Security Notice: GoodCloud Remote Management Incident
** Unauthorized access to some GoodCloud-connected GL.iNet routers and KVM devices**
Issued November 20, 2026 · Updated November 23, 2026 (UTC)
What happened and how we responded
On November 20, 2026, GL.iNet identified unauthorized access to some routers and KVM devices connected to GoodCloud, our remote management service. An unauthorized party exploited a vulnerability in the service and installed malware on some of those devices. We blocked the identified attack path on November 20 and released security firmware that disables the known malware and removes the related files and traces identified during our investigation.
We have submitted CVE reports for the vulnerabilities identified during our investigation into the attack and malware; CVE identifiers are pending. See technical details.
Who is affected
Receiving this notice, seeing an update prompt, or finding your model in the download tables does not mean your device was accessed. This incident involved devices connected to GoodCloud; a connection alone does not establish that an attack occurred.
Your situation What it means and what to do
Your device never connected to GoodCloud It was not likely exposed through this incident's attack path. Update the firmware as routine security maintenance. This incident alone is not a reason to reset the device or replace passwords and keys.
Your device connected to GoodCloud, but you have no evidence of unauthorized access It may have been exposed, but compromise is not confirmed. Install the security firmware and follow the precautionary password and key guidance below.
GL.iNet identified your device as affected, or you have evidence or a reasonable suspicion of unauthorized access Follow the recovery guidance below. If access appears to be ongoing, contain it first. For an affected KVM, also check the connected computer as a precaution.
Some KVM devices have cloud service enabled before account linking. Not having a cloud account, or not linking a device, is not by itself proof that it never connected. See the KVM cloud-service documentation. If you are unsure about the device's connection history or a suspicious change, contact Support for help assessing it.
What you should do now
For all users: install the security firmware
Install the latest stable security firmware for your exact model, using the official links below. You can update through the device's administration page; you do not need to run terminal commands or a security check first. Follow the router upgrade guide or KVM upgrade guide.
An update is a preventive step for users without evidence of compromise. An update prompt alone does not require a reset or password changes. If you want an optional check or need to preserve evidence, do that before restarting, resetting, or updating, since those actions can remove signs of earlier activity.
If unauthorized access is known or suspected: contain and recover
If access appears to be ongoing, disconnect the device from the internet if you can do so safely and contact Support from another device. If disconnecting would cut off your only remote access, contact Support to plan recovery.
For the strongest standard recovery assurance, download the official security firmware, install it without keeping settings, and manually configure the device again. Use new passwords and keys, and do not restore a backup from a potentially compromised device. On routers, turn Keep Settings off; on KVMs that offer it, clear Save current configuration. The upgrade guides above explain these options. If your model's options differ, ask Support for the appropriate procedure. A factory reset alone does not install the security fixes.
Keeping settings remains an option you may choose, including to preserve remote access. The update still provides targeted cleanup for the known November 20 malware and can substantially reduce the risk from that malware. However, it may retain other unauthorized changes, so it provides less recovery assurance than reinstalling without settings. Contact Support if you need help choosing an approach or suspicious activity continues.
For an affected KVM, also check the attached computer for unfamiliar accounts, software, browser extensions, startup items, or unexpected settings changes, and run a full scan with current security software. This is a precaution; it does not mean the attached computer was also accessed. See the KVM guidance in the incident announcement.
If your device connected to GoodCloud: replace potentially exposed passwords and keys
After updating or recovering the device, change passwords and replace access keys stored on or accessible from the GL.iNet device as a precaution, even if a check finds nothing. Examples include its administrator password and, if used, VPN and SSH keys. This advice does not mean every connected device was accessed or every password was copied. An update cannot revoke a key or password that was already copied.
For other computers and devices, replace credentials if they were also stored on the GL.iNet device, reused there, or there is evidence or a reasonable suspicion that the other device was accessed. Simply connecting a computer by Ethernet or Wi-Fi does not, by itself, establish that its passwords were exposed. If you are unsure which credentials need changing, ask Support. The technical discussion of credential exposure explains why these precautions matter after unauthorized administrator access.
Download and install the security update
The security firmware disables the known malware from this incident and removes its related files and the traces identified during our investigation, including when settings are retained. It provides targeted cleanup; it is not a general malware scan or a complete integrity check. Additional vulnerability fixes and their cloud or firmware coverage are explained in Technical details and investigation findings.
The cloud-side fix blocked the identified attack path, while firmware cleanup addresses the known malware already on a device. Neither can undo past access or revoke copied credentials. Follow the recovery guidance above if access is known or suspected.
These tables list models with published security firmware, not confirmed compromised models. Install the latest stable release for your exact model; the versions below are the minimum security versions listed in this notice. If you installed a security beta, move to the latest stable release.
