Unknown case of dp, iif=b --> rax0
[377315.565815] Unknown case of dp, iif=b --> rax0
[377315.570338] Unknown case of dp, iif=b --> rax0
[377506.642402] skb_to_hnat_info: 17 callbacks suppressed
[377506.647543] Unknown case of dp, iif=b --> rax0
[377509.381624] Unknown case of dp, iif=b --> rax0
[377509.386165] Unknown case of dp, iif=b --> rax0
[377509.390690] Unknown case of dp, iif=b --> rax0
[377509.395214] Unknown case of dp, iif=b --> rax0
[377509.399739] Unknown case of dp, iif=b --> rax0
[377509.404263] Unknown case of dp, iif=b --> rax0
[377509.408788] Unknown case of dp, iif=b --> rax0
[377509.413313] Unknown case of dp, iif=b --> rax0
[377509.417839] Unknown case of dp, iif=b --> rax0
[377819.314264] skb_to_hnat_info: 10 callbacks suppressed
[377819.314268] Unknown case of dp, iif=b --> rax0
[377819.324007] Unknown case of dp, iif=b --> rax0
[377819.353580] Unknown case of dp, iif=b --> rax0
[377819.358123] Unknown case of dp, iif=b --> rax0
[377819.362702] Unknown case of dp, iif=b --> rax0
[377819.367241] Unknown case of dp, iif=b --> rax0
[377819.371777] Unknown case of dp, iif=b --> rax0
[377819.376313] Unknown case of dp, iif=b --> rax0
[377819.650660] Unknown case of dp, iif=b --> rax0
[377819.655211] Unknown case of dp, iif=b --> rax0
[377824.370833] skb_to_hnat_info: 115 callbacks suppressed
[377824.376060] Unknown case of dp, iif=b --> rax0
[377824.380594] Unknown case of dp, iif=b --> rax0
[377824.512642] Unknown case of dp, iif=b --> rax0
[377824.537301] Unknown case of dp, iif=b --> rax0
[377824.541831] Unknown case of dp, iif=b --> rax0
[377824.546370] Unknown case of dp, iif=b --> rax0
[377824.661782] Unknown case of dp, iif=b --> rax0
[377824.681139] Unknown case of dp, iif=b --> rax0
[377826.563032] Unknown case of dp, iif=b --> rax0
[377826.567572] Unknown case of dp, iif=b --> rax0
[377838.127202] skb_to_hnat_info: 4 callbacks suppressed
[377838.132255] Unknown case of dp, iif=b --> rax0
[377838.230876] Unknown case of dp, iif=b --> rax0
[377838.253533] Unknown case of dp, iif=b --> rax0
[377838.258073] Unknown case of dp, iif=b --> rax0
[377838.343956] Unknown case of dp, iif=b --> rax0
[377838.368564] Unknown case of dp, iif=b --> rax0
[377838.373102] Unknown case of dp, iif=b --> rax0
[377838.377637] Unknown case of dp, iif=b --> rax0
[377838.446219] Unknown case of dp, iif=b --> rax0
[377838.471406] Unknown case of dp, iif=b --> rax0
[377844.235691] skb_to_hnat_info: 5 callbacks suppressed
[377844.240749] Unknown case of dp, iif=b --> rax0
[377844.245276] Unknown case of dp, iif=b --> rax0
[377844.318088] Unknown case of dp, iif=b --> rax0
[377844.387037] Unknown case of dp, iif=b --> rax0
[377844.410251] Unknown case of dp, iif=b --> rax0
[377844.414784] Unknown case of dp, iif=b --> rax0
[377844.419326] Unknown case of dp, iif=b --> rax0
[377844.423858] Unknown case of dp, iif=b --> rax0
[377844.565942] Unknown case of dp, iif=b --> rax0
[377844.589646] Unknown case of dp, iif=b --> rax0
[377854.538314] skb_to_hnat_info: 17 callbacks suppressed
[377854.543456] Unknown case of dp, iif=b --> rax0
[377854.601943] Unknown case of dp, iif=b --> rax0
[377854.630168] Unknown case of dp, iif=b --> rax0
[377854.634697] Unknown case of dp, iif=b --> rax0
[377854.639222] Unknown case of dp, iif=b --> rax0
[377854.643750] Unknown case of dp, iif=b --> rax0
[377854.648279] Unknown case of dp, iif=b --> rax0
[377855.462996] Unknown case of dp, iif=b --> rax0
[377855.483316] Unknown case of dp, iif=b --> rax0
[377855.487873] Unknown case of dp, iif=b --> rax0
[377859.553351] skb_to_hnat_info: 11 callbacks suppressed
