Security Notice: GoodCloud Remote Management Incident
Could you please share a file with the logs with me?
Would be very helpful for our community tool :slight_smile:
Yep, it’s still working :slight_smile:
Message me with your preferred method to send them.
Thanks admon. :slightly_smiling_face:
just a question, I backup my Spitz AX 2 months ago before the attack, is it wise to update to fresh firmware then restore from old clean backup? with so many devices connnected on my house, HOME AT, solar, CCTV, tvs,etc this is a living hell setting it up all over again, plus I have 3 devices all allegedly affected but no malware found.
what worries me this exploits harvest the data then uninstall and leave no trace, so hard to know what the script of malware actually did? GLinet has still not published how the attack was carried out as most people have goodcloud on 2FA or good password so their servers were compromised and not individual users, yet they havent mentioned a thing. I feel pretty disappointed that users of this community are coming to rescue while GLinet does what? reeps the rewards of someone fixing their systems? anyoe that contributed to that should recive free routers and equpiment as a good gesture from GLInet!
Unfortunately the safest answer is we don't know and Glinet is unlikely to know for certain either. The Goodcloud vulnerability appears to have been present in firmware versions as far back as 2024. Very few (if any) people have detailed logs going back 2+ years, so it is impossible to say if any devices were infected and then self-cleaned by the malware (as you stated).
What we DO know for certain is that malware implanted on glinet devices was definitely not limited to November 19-21, 2026. Community members have found older/different malware on various devices dated as far back as September 2025 - May 2026.
In short: it is impossible to say what may be in an older backup.
Updated to 4.11.1-op25 from 4.8.3-op24 on MT6000 and MT3000
I never enabled [not so] GoodCloud :rofl:
The community check script did not detect infection, and my Router Guru ChatGPT helped me check the review items that were related to modifications I made
The MT6000 is configured with cellular failover
MT3000 is confgured as a wireless bridge using WDS
Everything is working, including the custom firewall setting to prevent cloud backup over cell if primary WAN failure occurs at night when cloud backup runs to prevent blowing up my "unlimited" cell limit. Ask me why I added that feature :grin:
I performed the updates with Keep Settings
All in a 165 step process guided by ChatGPT, including pre-update preparation incase a factory reset was required and I had to rebuild everything, and a bunch of post-update checks to make sure everything was working
I think this is quite important
Vulnerability reports and remediation coverage
AstroWarp/SD-WAN command injection — GitHub report
Insufficient input validation could allow root command execution on the listed routers, including with AstroWarp disabled.
The report lists model-specific expected fix versions. The download tables above identify published incident security releases; check the exact model and build. The report's planned-version wording alone does not verify every shipped build. This router finding is not a KVM vulnerability claim.
So even if you didn't have Goodcloud enabled and had Astrowarp disabled you still could have been hacked.
Another one: GL-X3000 on 4.7.4. Same family, and it's the 35,745-byte variant, the same size as @acs's X2000 sample. GL's quick check didn't catch it.
**Persistence** (all in the same second, router clock 2025-07-14 02:17:25; the router clock was about 3 months slow, so the real date is probably later)
- `/etc/init.d/urandom_seed`: SHA-256 `3265f27feb954744581cdea2373b88ceae9d85b67e90487353fd48902cf4fc19` (same hash as everyone else's)
- `/bin/ulogd`: 35,745 bytes, SHA-256 `8179d282d69f346595aba9865de32eb76ec832964717b937971a51b74bcb8653` (another new hash at a known size)
- `/lib/upgrade/keep.d/netifd`: adds `/bin/ulogd` and `/etc/init.d/urandom_seed`, so it survives "Keep Settings" upgrades. This confirms @Romer's finding.
- `/etc/config/wireguard_server` was written **10 seconds after** the drop, the same pattern Romer saw. Mine had no peers, so nothing was added, but treat any WireGuard keys on an infected box as copied.
**Running when found:** `monitord` and `/usr/sbin/ujaild`, with `ujaild` running from `/tmp/ujaild (deleted)`. I pulled the binary from `/proc//exe` before killing it. It's static Go aarch64, garble-obfuscated, 6,750,356 bytes, SHA-256 `53736d5db721a358bec5b9ddf6056df73b36fc5330300342c42f866a05191432`. That's **identical to @acs's sample**, so the second stage looks shared across devices while ulogd varies. It had no open sockets when captured.
**Decoded C2 from my ulogd** (no adguardns in this one):
- `cdn.lede-openproject[.]org/v1/gl/access`
- `cdn.adxinsight[.]com/v1/gl/access`
- `cdn.openwrt-project[.]org/v1/gl/access`
The hardcoded ID is `24bdee728cab238310c2e9a29bf4d9cf09c78d38`, which is different from Romer's `83c862…`. The rest matches what's been posted: it reads the device_sn, mac, ddns, model and firmware_type files under `/proc/gl-hw-info/`, runs `uname -m`, checks in with `curl -fsSkL`, sleeps 7200, and decrypts its second stage with `openssl enc -d -aes-256-cbc -pbkdf2`.