Router security firmware downloads
GL-AXT1800: Install the security build from the official link above. If your device already shows 4.8.4 and you are unsure which build is installed, contact Support.
KVM security firmware downloads
Model Minimum security version
RM1, RM1V2, RM10, RM10RC, RM1PE, RM4PE 1.10.3
RMQ1 1.8.7
If your model is not listed, check the GL.iNet Download Center or ask Support which update applies. Do not install another model's firmware. The table is an update list, not a determination of which individual devices were affected.
Optional device checks before updating
Updating is the primary action. A check is optional and is not a prerequisite for installing the security firmware. If you want to check first, do so before restarting, resetting, or updating. Neither method below can rule out previous access or certify that a device is free of compromise.
First choice for broader coverage: community security check
The independently maintained community security check examines files, startup entries, running processes, and network connections for a broader set of known indicators. It can also flag indicators of the separate router persistence finding described below.
This is an independent third-party project. Review its instructions and source code, and use check-only mode. Administrator access is required. Skip evidence collection, cleanup, and report submission if you only want to check. An unfamiliar change flagged for review is not automatically proof of infection. You may ask Support for help instead of running a script.
Optional KVM check — limited coverage
See the KVM quick-check instructions on the GL.iNet forum. A negative result does not rule out compromise; follow this bulletin's firmware and recovery guidance.
How the incident happened
GoodCloud's MQTT device-messaging service, deployed using EMQX, had a configuration error in message authorization. A client could send management messages to other users' connected devices without the required permission. This is a finding about GL.iNet's GoodCloud deployment, not a claim that every EMQX installation is vulnerable. The GoodCloud report describes the service-side authorization problem.
A separate AstroWarp/SD-WAN input-handling flaw could cause management input to be executed as commands with root (administrator) privileges on affected routers, even when AstroWarp was turned off. A community report documents unauthorized remote command access on a GoodCloud-connected router. The RTTY finding below concerns remote-terminal connection security. These are distinct issues; the router command-injection flaw should not be assumed to explain every KVM compromise.
Vulnerability reports and remediation coverage
The links below point to GL.iNet's published vulnerability reports. Official CVE identifiers remain subject to assignment/publication confirmation; report titles and internal tracking references are not CVE numbers.
Vulnerability report Security impact Remediation and firmware coverage
GoodCloud message authorization — GitHub report Unauthorized messages could change device configuration or invoke device management APIs. Further impact depends on what the device accepts and processes. The report identifies GoodCloud v3.19.13 as affected and v3.19.14 as fixed. The identified cloud attack path was blocked on November 20. This is a service-side fix; device firmware separately provides incident malware cleanup.
AstroWarp/SD-WAN command injection — GitHub report Insufficient input validation could allow root command execution on the listed routers, including with AstroWarp disabled. The report lists model-specific expected fix versions. The download tables above identify published incident security releases; check the exact model and build. The report's planned-version wording alone does not verify every shipped build. This router finding is not a KVM vulnerability claim.
RTTY configuration and TLS certificate verification — GitHub report If relevant startup arguments can be modified, intended server-certificate verification can be bypassed, allowing connection to an attacker-controlled terminal server and root access. The report identifies 1.10.3 as fixed for RM1, RM10, RM10RC, RM1PE, RM1V2, and RM4PE, and 1.8.7 for RMQ1. Its router entries use expected fix wording; those entries do not by themselves confirm publication or verification of every planned router fix.
Fixing a vulnerability and cleaning up a compromised device are different tasks. The versions above describe the linked reports' remediation status; they are not a finding that every listed device was attacked. Retained settings, copied credentials, and changes outside the targeted cleanup can still require recovery action.
Additional findings and recovery limits
  • Separate router persistence reports. Community users reported a modified startup script and suspicious processes; GL.iNet acknowledged these reports in the forum. Some reported file dates predate November 20. The original reports do not establish the initial entry path or a connection to this incident. A process name alone is not proof of infection. Do not assume incident malware cleanup resolves every separate persistence finding.
  • Why keeping settings can leave other changes.Community KVM testing reported that an added startup script and SSH key survived a configuration-preserving upgrade on a test RM1. This illustrates a recovery limit; it does not establish that every affected KVM had those modifications. For known or suspected compromise, reinstall without keeping configuration using the model's supported upgrade options.
  • Firmware and boot integrity.Community recovery analysis explains that a normal reset or firmware reinstall may not rewrite every flash region. This is a recovery limitation, not evidence that boot components were changed in this attack. Contact Support if there are reasons to suspect deeper changes or activity persists after recovery.
  • Other devices and credentials. We have not confirmed access to other devices through a compromised GL.iNet device. However, root access can expose credentials held on that device, as explained in the remote-access case report. Not confirming access to another device does not eliminate that credential risk.
