V1.7 Release 2 GLRM1
I saw that then 1.7 firmware version has been removed (Comet ) from this web page: GL.iNet download center
Any particular reason for this removal? Thanks!
If I had to guess, complete lack of SQA or regression testing before pushing out an untested bug filled update to the public.
Some users reported encountering strange issues with version 1.7.0, such as devices losing their IP addresses, being unable to access the network, and blinking white lights.
However, we have been unable to reproduce this issue in our environment. It didn't happen in our testing process. We are diligently contact with the users meeting this issue and find out the reason.
You might can downgrade to 1.5.1, or keep using 1.7. But PLEASE NOTE that, as we know, if the issue happen, it can only be solve by unplug and replug the Ethernet cable.
Sorry for the inconvenience caused anyway, we will fix it ASAP.
This morning i found one more time the RM1PE blinking white led and with no access. Instead of reboot the device i rebooted the router. Once the router came up the connection with the RM1PE restored. I have setup the device for static ip. Before I reboot the router the router reported that there was no device connected. I updated from 1.7.0 to 1.7.1 beta for testing again.
Sincerely appreciate your update.
Please try with the 1.7.1 beta and see if can solve the problem.
If convenient, could you please set the lease time of DHCP server in your router to 2 mins?
It will be more efficient for checking if it can work stably.
Thanks again and looking forward to your update.
i had 1.7 and all was good. i just got 1.71 release 1 and tailscale stopped working. Date/Time is not set correctly on the KVM…
Can i get a link to 1.7 pls??
In 1.7.1 we add ntpd back , and disable connman build-in ntp client. So I guest your comet can only access the ntp server which DHCP assigned?
I suggest you modify
bash-4.4# cat /etc/ntp.conf
restrict default ignore
server 0.pool.ntp.org iburst
server time.cloudflare.com iburst
server ntp.tencent.com iburst
restrict 0.pool.ntp.org nomodify notrap noquery
restrict time.cloudflare.com nomodify notrap noquery
restrict ntp.tencent.com nomodify notrap noquery
The way things have turned out so far is just ridiculous
  1. Some users report that the system may randomly disconnect when we keep CONNMAN NTP and disabled NTPD.
  2. If NTPD is kept while CONNMAN NTP is disabled, users like you won't be able to update their time.
  3. If we keep both sides as we did initially, someone will come running and say we're bombing the NTP server.
Version 1.7.1 is still bombarding my NTP server, even when overriding the /etc/ntp.conf file and will not sync time. Even if a stop the NTPD daemon. Based on the source port, my guess is the CONNMAND NTP is not disabled.
[root@glkvm:/etc/init.d]# bash S49ntp stop
Stopping ntpd: OK
[root@glkvm:/etc/kvmd/user/scripts]# date
Wed Dec 31 19:09:30 -05 1969
[root@glkvm:/etc/kvmd/user/scripts]# cat S20update_ntp.sh
#! /bin/sh
echo "server 192.168.69.5 iburst minpoll 6 maxpoll 8" > /etc/ntp.conf
09:00:15.690176 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0x10, ttl 64, id 50605, offset 0, flags [DF], proto UDP (17), length 76)
    192.168.69.60.43698 > 192.168.69.5.123: [udp sum ok] NTPv4, Client, length 48
	Leap indicator: clock unsynchronized (192), Stratum 0 (unspecified), poll 10 (1024s), precision 0
	Root Delay: 0.000000, Root dispersion: 0.000000, Reference-ID: (unspec)
	  Reference Timestamp:  0.000000000
	  Originator Timestamp: 0.000000000
	  Receive Timestamp:    0.000000000
	  Transmit Timestamp:   2208988816.019604573 (1970-01-01T00:00:16Z)
	    Originator - Receive Timestamp:  0.000000000
	    Originator - Transmit Timestamp: 2208988816.019604573 (1970-01-01T00:00:16Z)
09:00:15.690482 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 62322, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.43698: [bad udp cksum 0x0bdc -> 0xa64d!] NTPv4, Server, length 48
	Leap indicator:  (0), Stratum 1 (primary reference), poll 10 (1024s), precision -22
	Root Delay: 0.000000, Root dispersion: 0.001052, Reference-ID: GPS^@
	  Reference Timestamp:  3973327210.877357410 (2025-11-28T14:00:10Z)
	  Originator Timestamp: 2208988816.019604573 (1970-01-01T00:00:16Z)
	  Receive Timestamp:    3973327215.690285735 (2025-11-28T14:00:15Z)