**Decoding tip:** in this LNUM build, header byte 11 is sizeof(lua_Integer) = 4, not the integral flag, and type-9 constants are 4-byte ints. Each character is stored as `{value, pos, op, key}`: `add` → value−key, `sub` → value+key, `xor` → value^key. A ~100-line Python parser decodes the strings statically without running anything.
**Tip if you find it:** freeze the processes first (`kill -STOP`), then `cat /proc//exe > /tmp/ujaild.bin`. Once it's killed or the router reboots, the second stage is gone for good.
My other X3000 (4.8.4, rebooted before I checked) showed nothing. Samples have gone to security@gl-inet.com. Reflashing without keeping settings as we speak.
Is it safe to use good cloud again if I reflashed latest fixed firmware of my e5800 mudi7 Router with NO keeping data, changed passwords and Keys and reseted Router once again? Gl-inet wrote they had fixed cloud security Bug, I have read that bad Domain is suspended. I am not sure if it is okay to use good cloud again. I read about Attack is still going on and there is another security Bug in cloud which is not described in detail. At the moment I disconnected my router and switched it off completely but in future I am looking for a possibility for remote Management of it and used good cloud in the past.
Safe
The attacks have ceased and the vulnerability has been patched. GoodCloud and device with latest firmware are currently secure and operating normally.
You can perform a complete scan using the community script. If you encounter any anomalies or have concerns, please report them to support@gl-inet.com.
Just to clear things up, devices that have never GoodCloud enabled are unaffected and have nothing to do with this incident. The current connection between the cloud server and the device is secure.
Thank you for your question.
If it has never connected to GoodCloud, your MT2500 should not be affected by this incident.
Your device's current behavior seems more like it has been bricked for some reason. Please refer to the following tutorial to see if it is helpful:
If you are still having problems and the device is still under warranty, we recommend contacting support@gl-inet.com for after-sales support.
There may be a bit of a misunderstanding here.
As Bruce/the announcement clarified, if GoodCloud is not enabled, the deviees will not be affected by this incident.
The description here means that the vulnerability does not necessarily require AstroWarp to be enabled, but the relevant exploit path still needs to go through the GoodCloud.
Dear GL.iNet, even though it’s no longer supported, I noticed that you’ve updated the AR750 Creta. Thank you very much!
Cross-posting an update from the reddit topic.
Update - Nov 24, 2:57am US CST (not official GL statements)
More findings after looking deeper on the GoodCloud side:
  • The attacker was already testing routers on Nov 19, about a day and a half before the main attack. GoodCloud’s own logs show four devices we looked at answering requests GoodCloud never sent, between 08:48 and 09:34 UTC on the 19th. Then nothing until the main wave started at 20:06 UTC on the 20th. It looks like a trial run on a handful of devices.
  • You can check your own router from your GoodCloud account. No command line needed. Sign in, go to Logs > Device Logs, set the dates to Nov 19 to 21, and click “Details” on the entries. If you see "id":1 in the message, your router was hit.
  • Not seeing it doesn’t mean you’re safe. It only means that record isn’t there.
  • This still works if you’ve already reset or updated the router. The record is kept in the cloud, not on the router.
  • We’ve looked at a cross-section of 260 GoodCloud-attached routers so far, and 210 of them show they were hit this way.
  • Step by step guide to check yours: gl-security-incident-2026/docs/goodcloud-device-log.md at main · RemoteToHome-io/gl-security-incident-2026 · GitHub
For those newly joining the saga: Admon’s community script remains the best automated scanning and detection tool for checking your GL router - start here: Community fix for CSA-2026-01: check a device for the gl-helper malware · gl-i.net (unofficial)
How can I proceed to request GL-iNet to erase my account on Astrowarp/GoodCloud?
You can delete your GoodCloud account yourself. There is an account deletion option in the GoodCloud portal. That's what I did.
More importantly, I would recommend stopping and disabling the GoodCloud services on the router itself, preventing them from starting automatically, and removing the stored cloud token. Deleting your account alone does not necessarily prevent the router from attempting to communicate with GoodCloud servers.
I've done this on both my Flint 2 and Flint 4 and verified that no GoodCloud processes or active MQTT connections remain.
@bruce @will.qiu If people took the above action would that mean DPI / content filter database wouldn't update? I am under the impression that the database updates via GoodCloud even if there is no user account created.
Please delete it from the cloud platform, or send this request to support@gl-inet.com.