Investigation and further updates
Security firmware has already been released for the models listed above. Its availability does not mean every device of those models was compromised, and additional findings do not establish that all listed devices share the same vulnerabilities.
We are continuing to determine the number of affected devices, the timeline of unauthorized activity, and whether computers connected to affected KVMs were accessed. As individual findings are verified, we will update this notice and publish model-specific advisories identifying the relevant versions, confirmed fixes, and any further actions. Any additional firmware work will be described separately from the security releases already available.
Our commitment to customers
We’re sorry for the concern and disruption this incident caused. Updating and recovering devices takes time, especially when they are managed remotely. Our Support team is ready to help you assess your device, choose a recovery approach, and interpret check results.
Teams across GL.iNet are continuing the investigation and adding safeguards to our cloud services and device firmware. We will share confirmed findings and further guidance as they become available.
Frequently asked questions
1. Was my device affected by this incident?
Devices that never connected to GoodCloud were not exposed through this incident's attack path. Devices that connected could have been exposed, but connection alone does not establish compromise. AstroWarp being turned off does not rule out GoodCloud exposure. Some KVMs can connect before account linking. If your connection history is unclear, contact Support. Keep firmware up to date as routine security maintenance.
2. Does a check that finds nothing mean my device was unaffected?
No. A check covers only the indicators it looks for, and restarting or updating can remove signs. Install the security firmware regardless of the result. For optional checks, use the community check for routers or broader KVM coverage. The short KVM check has limited coverage.
3. Who needs to change passwords and keys or check other devices?
For devices that connected to GoodCloud, and for any device you know or suspect was compromised, replace credentials stored on or accessible from the device after updating or recovery. This is a precaution even without a positive check. A device that never connected and has no other reason to suspect compromise does not need incident-related credential replacement. Check the computer attached to an affected KVM; for other devices, use the exposure and access criteria in What you should do now.
4. Can the same GoodCloud attack path still be used?
We blocked the identified attack path on November 20. That service-side fix does not remove malware already installed on a device. Install the security firmware and follow the recovery guidance appropriate to your situation. The vulnerability reports above describe the scope of each fix.
5. Will I receive an email if my device was affected?
We will email customers whose devices we identify as affected using the address associated with their GL.iNet cloud account, including when a device has since been rebooted or updated. Not receiving an email is not proof that a device was unaffected. Do not wait for a notification before installing the security firmware or seeking help if you suspect compromise.
6. Do I need to factory reset or reinstall firmware?
An update prompt alone is not a reason to reset. If unauthorized access is known or suspected, the strongest standard recovery option is to reinstall official security firmware without preserving settings, then manually configure the device again. Turn off Keep Settings on a router or Save current configuration on a supported KVM upgrade. Keeping settings remains your choice, with the cleanup limits explained above. A reset alone does not install the fixes. See the linked upgrade guides or ask Support about your model.
Contact
For device checks, firmware updates, and recovery, email support@gl-inet.com. To report a security issue, email security@gl-inet.com.
Update history
  • November 20, 2026 (UTC): Initial notice issued.
  • November 22, 2026 (UTC): Added the community security check and further information.
  • November 23, 2026 (UTC): Updated with pending CVE reports(identifies pending assessment) and additional findings.
GL.iNet Security Team
Does this only include if the device linked to goodcloud or glkvm had enabled remote access ?
On my router for example I only linked it to goodcloud, but had no remote access enabled.
Where my wireguard server credentials exposed on goodcloud?
On a side note for people wondering if persistancy is possible: yes it is possible on the router but I suspect the attack to be small targeted, the chances seem to be low.
If you don't trust it after a factory reset please check the contents of /etc/uci-defaults and /etc/sysupgrade.conf if there are no suspicious pointers to malicious code you should be fine.
Can you please be more specific how to check if our devices were affected? What to look for on the routers? Can I still export the configuration backup, factory reset and safely import the configuration back?
My guesses are try to carefully examine it for now if your device is a router:
Check these files after the reset took place and you placed back the backup:
  • /etc/rc.local (start up programs)
  • /etc/sysupgrade.conf (files being preserved after backup, and also with firmware upgrades)
  • crontab -e (tasks)
  • /etc/uci-defaults (code being executed when firmware flashes, or firmware reset is pressed, this is a unusual place as the firmware image code executes at /rom/etc/uci-defaults)
  • /etc/rc.d ( service symlinks, delete to disable )
My problem is, we don't know yet when the attack took place and how long, and we neither know if the attacked devices are having persistanced code, so examination is advised with the backups.
You could try to do the firmware reset via u-boot to avoid any uci-defaults trigger.
Ps: I'm not a GL employee.
Is a KVM which is not bound to your cloud service but showing the Cloud service enabled safe or not?
I just discovered that the cloud service can be disabled fully..... That should be the default but it is not :(.
