After update to gl-ar750-3.013-0129:
- no Open VPN connecten
After revert to gl-ar750-3.010:
- Open VPN working fine again
What is the error message?
You can try again in 3.013-0129 again, and send the log in here, you can find it in Advanced → Status → System Log.
3.010->3.013 didn’t change the VPN, it shouldn’t has this issue.
Today, i checked update from 3.010 to 3.013-0129 again.
After update:
Does Openvpn over 443 work in the old firmware?
Is this a problem of your ISP?
Could you please send the log to me? One is TCP 443, another is UDP 1194.
Addet from GL-AR-750 Creta, broken after update firmware from 3.104 to 3.105
It can be it will help for constantly improve the firmware:
Thats my two cents on this
Look forward.
@alzhao @Henry_Bruns
There seems to be a lot more energy put into releasing new devices than into firmware. This would be okay if there was support in the mainline tree for a fully functional openwrt build. But the patches for the Slate have not been made and we are left without a satisfactory way to use the device (building firmware possible for me, but an annoyance). It encourages users to purchase devices with better openwrt and/or dd-wrt support
I was doing a mistake, the follow link is the right one to the actual alternate bug tracker:
Look forward.