[377859.553355] Unknown case of dp, iif=b --> rax0
[377859.574214] Unknown case of dp, iif=b --> rax0
[377861.479257] Unknown case of dp, iif=b --> rax0
[377861.579218] Unknown case of dp, iif=b --> rax0
[377861.603737] Unknown case of dp, iif=b --> rax0
[377861.608293] Unknown case of dp, iif=b --> rax0
[377863.414746] Unknown case of dp, iif=b --> rax0
[377863.419287] Unknown case of dp, iif=b --> rax0
[377863.531697] Unknown case of dp, iif=b --> rax0
[377863.554975] Unknown case of dp, iif=b --> rax0
[377865.370272] skb_to_hnat_info: 5 callbacks suppressed
[377865.375326] Unknown case of dp, iif=b --> rax0
[377865.515157] Unknown case of dp, iif=b --> rax0
[377865.536593] Unknown case of dp, iif=b --> rax0
[377865.541121] Unknown case of dp, iif=b --> rax0
[377865.545659] Unknown case of dp, iif=b --> rax0
[377866.452655] Unknown case of dp, iif=b --> rax0
[377866.457228] Unknown case of dp, iif=b --> rax0
[377866.526285] Unknown case of dp, iif=b --> rax0
[377866.550047] Unknown case of dp, iif=b --> rax0
[377866.554574] Unknown case of dp, iif=b --> rax0
[377870.629455] skb_to_hnat_info: 12 callbacks suppressed
[377870.634595] Unknown case of dp, iif=b --> rax0
[377871.573616] Unknown case of dp, iif=b --> rax0
[377871.578162] Unknown case of dp, iif=b --> rax0
[377871.582693] Unknown case of dp, iif=b --> rax0
[377871.667672] Unknown case of dp, iif=b --> rax0
[377871.672227] Unknown case of dp, iif=b --> rax0
[377871.676755] Unknown case of dp, iif=b --> rax0
[377872.480244] Unknown case of dp, iif=b --> rax0
[377872.484789] Unknown case of dp, iif=b --> rax0
[377872.489320] Unknown case of dp, iif=b --> rax0
[377885.173525] skb_to_hnat_info: 9 callbacks suppressed
[377885.178579] Unknown case of dp, iif=b --> rax0
[377885.183106] Unknown case of dp, iif=b --> rax0
[377885.227087] Unknown case of dp, iif=b --> rax0
[377885.231625] Unknown case of dp, iif=b --> rax0
[377885.367840] Unknown case of dp, iif=b --> rax0
[377885.372375] Unknown case of dp, iif=b --> rax0
[377885.451264] Unknown case of dp, iif=b --> rax0
[377885.455822] Unknown case of dp, iif=b --> rax0
[377885.460369] Unknown case of dp, iif=b --> rax0
[377885.464902] Unknown case of dp, iif=b --> rax0
[378006.425429] skb_to_hnat_info: 204 callbacks suppressed
[378006.425432] Unknown case of dp, iif=b --> rax0
[378006.435220] Unknown case of dp, iif=b --> rax0
[378006.439752] Unknown case of dp, iif=b --> rax0
[378006.444282] Unknown case of dp, iif=b --> rax0
[378006.448809] Unknown case of dp, iif=b --> rax0
[378006.453366] Unknown case of dp, iif=b --> rax0
[378006.457894] Unknown case of dp, iif=b --> rax0
[378006.473018] Unknown case of dp, iif=b --> rax0
[378006.477565] Unknown case of dp, iif=b --> rax0
[378006.482093] Unknown case of dp, iif=b --> rax0
[378173.604039] skb_to_hnat_info: 1740 callbacks suppressed
[378173.609358] Unknown case of dp, iif=9 --> rax0
[378173.613890] Unknown case of dp, iif=9 --> rax0
[378173.618415] Unknown case of dp, iif=9 --> rax0
[378173.622939] Unknown case of dp, iif=9 --> rax0
[378173.627462] Unknown case of dp, iif=9 --> rax0
[378173.639630] Unknown case of dp, iif=9 --> rax0
[378173.644185] Unknown case of dp, iif=9 --> rax0
[378173.648707] Unknown case of dp, iif=9 --> rax0
[378173.653229] Unknown case of dp, iif=9 --> rax0
[378173.671681] Unknown case of dp, iif=9 --> rax0
[378181.054437] skb_to_hnat_info: 34 callbacks suppressed
[378181.059575] Unknown case of dp, iif=9 --> rax0
[378181.064104] Unknown case of dp, iif=9 --> rax0
[378181.068630] Unknown case of dp, iif=9 --> rax0
