Are there plans for releasing updated firmware for older devices, e.g. Shadow (AR300M)?
Yes, we're working on this, and expect to release it in about 2–3 days.
Will the Flint 4 firmware version 4.11.0.b06 also receive an update?
The security updates you published today do not adequately address the various malware and your team continuing to tell everyone that upgrading with "keep settings" is going to ensure people bring the some of the malware into their newly flashed firmware and provide them with a false sense of security.
Standard OpenWrt /lib/upgrade/keep.d/netifd only preserves /etc/udhcpc.user.d/. The attacker appended /bin/ulogd and /etc/init.d/urandom_seed to this file. Whenever an administrator upgrades GL.iNet firmware with "Keep settings" enabled, OpenWrt's sysupgrade archives both malicious files and (should) restore them onto the freshly flashed firmware.
@rthco identified that's exactly the method the urandom_seed/ulogd/ujaild malware uses to persist across the update. It survives the "security" updates your team published today. Ken confirmed it here:
These guys disappeared...
The statements are so bad that they are making the situation even worse.
I always remove GL-iNet software garbage after every update - if there is no possibility to install clean openwrt .
opkg remove gl-sdk4-cloud gl-sdk4-ui-cloud gl-sdk4-ui-parentalcontrol kmod-gl-sdk4-parental-control samba4-utils - 4.14.12 samba4-server samba4-libs minidlna gl-sdk4-webdav gl-sdk4-tailscale gl-sdk4-ui-tailscaleview tailscale gl-sdk4-nas-exfat gl-sdk4-nas-utils gl-sdk4-ui-nasview gl-sdk4-nas-web gl-sdk4-ui-astrowarp kmod-dpi gl-sdk4-ui-dpifeatures gl-sdk4-dpi
Will GL-BE3600, GL-MT3600BE & GL-BE10000 on 4.11.x beta get bug fix now? If yes, when will the new firmware arrive?
Just came in to add my thanks to @admon and @rthco .
I have a Flint 4, never used Goodcloud; and the router seems clean - but that's only thanks to your script looking for real IoCs, not the `tmp` check.
To Gl.Inet Staff:
- You are probably in a bit of a panic. The forum moderators (Glinet stafff) are probably constrained by what "corporate" are letting you say.
- Thanks for the engagement with the community so far; but you need to go further, and listen to the people like @admon and @rthco who are really providing excellent support; in their own time, without any obligation. We need to get that advisory page updated NOW to provide accurate information.
- I would really love for a proper lessons learned / postmortem to happen once the immediate impact has calmed down.
- It would be great if the community could have a way to feed into what lessons could be learned from this too.
The most important thing is transparency.
It’s much better to hear bad news directly from GL.iNet rather than from random people on Reddit or other forums.
If something is hidden and a customer ends up discovering it on their own, that could be the final straw.
By the way; thanks to @admon , @rthco and many others , you guys are doing a really good job
The triage tool does not recognise --update on MT6000. Running it without --update ran version 2.49
~# sh gl-helper-triage.sh --update
ERROR: unknown option: --update (see --help)
root@Alvonnie_GL:~#
same on RM10 KVM
The --update is valid from 2.50 and above
Just download the script once again:
curl -fsSL https://app.gl-i.net/csa-2026-01-fix -o gl-helper-triage.sh
Thank you for not forgetting op25 for the MT3000 and MT6000.
Repeat Request
Has anybody said what is the effect on PCs connected to hacked routers? is there a way to check if a PC is infected and if so how to clean and recover it?
That's a difficult question.
The best approach I take into consideration is: if my router was attacked, there is a risk of my computer was also attacked.
It's also very difficult to answer what the attacker did on each device.
There's currently no way to know. The optimistic take is that the exploit was more likely to be levering your router as part of a botnet rather than trying to cross-infect across your LAN. But that's just guesswork. Having said that, given the scale of the exploit, I would have expected some indication of PC infection (or attempted infection) by now. But again, that's just speculation.
I think this whole palaver could of been a ruse, a ploy, a misdirect insisted on by the bosses in the Big Country to get all users, including those happily on old firmware, to update to new firmware where a back door was insisted on.
Conspiracy theory fan))
Hi all,
Wanted to make sure Tailscale is up to date as well, assuming the following will be okay to run on the latest MT6000 Firmware (4.11.1)?
Support stated that, based on my MAC and S/N, my devices aren't compromised. However, upon inspecting GoodCloud logs - they are very much compromised. Here's what's compromised and how:
- attacker managed to login as me
- attacker used POST / GET queries
- all Wi-Fi configurations and passwords compromised
- all VPN tunnels, servers, clients, configurations compromised
- all MAC addresses of clients exposed
Now the important bit - on BE3600, the updated firmware does NOT resolve the issue. The access persists and the attacker tools continues to send post/get queries leaking all the information, even on the latest firmware. The vulnerability is NOT closed.
