Security Notice: GoodCloud Remote Management Incident
That's a bold statement. You can't know whether it's true. All you can know is that they're safe from the exploits that you're aware of.
DPI database updates will not be affected. DPI enabled does not require a cloud account to be linked.
We can confirm that the vulnerability related to this incident has been patched.
Our R&D team has been working in 24-hour rotational shifts over the past few days to address this.
Finally someone spoke correctly. Community solved, manufacturer watched.
Yes, that's a good approach, but GL-iNet should also have a 24/7 shifts on the security team monitoring the services, not only AFTER the issue was reported.
It seems the malware was there by almost 1 year.
We are investigating this incident.
We can't share any details publicly right now, but we'll release more information as the investigation progresses.
  1. GL-RM1 checked and upgraded. (no evidence of infection)
  2. GoodCloud account deleted. (never bound to device)
  3. GL-RM1 isolated from network.
  4. GL-RM1 placed in incinerator. :fire:
  5. Incident response complete.
using the comunity scipt,its on the ver cautios side and it flags potential changes made by user. In my instance it reports changes in firmware and so on.
running various scripts and without backup i was able to retrive my latest firmware version from router despite the fact it reboots every night so goodcloud logs are gone, but firmware shows identical SHA from may 26 till 22 nov. So no changes.
3. Overall investigation status
Finding
Assessment
Firewall configuration
Identical to July copy
Network configuration
Differences explained
DNS acceptance rules
No malicious instructions identified
WAN isolation script
Single functional modification
Sysupgrade configuration
NAS directory addition
AstroWarp enable settings
Identical to factory
Historical attack indicator
Suspicious, unresolved
Persistent malware
Not detected
Active reverse shell
Not detected
Additional administrator accounts
Not detected
The empty state file remains our only identified indicator of the November attack. Everything else examined so far has either a reasonable explanation or predates the incident.
Considering the evidence across both routers:
  • The Spitz and Flint developed the same empty state file during the reported attack window.
  • AstroWarp is currently disabled, consistent with the factory configuration on the Spitz.
  • Neither of the other SD-WAN state files exists on the Spitz.
  • The filesystem uses noatime.
  • No known persistent malware or active reverse shell has been detected.
  • The historical attack hypothesis is increasingly credible. However, we still cannot determine what command was executed, whether malware was installed, or whether any information was extracted. The access timestamp is not guaranteed to represent creation time.
BusyBox integrity check passed. Both SHA-256 hashes are identical.
This confirms that the flagged /usr/bin/login symbolic link points to an unmodified BusyBox binary.
Additionally, the symbolic link's timestamp is 19 June 2026, approximately five months before the reported attack. Its original purpose remains unverified, but we have no evidence linking it to the November incident.
The Samba4 startup script is 593 bytes larger than the factory version.
Property
Factory
Current
File size
7,996 bytes
8,589 bytes
Permissions
755
755
Owner
root
root
Modified
6 Nov 2025
21 June 2026
SHA-256
Different
Different
The modification predates the November attack by five months. Interestingly, its timestamp matches the modification of /etc/sysupgrade.conf, where we identified the additional GL.iNet NAS directory. This suggests a possible connection to a NAS package update, but we need to verify the actual changes.
We have now examined every flagged REVIEW item individually rather than relying solely on the scanner's automated verdict.
There is no additional evidence of a surviving malicious installation on your Spitz AX. That is encouraging, but it does not establish that the router was never compromised.
Given your preference to retain your extensive router configuration, I would now proceed with the following sequence:
  1. Download a fresh configuration backup and retain it offline.
  2. Install the official security-patched firmware with Keep Settings enabled.
  3. Run the latest triage scanner again using --check --no-report.
  4. Compare the new findings against our existing investigation.
  5. Keep GoodCloud disabled.
  6. A keep-settings upgrade is a reasonable intermediate recovery step given our findings, but a clean reflash without restoring potentially compromised settings remains the higher-assurance option.
Unfortunately you are correct that "devices with latest firmware are currently secure and operating normally" is not an accurate statement, especially if you "keep settings" when upgrading firmware as Glinet has told people is fine to do. Researchers and users have found an older strain of malware on devices dating as far back as September 2025 that the new firmware does not completely eradicate, and per @rthco:
"The firmware update does not clear it if you keep settings. In our test the security firmware put urandom_seed back but left /bin/ulogd, because the backdoor adds itself to the list of files kept across upgrades. Reinstall without keeping settings and do not restore a backup from that router.
Loader, with a decoder: gl-security-incident-2026/docs/older-backdoor-loader.md at main · RemoteToHome-io/gl-security-incident-2026 · GitHub
Second stage, with detection rules: gl-security-incident-2026/docs/older-backdoor-second-stage.md at main · RemoteToHome-io/gl-security-incident-2026 · GitHub
Servers: gl-security-incident-2026/docs/attacker-infrastructure.md at main · RemoteToHome-io/gl-security-incident-2026 · GitHub
Everything else: GitHub - RemoteToHome-io/gl-security-incident-2026: Coordinated findings on the GL.iNet cloud remote-management incident of November 2026: what is known, how to check a device, how to recover · GitHub "
We received this question. Already under investigation.
The issue within the scope of the recent official announcement has been resolved in this firmware update. There is a CVE in the follow-up to distinguish the incident.
