I would really like it to be updated first.
The build he offered you it's already 25.12.5 if that it's too "outdated" for you I don't know what to tell you ![]()
Maybe you should stay on vanilla openwrt ![]()
There are a lot of changes per [OpenWrt Wiki] OpenWrt 25.12.6 - Service Release - 18. October 2026. It's really worthy for the team to update from 25.12.5.
Device fixes
- ath79: GL.iNet GL-E750 (Mudi) V2 - fix the 5 GHz WiFi radio, which did not come up because of missing calibration data
- mediatek: MT7986 - correct the system timer rate, fixing clock drift (e.g. NTP running at the +500 ppm limit on the GL.iNet GL-MT6000)
They going to, but that's why I said you should stay on vanilla openwrt ![]()
I just went vanilla. I wasn't using any features on GLiNet or the GUI.
GLiNet: Thanks for the hardware that works great with OpenWRT
Is a new op25 build coming soon? If not, I think I'll just install the vanilla OpenWRT version tomorrow...
As I did understand from GL.iNet team, 4.11.x-op25 for Flint 2 is already in the works. Unfortunately, they did not give us any ETA. Should be soon if they already started to work on it.
New version is out!
4.11.0-op25-beta1 is now available for download:
Flint 2: mt6000-op-4.11.0-op25_beta1
Beryl AX: mt3000-op-4.11.0-op25_beta1
It's nice to see the following new features available in the 4.11-op25 beta 1 firmware.
- "Network Quantity" function, it even has speed test function built-in.
- The "Security scanning" is also good to have.
- The firmware upgrade now include DPI online upgrade.
- The SQM now have "CAKE autorate"
- DNS is centralized in one place for every kind of connection.
I am exciting to see these new features, well done, thanks! ![]()
Hi, I'm using 4.8.3-op24 on flint2 right now. Is it possible to update to mt6000-op-4.11.0-op25_beta1-1190-1030-1793362458 and keep current settings?
Thank you!
More then recommend is to wipe and set every setting manually again and don't import Luci backup
I thought the Flint 2's OpenWrt 25 firmware (v4.11) would finally bring Mesh support, but unfortunately not... ![]()
I spent about 15 minutes looking for this feature in the new firmware, with no success. Then I went back and carefully reread the changelog... only to realize there was actually no mention of Mesh support at all.
What a disappointment! ![]()
I hope there will be soon a new build with Mesh support.
Would love to update, some brave people who already have: i would like to hear if its worth updating and stable so far.
I'll let you know how it goes. I am gonna update now, because it's the best chance to mitigate this remote code execution exploit (assuming GL-iNet updates as soon as the OpenWrt fix is out, and if not, this is the final straw that will make me switch to vanilla OpenWrt firmware instead).
- Alright, the update is fully installed and configured!
- Model: GL-MT6000 Flint 2.
- My old firmware before the upgrade was "Stable" v4.11.0 (released 2026-09-28).
- I am now on "OpenWrt 25" v4.11.0-op25 (released 2026-11-02).
- Did a clean install without keeping configs, and just got done setting everything up in detail.
- There were no UI issues with the GL-iNet frontend or with LuCI.
- The system logs don't show any serious-looking errors (just general small stuff which looks like it's probably normal).
- The ancient "stable" firmware uses Mediatek closed-source WiFi drivers, whereas the "op25" uses open-source WiFi drivers which some people have had issues with in the past.
- WiFi is stable so far. My download speed increased from 233 MiB (closed-source stable) to 246 MiB/s (open-source op25). Verified on 3 different speedtest sites with multiple servers near me. Sidenote: My ISP's official cap is 250 MiB/s but I don't think I've ever reached that.
- I am using lots of Port Forwarding, which was one of the things that people mentioned crashing and freezing the router in the previous OP25 firmware.
- If I get any crashes or disconnections, which the June op25 firmware was famous for in this thread, I'll let you know.
- Note: I don't use the router's VPN features or AdGuard Home (AGH). I use Cloudflare encrypted DNS instead. So I can't test if those features work. I know others had issues with them in the previous firmware.
- Note: I am using Hardware Accelerated routing. No SQM (since it has zero benefit since I never need low latency multiplayer gaming at the exact same time as heavy internet downloads, so I would only lose bandwidth for nothing by using SQM).
- The adventure begins!
I threw together monitoring to let my computer check the connection every 5 seconds (the offline was just me manually disabling my computer WiFi to make sure it works):
[2026-11-03 07:11:44] [INFO] Monitoring started...
[2026-11-03 07:11:44] [INFO] Initial state: OFFLINE
[2026-11-03 07:11:56] [INFO] Connection RESTORED (Online) — Downtime: 12s (12.0s)
[2026-11-03 07:12:16] [WARNING] Connection LOST (Offline)
[2026-11-03 07:13:36] [INFO] Connection RESTORED (Online) — Downtime: 1m 20s (80.0s)
^C[2026-11-03 07:13:40] [INFO] Monitoring stopped by user.
So I'll run this now and will check the logs later to see if there's any router downtime.
I've attached the code here if anyone else wants to monitor their network. Rename to main.py and run with Python.
main.py.txt (3.1 KB)
Hello
Which version of OpenWrt is it—25.12.5 or 25.12.6?
It is version 25.12.6
Pulled the trigger with this firmware, did a "dirty" upgrade on top of 4.9.1-op25 so far everything working without issues would report otherwise ![]()
Did the update from 4.9.1-op25 yesterday (keep settings), been over a day, all seems good.
Is it a good idea to open ports atm with CVE-2026-98432 exploid out there ? I hope gl inet will bring a fw like op25 build with newest Kernel where this has been fixed. I Cant imagine how many Routers are affected
