For reset, would restoring from a (new) backup work? Or do we need to reset and setup the router from scratch again?
in the absence of details of the vulnerability and potential compromise, I would assume the configuration settings may be compromised.
keep in mind that anything you or miscreants put in the /etc/kvmd/user/ path may survive firmware upgrade and reset.
I would also be concerned about compromise of the IP-KVM connected computer.
You identified the problem in Nov 20, 2026? The exploit started at least back in Sep 2025 (more than a year ago), when /etc/init.d/urandom_seed was overwritten to load backdoors on the router and it has mechanisms to survives firmware upgrades via modified /lib/upgrade/keep.d/netifd
yeah it'd be great getting an official firmware pushed through normal channels rather than a one-off.
also i assume this is a risk for anything connected to goodcloud... is that the "remote management" mentioned (why not mention it by name?)
and if it is goodcloud would the goodcloud console logs show the behavior in some way? like a device login or anything?
Edit: Apparently the thread has been unlisted for now so does not appear publically anymore, no idea why.
Likely GL-iNet does not want AI scrapers from knowing anything about the vulnerability.
I wouldn’t be surprised if “someone” purged the logs to destroy evidence that could be used in a lawsuit or otherwise be used to damage their reputation.
At first, we temporarily distributed the fixed firmware through Google Drive in that thread — now that the KVM firmware is available in the Download Center, that thread is unlisted.
Does this update include the compromised certs fix? Or we have to manually apply that after updating?
You talk about KVM firmware, but what about routers firmware ? Because in the security notice, routers are also touched...
For now, Flint4 didn't have any new FW
But as I read what GL Staff pusblished, I became to think that KVM are the one targeted... not routers...
@will.qiu Were routers targeted ?
In their statement it is also routers, but i get the impression the attack was more under the kvms.
I'm copying my logs to my local computer, generating an SBOM, getting hashes of relevant items as well as backing up my configuration manually, and the typical backup mechanism. I'm thinking it's only a coincidence, but last week I all of a sudden started receiving dating spam, fake hookup sites, etc... in what has been a very clean spam box. I almost always use apple's hide my email feature, and these are all coming to my main email address. Anyone else? Also, has anyone found possible IOC or IOA's yet?
KVM Status Quick Check Quickly check if your KVM is under attack
Router Status Quick Check Quickly check if your Router is under attack
What's the degree of confidence in this? Is this a reliable indicator that devices haven't been compromised, or just that the exploit isn't currently running?
I have to agree that GL is going an honest job with providing the info they have to right now and not the root cause. They don't others to copy the attack until firmware is released. Good for them as they are protecting us.
I have a few things I would like to know:
- For any affected device, what was installed, and what indicators should I look for on the device and on client computers that used it?
- Will any IOCs be available in the future for us to run checks?
- Were device-stored secrets exposed, such as VPN client configurations and keys, Wi-Fi credentials, the admin password, or cloud session tokens?
- What was the exposure window, i.e. when exploitation began and when the unauthorized access was cut?
- Was exposure limited to devices bound to a GoodCloud account, or were unbound devices also reachable?
- Does the recommended 10-second factory reset fully remove the malicious software, or do you recommend a U-Boot reflash with a clean image?
- Which firmware version will contain the fix for the GL-MT3000, GL-AXT1800 and GL-BE3600, and what is the expected release timing?
- Will a CVE be assigned for the cloud-service vulnerability?
Thanks.
And to be honest, an IT risk assessment should have been performed before choosing or deploying any product. Then you would already know what the response and mitigation should be.
Too vague...
Are only devices connected to GoodCloud affected, or are all KVM/routers with GL.iNet firmwares affected?
This seems very serious. If the KVM are affected, the attacker had control of your computer, and nobody can predict how deep they went.
is vanilla OpenWrt also affeceted?