For non experts like me who have tried to follow the situation closely since Friday, a few questions:
Before rebooting my router this weekend, I ran the community script, which found no malware but reported an IOC on the basis of some recorded login activity that took place during a brief time window late on Friday and early Saturday UTC. First question: Is it fully clear that logins during this period were done by the attacker? Is it known whether the gl-inet response team could have used their GoodCloud access to scan routers in order to get an understanding of the scale of the situation? A yes/no statement from the manufacturer may help our understanding of this.
Second question: Given that no malware has been found in all runs of the community tool in my case, including after installing the security firmware update (with saved settings, necessarily for now, but rotated admin credentials and VPN keys), can the remaining risk be quantified? In other words, until I can do a factory reset, is there some assurance that the community tool could detect any infected files from the known malware, should any of these survive the update?
But I thought the database updates pushed via a goodcloud backend, regardless if the user has an account or not (hence the question if a user was to stop GoodCloud service running locally would it stop updating). How are the DPI / content filter definitions updates pushed to end users?
It is currently unknown if Glinet themselves used the same vector that the attackers used in order to push remote cleanup commands to devices. RemoteToHome found evidence of 3 different cleanup commands run on various devices that indicate someone was trying to terminate the malware running on various models of devices. It is not known if the attacker was attempting to clean up their own malware, or if someone at Glinet remotely sent some of these commands to devices in order to try and contain the attack.
C5, C6, and C7 as documented here: gl-security-incident-2026/docs/attacker-messages.md at main · RemoteToHome-io/gl-security-incident-2026 · GitHub
Answer to second question: The community script has been updated several times per day over the past few days as new indicators of compromise have been identified. At the moment Admon's community script provides very comprehensive checks for all of the known malware variants that have been identified. Currently only the older backdoor malware that dates back to 2025 has shown it can survive an update with "keep settings" turned on. Admon's community script finds and repots on this.
It's hard to quantify your remaining risk, because the attackers had root access to devices and although Glinet and the community have identified several malware variants, it is impossible to say for certain exactly what the attacker did on any specific device after you have upgraded the firmware and rebooted the device. If you are unable to do a clean factory reset without keeping settings due to not having physical access to the device, it sounds like you have taken all the steps you can take at this moment and based on all of the information currently known your risk is relatively low. I recommend monitoring the situation. Check for updates to Admon's script on an ongoing basis and run the checks again as new updates are published.
Thanks so much @rdizzie -- this is most helpful in getting an overall grasp of the situation.
It has been a drip by drip experience from GL-iNet. Now 4.8.5 have been released with another security fix . How many more? It is a nightmare to setup the router again and again (Spitz-AX3000). What is worrying is users dont know the extent. On top of it, no updates were provided on this device for over a year from 4.8.3. There are bugs as well on the old openwrt branch(21.02) and mediaTek was not asked/forced to upgrade/fix it. And then there is worse communication-when push came to shove, you were forced security fixes. Very poor support provided for this router to be honest.
Thank you for pointing that out, I had not noticed the new firmware published today yet.
IMPORTANT: Glinet just released another new firmware update for various models. Depending on model it appears to address different vulnerabilities, including remediation of another potential shell injection attack. Firmware updates may address one or more of the following depending on the model:
  • Fixed vulnerability vdb-submit-1112986 and hardened rtty security.
  • Fixed vulnerability vdb-submit-1112997 by adding configuration and parameter validation to prevent shell injection attacks.
  • Fixed vulnerability VDB-submit-1113491 and enhanced the security protection of NAS identity authentication.
  • Incorporated the security patch CVE-2026-99288.
GL-X3000. I did the 4.8.4 upgrade. A few hours latter we have 4.8.5.
If I don´t use NAS outside my lan (no open ports) and it is a home lan, is it safe to keep it with 4.8.4 until the 4.11 is released?
My limited understanding is that it needs to go in anway, but if router config is exposed to internet i.e. file sharing/ port forwarding/ remote access is not used, then risk is lower.At least for me as i dont do that. I dont know about you but for me i use other packages and update install sweeps them clean although configs are saved. Setting up some of them such as autocake rotate is tricky and time consuming. So, if they keep on pushing fixes as they discover, it becomes unmanageable.
Some feedback I put in the Discord/Reddit on both the GL.inet advice and the community site which I hope proves useful as they both seem to assume a certain level of knowledge/familiarity with technological terms etc
I feel they need to provide an "idiots guide" on how to factory reset and/or reinstall firmware rather than stating "download the official security firmware, install it without keeping settings, and manually configure the device again."
Many less technical users are going to confuse factory reset/reinstall and it needs to be as basic as:
To factory reset your device:
1. Download the latest xxx (common upgrade or uboot - which?) to a local device.
2. Log into your Glinet device (ideally when not connected to the internet). Do not choose the option to update your firmware if offered on logging in
3. Instead, go to xxx and manually upload the software you downloaded in step 1. Do not choose the option to "Keep settings on upgrade"
4. Then xxxx Etc..
Apologies if it's already there but unlike the guide how to run the community script, I looked and couldn't see it in an obvious place
What's your assessment? Do I have to do it again without transferring settings, or can I transfer settings this time if I already reinstalled yesterday with the previous firmware?
Yesterday, when I reinstalled the previous firmware on my devices, I set everything up from scratch, didn't activate Good Cloud, and also deleted my Good Cloud account.
And one more question: how do I delete astrowrap? I can't find any way to delete the account there!