[378181.073159] Unknown case of dp, iif=9 --> rax0
[378181.099567] Unknown case of dp, iif=9 --> rax0
[378181.140925] Unknown case of dp, iif=9 --> rax0
[378181.160005] Unknown case of dp, iif=9 --> rax0
[378181.200565] Unknown case of dp, iif=9 --> rax0
[378181.205096] Unknown case of dp, iif=9 --> rax0
[378181.229344] Unknown case of dp, iif=9 --> rax0
[378237.855780] skb_to_hnat_info: 4 callbacks suppressed
[378237.860835] Unknown case of dp, iif=b --> rax0
[378237.865367] Unknown case of dp, iif=b --> rax0
[378237.869892] Unknown case of dp, iif=b --> rax0
[378237.874417] Unknown case of dp, iif=b --> rax0
[378237.878940] Unknown case of dp, iif=b --> rax0
[378237.883464] Unknown case of dp, iif=b --> rax0
[378237.887989] Unknown case of dp, iif=b --> rax0
[378237.905711] Unknown case of dp, iif=b --> rax0
[378237.915111] Unknown case of dp, iif=b --> rax0
[378237.918743] Unknown case of dp, iif=b --> rax0
[378243.533019] skb_to_hnat_info: 1499 callbacks suppressed
[378243.538333] Unknown case of dp, iif=b --> rax0
[378243.542922] Unknown case of dp, iif=b --> rax0
[378243.547462] Unknown case of dp, iif=b --> rax0
[378243.551998] Unknown case of dp, iif=b --> rax0
[378243.556528] Unknown case of dp, iif=b --> rax0
[378243.561056] Unknown case of dp, iif=b --> rax0
[378243.565583] Unknown case of dp, iif=b --> rax0
[378248.817517] Unknown case of dp, iif=b --> rax0
[378248.822058] Unknown case of dp, iif=b --> rax0
[378248.826585] Unknown case of dp, iif=b --> rax0
[378248.864147] Unknown case of dp, iif=b --> rax0
[378248.872918] Unknown case of dp, iif=b --> rax0
[378248.877448] Unknown case of dp, iif=b --> rax0
[378248.882000] Unknown case of dp, iif=b --> rax0
[378248.886530] Unknown case of dp, iif=b --> rax0
[378248.891056] Unknown case of dp, iif=b --> rax0
[378248.895581] Unknown case of dp, iif=b --> rax0
[378255.135635] skb_to_hnat_info: 29 callbacks suppressed
[378255.135639] Unknown case of dp, iif=b --> rax0
[378255.145328] Unknown case of dp, iif=b --> rax0
[378255.149859] Unknown case of dp, iif=b --> rax0
[378255.154396] Unknown case of dp, iif=b --> rax0
[378255.158932] Unknown case of dp, iif=b --> rax0
[378255.163460] Unknown case of dp, iif=b --> rax0
[378255.167988] Unknown case of dp, iif=b --> rax0
[378255.172514] Unknown case of dp, iif=b --> rax0
[378255.177042] Unknown case of dp, iif=b --> rax0
[378255.181567] Unknown case of dp, iif=b --> rax0
[378264.247524] skb_to_hnat_info: 67 callbacks suppressed
[378264.247528] Unknown case of dp, iif=b --> rax0
[378264.257327] Unknown case of dp, iif=b --> rax0
[378264.261878] Unknown case of dp, iif=b --> rax0
[378264.266428] Unknown case of dp, iif=b --> rax0
[378264.270976] Unknown case of dp, iif=b --> rax0
[378264.275521] Unknown case of dp, iif=b --> rax0
[378264.280066] Unknown case of dp, iif=b --> rax0
[378264.284616] Unknown case of dp, iif=b --> rax0
[378264.289161] Unknown case of dp, iif=b --> rax0
[378264.293857] Unknown case of dp, iif=b --> rax0
[378269.592561] skb_to_hnat_info: 164 callbacks suppressed
[378269.597791] Unknown case of dp, iif=b --> rax0
[378269.602772] Unknown case of dp, iif=b --> rax0
[378269.607320] Unknown case of dp, iif=b --> rax0
[378269.612003] Unknown case of dp, iif=b --> rax0
[378269.616655] Unknown case of dp, iif=b --> rax0
[378269.621289] Unknown case of dp, iif=b --> rax0
[378269.625919] Unknown case of dp, iif=b --> rax0
[378269.630459] Unknown case of dp, iif=b --> rax0
[378270.036257] Unknown case of dp, iif=b --> rax0
[378270.041082] Unknown case of dp, iif=b --> rax0
[378274.744250] skb_to_hnat_info: 139 callbacks suppressed