	  Transmit Timestamp:   3973327215.690375269 (2025-11-28T14:00:15Z)
	    Originator - Receive Timestamp:  +1764338399.670681162
	    Originator - Transmit Timestamp: +1764338399.670770696
09:00:15.727802 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0x10, ttl 64, id 50608, offset 0, flags [DF], proto UDP (17), length 76)
    192.168.69.60.43384 > 192.168.69.5.123: [udp sum ok] NTPv4, Client, length 48
	  Transmit Timestamp:   2208988816.028469832 (1970-01-01T00:00:16Z)
	    Originator - Transmit Timestamp: 2208988816.028469832 (1970-01-01T00:00:16Z)
09:00:15.727953 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 15561, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.43384: [bad udp cksum 0x0bdc -> 0x334a!] NTPv4, Server, length 48
	  Originator Timestamp: 2208988816.028469832 (1970-01-01T00:00:16Z)
	  Receive Timestamp:    2208988816.028469832 (1970-01-01T00:00:16Z)
	    Originator - Receive Timestamp:  -0.000000000
	    Originator - Transmit Timestamp: -0.000000000
09:00:17.772805 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 50934, offset 0, flags [DF], proto UDP (17), length 76)
    192.168.69.60.123 > 192.168.69.5.123: [udp sum ok] NTPv4, Client, length 48
	Leap indicator: clock unsynchronized (192), Stratum 0 (unspecified), poll 6 (64s), precision -19
	Root Delay: 0.000000, Root dispersion: 0.000045, Reference-ID: (unspec)
	  Transmit Timestamp:   2208988818.167261478 (1970-01-01T00:00:18Z)
	    Originator - Transmit Timestamp: 2208988818.167261478 (1970-01-01T00:00:18Z)
09:00:20.607777 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0x10, ttl 64, id 51531, offset 0, flags [DF], proto UDP (17), length 76)
    192.168.69.60.43315 > 192.168.69.5.123: [udp sum ok] NTPv4, Client, length 48
	  Transmit Timestamp:   2208988821.000532250 (1970-01-01T00:00:21Z)
	    Originator - Transmit Timestamp: 2208988821.000532250 (1970-01-01T00:00:21Z)
09:00:22.608163 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0x10, ttl 64, id 51928, offset 0, flags [DF], proto UDP (17), length 76)
	  Transmit Timestamp:   2208988823.000627711 (1970-01-01T00:00:23Z)
	    Originator - Transmit Timestamp: 2208988823.000627711 (1970-01-01T00:00:23Z)
09:00:26.608682 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0x10, ttl 64, id 52581, offset 0, flags [DF], proto UDP (17), length 76)
	  Transmit Timestamp:   2208988827.000747852 (1970-01-01T00:00:27Z)
	    Originator - Transmit Timestamp: 2208988827.000747852 (1970-01-01T00:00:27Z)
09:00:26.608857 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 48226, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.43315: [bad udp cksum 0x0bdc -> 0xa5b0!] NTPv4, Server, length 48
	  Originator Timestamp: 2208988827.000747852 (1970-01-01T00:00:27Z)
	  Receive Timestamp:    2208988827.000747852 (1970-01-01T00:00:27Z)
09:00:31.608749 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0x10, ttl 64, id 53145, offset 0, flags [DF], proto UDP (17), length 76)
    192.168.69.60.55733 > 192.168.69.5.123: [udp sum ok] NTPv4, Client, length 48
	  Transmit Timestamp:   2208988832.000748783 (1970-01-01T00:00:32Z)
	    Originator - Transmit Timestamp: 2208988832.000748783 (1970-01-01T00:00:32Z)
09:00:33.608858 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0x10, ttl 64, id 53591, offset 0, flags [DF], proto UDP (17), length 76)
	  Transmit Timestamp:   2208988834.000807689 (1970-01-01T00:00:34Z)
	    Originator - Transmit Timestamp: 2208988834.000807689 (1970-01-01T00:00:34Z)
09:00:37.610414 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0x10, ttl 64, id 54220, offset 0, flags [DF], proto UDP (17), length 76)
	  Transmit Timestamp:   2208988838.001184176 (1970-01-01T00:00:38Z)
	    Originator - Transmit Timestamp: 2208988838.001184176 (1970-01-01T00:00:38Z)
09:00:37.610565 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 54789, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.55733: [bad udp cksum 0x0bdc -> 0xabc7!] NTPv4, Server, length 48
	  Originator Timestamp: 2208988838.001184176 (1970-01-01T00:00:38Z)
	  Receive Timestamp:    2208988838.001184176 (1970-01-01T00:00:38Z)
I had to add an IPTABLES rule to block non-port 123 NTP requests coming from CONNMAND. CONNMAN uses a random source port, NTPD uses source port 123.
#! /bin/sh
iptables -A OUTPUT -p udp --dport 123 ! --sport 123 -j DROP
Now NTPD can sync time.