The disable button is hidden under "More Settings".
On my GL-RM1, Goodcloud and self-hosted are disabled, and all outbound traffic is blocked with IPTABLE rules on the device itself.
Can I assume I am safe?
Chain OUTPUT (policy ACCEPT)
target     prot opt source               destination
DROP       icmp --  anywhere             anywhere             icmp echo-request
ACCEPT     all  --  kvm.redacted.com     192.168.69.0/24
DROP       all  --  kvm.redacted.com     anywhere
DROP       udp  --  anywhere             anywhere             udp spt:!ntp dpt:ntp
This is a serious security incident that understandably raises concerns among GL.iNet users. I appreciate GL.iNet's initial response, but several important questions remain:
@bruce @will.qui, could you please clarify the following?
  • Which devices and firmware versions were affected?
  • When did the attacks begin?
  • Will GL.iNet provide indicators of compromise (IOCs) to help users determine whether their routers were affected?
  • Can a factory reset reliably remove the malware?
  • When can we expect the announced security firmware update?
More technical details and clear guidance would be greatly appreciated, especially for users with complex router configurations.
Transparency and regular updates will be important in helping customers regain confidence in GL.iNet's products and services.
Another question is : what does the malware do ?
If I had goodcloud remote access enabled, I would:
  • follow any enterprise incident response procedures (quarantine KVM and connected computer, save any applicable activity logs, etc.)
  • manually download the latest firmware
  • perform a local upgrade
  • make sure to uncheck the box to save configuration
  • then scan or re-image the connected computer
  • if in an enterprise environment, remove the KVM
  • if in a homelab, disable goodcloud and block all outbound traffic
I suspect if the goodcloud enabled KVM was connected to a computer, and was either logged in at the time or did not have access controls enabled (e.g. console access), it's possible the miscreants could have installed malware on the connected computer, not just the KVM itself.
This scenerio is precisely why I do not enable any OEM cloud remote access capability. And precisely why these devices should never be connected in an enterprise environment. Full stop.
Also likely why user @1020alex got fired from his job.
@bruce @will.qiu - I'm going to post the same reply as on reddit.. This vague notice is NOT the way to do things.
Can you publicly post the root issue, detection & mitigation process asap please? Like right here, right now please?
This isn't the type of thing to keep gated behind someone checking or receiving an email. That is not how CVE and security disclosure is done for an active threat already being exploited. We should be able to start detection and mitigation immediately. Has GL registered a CVE with MITRE?
These are devices most often directly managing private LANs or already inside the existing LAN. We need to understand the full exposure and potential for lateral movement FOR IMMEDIATE ACTION.
Emails could have been registered with disposables for privacy, GL email domains go direct to spam on some providers, and some of us manage devices on behalf of others. Personally, I can't wait for thousands of individual emails to potentially come in and get forwarded. I have 400+ devices in my personal GoodCloud alone and no email with details yet.
We need dates, initial attack vectors, indicators & artifacts to look for, etc. MANY GL devices are physically remote, so "pushing reset" isn't an option. Remember you sell VPN servers and KVMs - the entire point is people may be managing these devices from many miles away. These devices could be inside management and control VLANs.
EDIT: GL TEAM, I'm not sure who missed security-basics training day, but DO NOT tell people to blinding just reset their devices!
If this is a full root exploit, then the devices need to be scanned to see if it was actually infected first before reset, and hopefully find file modification dates so you can determine how long the device has been compromised and the potential blast radius to other LAN devices. If this device was inside a small office with HIPAA or PCI compliance then it may be required to investigate or wipe entire exposed infrastructure. People need information exactly how to IDENTIFY the compromise as STEP 1.
TO EVERYONE - If your GL device is in a business environment, then DO NOT just reset it. This could void your insurance coverage for the event. Power off and remove the device, then contact your IT support or even your insurance provider if you have umbrella or cyber coverage so that forensics can be done to assist with a full environment assessment.
This response is a disgrace. There is nothing like sufficient information here.
Looks like emails are going out.
I briefly had goodcloud enabled when I first got the GL-RM1 in October, 2025, but quickly disabled it given the security risks.
That email response is as entirely useless and devoid of details as the initial announcement. This handling just gets worse by the minute.
Since I initially had goodcloud enabled back in October, 2025, I logged into my goodcloud account and manually reviewed the logs.
Seems like everyone affected should export all the logs to preserve evidence. It would be helpful if GL-iNet could provide an example what suspicious activity would look like,
For me, there is no logs prior this morning ... no logs from 20/11
Yeah, same for me.
I'm wondering now if this could be related with my post from yesterday
KVM firmware(s) are here https://forum.gl-inet.com/t/kvm-firmware-security-update/73058
Edit: Apparently the thread has been unlisted for now so does not appear publically anymore, no idea why.