[378274.749478] Unknown case of dp, iif=b --> rax0
[378274.754631] Unknown case of dp, iif=b --> rax0
[378274.759265] Unknown case of dp, iif=b --> rax0
[378274.763907] Unknown case of dp, iif=b --> rax0
[378274.768448] Unknown case of dp, iif=b --> rax0
[378274.773082] Unknown case of dp, iif=b --> rax0
[378274.777713] Unknown case of dp, iif=b --> rax0
[378274.782253] Unknown case of dp, iif=b --> rax0
[378274.786896] Unknown case of dp, iif=b --> rax0
[378274.791523] Unknown case of dp, iif=b --> rax0
[378280.100828] skb_to_hnat_info: 169 callbacks suppressed
[378280.106057] Unknown case of dp, iif=b --> rax0
[378280.111054] Unknown case of dp, iif=b --> rax0
[378280.115609] Unknown case of dp, iif=b --> rax0
[378280.120286] Unknown case of dp, iif=b --> rax0
[378280.124932] Unknown case of dp, iif=b --> rax0
[378280.129573] Unknown case of dp, iif=b --> rax0
[378280.134218] Unknown case of dp, iif=b --> rax0
[378280.138861] Unknown case of dp, iif=b --> rax0
[378280.143495] Unknown case of dp, iif=b --> rax0
[378280.148164] Unknown case of dp, iif=b --> rax0
[378285.102782] skb_to_hnat_info: 1129 callbacks suppressed
[378285.108096] Unknown case of dp, iif=9 --> rax0
[378285.112621] Unknown case of dp, iif=9 --> rax0
[378285.117144] Unknown case of dp, iif=9 --> rax0
[378285.121667] Unknown case of dp, iif=9 --> rax0
[378285.126189] Unknown case of dp, iif=9 --> rax0
[378285.130711] Unknown case of dp, iif=9 --> rax0
[378285.135233] Unknown case of dp, iif=9 --> rax0
[378285.139755] Unknown case of dp, iif=9 --> rax0
[378285.144277] Unknown case of dp, iif=9 --> rax0
[378285.148799] Unknown case of dp, iif=9 --> rax0
[378311.180476] skb_to_hnat_info: 5079 callbacks suppressed
hoping this releases soon, want to do a fresh install from 4.6.2 and get up to date! can't wait for that new port management page which I think is included
Installed beta 4.7.1 on GL-X3000 yesterday.
So far so good.
Solid cellular connection now.
Just updated available plugins.
Will restart router tonight.
beta-4.7-upgrade
I can only warn, like always: Don't do this.
can you explain why not?
Oh yea, upgrading packages to newest version can have api breaking changes, i wouldn't do that too lol
You are correct.
I have been locked out of the router.
I still have internet access.
The device doesnt show in the GoodCloud Cloud Management.
However the activity log show that the router is connected.
This is the activity log.
GL.iNet-activity-log.xlsx.zip (6.7 KB)
My VPN still works.
I can access the router from the WinScp software.
Any idea how I can fix this?
Reset the firmware.
And don't do plugin-upgrades. Never, ever.
You can fix it by reflashing the firmware through UBoot.
Yes, I know that.
However seeing, that the only problem is that I am locked out, I am hoping for a GL-inet Tech to find a soloution that doesnt require me resetting everything.
It's been a fortnight since the Brume 2 release date of 18th October 4.7.0 and there's still no information if this fixes any bugs from the previous 4.7.0 firmware for the Brume 2.
I can't beta test Astrowarp while there's no information coming forward on the MT2500 beta firmware.
Really disappointed with this.
You upgraded the lua-eco packages - they will break the current GUI.
No chance of any other solution than resetting the device, I am sorry.
Ok.
So going forward, this package should not be included to be updated.
No, going forward: Don't update packages manually.
In the end, it's your decision. I can only advise against it. But since I'm not a GL.iNet employee, you don't have to listen to me :slight_smile:
