Only devices that are hooked up with MalCloud (AKA GoodCloud). On November 20, 2026, GL.iNet identified a security vulnerability in our cloud remote management services. An unauthorized party exploited this vulnerability to access and install malicious software on a subset of GL.iNet routers and KVM devices.
For goodcloud enabled IP-KVMs, I would also be concerned the device the IP-KVM is connected to could possibly be compromised, if the system was unlocked or does not have access controls in place (e.g. a console port). Nothing to stop a miscreant from installing malware or Trojans on the host system.
what is that?
A GL-iNet service, if enabled, allows you to remotely access your router/KVM via their always connected cloud service via a web browser. The downside is it also allows miscreants to do the same thing if a vulnerability is exploited.
Confirmed the compromised certs fix is NOT included in this firmware update. I had to reapply the workaround via CLI .
[root@kvm:~]# curl https://dv-g3b-emudhra.we-have-a-problem.com/
Your client successfully connected to the site. That's bad!
[root@kvm:~]# curl https://dv-g3b-aaa-emudhra.we-have-a-problem.com/
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
[root@kvm:~]# curl https://dv-g3b-noct-emudhra.we-have-a-problem.com/
[root@kvm:~]# curl https://dv-g3b-aaa-noct-emudhra.we-have-a-problem.com/
[root@kvm:~]# mkdir -p /etc/ssl/untrusted
[root@kvm:~]# mv /etc/ssl/certs/emSign_ECC_Root_CA_-_C3.pem /etc/ssl/untrusted/
[root@kvm:~]# mv /etc/ssl/certs/emSign_ECC_Root_CA_-_G3.pem /etc/ssl/untrusted/
[root@kvm:~]# mv /etc/ssl/certs/emSign_Root_CA_-_C1.pem /etc/ssl/untrusted/
[root@kvm:~]# mv /etc/ssl/certs/emSign_Root_CA_-_G1.pem /etc/ssl/untrusted/
i have this via ssh
root@GL-MT6000:~# ps | grep tmp
5068 root 1232 S /usr/sbin/crond -f -c /tmp/gl_crontabs -l 10
6792 root 0 SW [RtmpCmdQTask]
6793 root 0 SW [RtmpWscTask]
11865 root 5244 S /usr/sbin/rtty --conf /tmp/rtty.ini
12697 root 0 SW [RtmpMlmeTask]
14099 root 1236 S grep tmp
can you get the content of /tmp/rtty.ini?
cat /tmp/rtty.ini
The original post has been updated, please check the latest updates:
@bruce @alzhao @will.qiu: there are now three reports of the same root reverse shell on GL-AXT1800 4.8.3 routers bound to GoodCloud, all to 170.39.226.219, two of them started at 21:40 UTC on November 20. One is mine. GL's quick check reads it as "healthy and secure". Details, the cause, and a check that catches it: Quickly check if your Router is under attack - #34 by rthco
If I'm understanding right, the attacker had access via GoodCloud. So they had full access to these devices.
It's impossible to know what they did. They could have installed one kind of exploit in my router and another exploit in your router. GL-iNet will be unable to know what the attacker did.
If they had access to the KVM, they could have had full access to your PC and stolen credentials, files, etc.
In summary: remove these devices from the internet (KVM, routers, and computers connected to them).
A full reset of these devices and formatting the computers are the safest option.
I found the same problem on my routers. When did you first discover it? It appears to be a different issue from the one others have discovered.
Was this reported before on the forum or directly to GL-iNet?
I'm also looking for an old report but failed. I found the same problem in my routers. Not sure if it's also caused by a same GoodCloud vulnerability.
If the attacker had access to these devices and installed a persistent file, a new firmware will not fix the issue.
It seems @admon did a good job here:
GL-MT3000 / Firmware 4.11.0 – Security check findings
I've performed several checks on my GoodCloud-connected Beryl AX (GL-MT3000), including the official IOC check, community triage script, reverse shell checks, and persistence checks. No known indicators were found, and the router has not been rebooted since November 19 (before the reported attacks).
This doesn't rule out a compromise, but might be a useful additional data point. Full findings and details here:
Patiently awaiting firmware for the b3000 marble
GL-X2000 (fw 4.7.13, GoodCloud + Tailscale, LTE): the official check (ps | grep tmp) finds nothing, but I found something different from the reverse shell reports here.
- /etc/init.d/urandom_seed has extra lines at the top: it copies /usr/bin/lua to /usr/bin/monitord, copies /bin/ulogd to /var/run/monitord.pid, runs it and deletes it
- /bin/ulogd is compiled Lua 5.1 bytecode (collects MAC/model/firmware, downloads a zip to /tmp, chmod +x, rm)
- a running /usr/sbin/ujaild whose binary is deleted (/proc/PID/exe -> /tmp/ujaild (deleted)), static Go aarch64, started Nov 16 ~02:05 CET
- no foreign SSH keys or logins
@asgdfgfew23 you mentioned urandom_seed being overwritten since Sep 2025: is this what you saw? Does anyone else have a modified urandom_seed, a /bin/ulogd or an ujaild process? Please check read-only (cat /etc/init.d/urandom_seed, ls -l /proc/*/exe | grep deleted) and don't run any files.
Is there a patch scheduled for release tomorrow for Flint 2, specifically the op25-based firmware?
