Just wondering if anyone has used Tailscale’s Mullvad Exit Nodes on a GL.iNet GL-MT3000 (Beryl AX). I know that Tailscale implementation is still in beta on the GL.iNet routers (only running version 1.32.2-dev-t). I’m also based in Australia and it’s not available here to test.
To test tailscale stable version binary you can upgrade it manually for MT3000,
cd /tmp; curl -f -L https://pkgs.tailscale.com/stable/tailscale_1.52.1_arm64.tgz -o tailscale_1.52.1_arm64.tgz
tar -zxvf tailscale_1.52.1_arm64.tgz
mv tailscale_1.52.1_arm64/tailscale* /usr/sbin/
Keep in mind the firmware version needs to be 4.5 at least.
I did note the typos and have updated the Tailscale version to 1.52.1. As I’m in Australia, I hadn’t tested the Mullvad Exit Nodes part. Because I don’t believe, it’s available as yet here.
Are you running firmware version 4.5?
Latest 4.5 snapshots have a bug:
On boot, 2G and 5G wifi APs come up as open network ( no password ) and with names:
- MTK_CHEETAH_AP_2.4G
- MTK_CHEETAH_AP_5G
I didn’t reproduce the issue. Do you upgrade with keep-setting?
I reproduced the bug. I upgraded with keep-setting.
I tested again with today’s firmware upgrade from version 4.4.6.
There may be some config messed up in your old firmware.
Do you remember your previous version? You can export log for further debugging if needed.
Ah, I upgraded from the previous beta build of 4.5, not from 4.4.6
- MTK_CHEETAH_AP_5G
I had a similar effect here, however I noticed that these networks can be renamed, given a password and even disabled.
You can try turning them off, but they need to be set in the settings /etc/config/wireless
On my side, the issue is, I have 5G wifi AP configured but when the device is booted it sets up open AP with above names… After network restarting, the configured AP comes up.
Thank you guys. We’re looking into this.
Will it work if I amend this curl command based on the arm64 listed stable version here:
https://pkgs.tailscale.com/stable/ or more correctly https://pkgs.tailscale.com/stable/#static
i.e.
https://pkgs.tailscale.com/stable/tailscale_1.54.0_arm64.tgz
cd /tmp; curl -f -L https://pkgs.tailscale.com/stable/tailscale_1.54.0_arm64.tgz -o tailscale_1.54.0_arm64.tgz
tar -zxvf tailscale_1.54.0_arm64.tgz
mv tailscale_1.54.0_arm64/tailscale* /usr/sbin/
EDIT1: OK, so I did that, it updated but still shows 1.52.1 in the login.tailscale.com admin page???
EDIT2: So I tried it again and got this error:
curl: (6) Could not resolve host: pkgs.tailscale.com
I have little idea what I am doing but it seems a DNS issue. I have the Beryl AX connected to my Asus RT-AX86U via Ethernet Cable and set up as an AP via the Network Mode (using Webadmin, but why can’t GLi sort out an App option for that AP mode, why does it have to be done via Webadmin?!), so searching around I found (and issued) this:
sudo echo nameserver 8.8.8.8 > /etc/resolv.conf
Which resolved the curl error and I could then run the commands above. My Router uses Cloudflare 1.1.1.1 and 1.0.0.1, maybe it does not like that.
I had to then disable AP mode and reset the Router BACK to Router Mode to see if the Plugin Version had updated (Why can’t GLI allow the Tailscale App to run in AP Mode, is this a Tailscale limitation?).
In any case the version has now updated to 1.54.0.
didnt work for me got this error after trying to insatll 1.54
root@GL-AX1800:/usr/sbin# ./tailscale
./tailscale: line 1: :s: not found
./tailscale: line 1: : not found
./tailscale: line 1: 4: not found
./tailscale: line 1: ELF@@8@@@@PPdd4K4KLMMHTHT7Qtd4J]ML%: not found
./tailscale: line 2: can’t open ~CdN: no such file
./tailscale: line 2: SaD: not found
./tailscale: line 2: SbDTBTCa@: not found
./tailscale: line 2: @hc_?T@@A@_OR: not found
./tailscale: line 2: xd: not found
./tailscale: line 3: syntax error: unexpected “)”
I recommend to use my tailscale update script: Script: Update Tailscale on (nearly) all devices
same issue apparently new version is not working for some reason
What admon said :-). So much easier and neater.
Has anyone every gotten the Beryl to use Mullvad as an Exit node? I have updated tailscale on the Beryl to the latest version (1.82.0), but the only exit node available is my MacMini that I have setup as a exit node. There are no Mullvad options. Mullvad is configured for the Beryl. Thanks!
So, in case this helps anyone else, I was able to finally get it working with Mullvad exit nodes. I had to follow the instructions below from another post.
I found the answer to my problem of mullvad exits not working on my Beryl: > Configuring the Exit Node Using the LuCI Admin Panel
To successfully configure the exit node, follow these additional steps in the LuCI admin panel:
Access the Advanced Settings:
• Navigate to System > Advanced in the LuCI admin panel.
• Select Network > Firewall.
Edit the Firewall Zone:
• You will see three zones listed by default:
lan > wan
wan > REJECT
guest > wan
• Locate the second zone (wan > REJECT) and click Edit.
Modify the Advanced Settings:
• Go to the Advanced Settings tab.
• In the “Covered devices” dropdown, select tailscale0.
Save and Apply Changes:
• Click Save, then Save & Apply to finalize the configuration. (Unable to use tailscale exit nodes on Beryl AX - #18 by rairoumaru)
I'm not sure why this is so hidden. But it my case it seems to be unique to Mullvad exit nodes as normal exit nodes seemed to work fine.