09:20:07.125836 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 19960, offset 0, flags [DF], proto UDP (17), length 76)
	Leap indicator: clock unsynchronized (192), Stratum 0 (unspecified), poll 6 (64s), precision -20
	Root Delay: 0.000000, Root dispersion: 0.000122, Reference-ID: (unspec)
	  Transmit Timestamp:   2208988823.168078076 (1970-01-01T00:00:23Z)
	    Originator - Transmit Timestamp: 2208988823.168078076 (1970-01-01T00:00:23Z)
09:20:07.125986 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 13925, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x5c86!] NTPv4, Server, length 48
	Leap indicator:  (0), Stratum 1 (primary reference), poll 6 (64s), precision -22
	  Reference Timestamp:  3973328402.877348656 (2025-11-28T14:20:02Z)
	  Originator Timestamp: 2208988823.168078076 (1970-01-01T00:00:23Z)
	  Receive Timestamp:    3973328407.125872068 (2025-11-28T14:20:07Z)
	  Transmit Timestamp:   3973328407.125914862 (2025-11-28T14:20:07Z)
	    Originator - Receive Timestamp:  +1764339583.957793992
	    Originator - Transmit Timestamp: +1764339583.957836786
09:20:09.126016 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 20003, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.000152, Reference-ID: (unspec)
	  Originator Timestamp: 3973328407.125914862 (2025-11-28T14:20:07Z)
	  Receive Timestamp:    2208988823.169172336 (1970-01-01T00:00:23Z)
	  Transmit Timestamp:   2208988825.168341333 (1970-01-01T00:00:25Z)
	    Originator - Receive Timestamp:  -1764339583.956742525
	    Originator - Transmit Timestamp: -1764339581.957573528
09:20:09.126167 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 7138, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x133c!] NTPv4, Server, length 48
	Root Delay: 0.000000, Root dispersion: 0.001083, Reference-ID: GPS^@
	  Originator Timestamp: 2208988825.168341333 (1970-01-01T00:00:25Z)
	  Receive Timestamp:    3973328409.126058887 (2025-11-28T14:20:09Z)
	  Transmit Timestamp:   3973328409.126125270 (2025-11-28T14:20:09Z)
	    Originator - Receive Timestamp:  +1764339583.957717553
	    Originator - Transmit Timestamp: +1764339583.957783937
09:20:11.126599 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 20386, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.000183, Reference-ID: (unspec)
	  Originator Timestamp: 3973328409.126125270 (2025-11-28T14:20:09Z)
	  Receive Timestamp:    2208988825.169351395 (1970-01-01T00:00:25Z)
	  Transmit Timestamp:   2208988827.168924075 (1970-01-01T00:00:27Z)
	    Originator - Receive Timestamp:  -1764339583.956773875
	    Originator - Transmit Timestamp: -1764339581.957201195
09:20:11.126738 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 18073, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0xd7f2!] NTPv4, Server, length 48
	Root Delay: 0.000000, Root dispersion: 0.000991, Reference-ID: GPS^@
	  Reference Timestamp:  3973328410.884628582 (2025-11-28T14:20:10Z)
	  Originator Timestamp: 2208988827.168924075 (1970-01-01T00:00:27Z)
	  Receive Timestamp:    3973328411.126623742 (2025-11-28T14:20:11Z)
	  Transmit Timestamp:   3973328411.126688569 (2025-11-28T14:20:11Z)
	    Originator - Receive Timestamp:  +1764339583.957699667
	    Originator - Transmit Timestamp: +1764339583.957764494
09:20:13.125836 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 20905, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.000213, Reference-ID: (unspec)
	  Originator Timestamp: 3973328411.126688569 (2025-11-28T14:20:11Z)
	  Receive Timestamp:    2208988827.169557170 (1970-01-01T00:00:27Z)
	  Transmit Timestamp:   2208988829.168185523 (1970-01-01T00:00:29Z)
	    Originator - Receive Timestamp:  -1764339583.957131399
	    Originator - Transmit Timestamp: -1764339581.958503045
09:20:13.125948 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 8662, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x29df!] NTPv4, Server, length 48
	Root Delay: 0.000000, Root dispersion: 0.001022, Reference-ID: GPS^@
	  Originator Timestamp: 2208988829.168185523 (1970-01-01T00:00:29Z)
	  Receive Timestamp:    3973328413.125857091 (2025-11-28T14:20:13Z)
	  Transmit Timestamp:   3973328413.125915362 (2025-11-28T14:20:13Z)
	    Originator - Receive Timestamp:  +1764339583.957671568
	    Originator - Transmit Timestamp: +1764339583.957729838
09:20:17.125842 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 21700, offset 0, flags [DF], proto UDP (17), length 76)
	  Transmit Timestamp:   3973328417.125217127 (2025-11-28T14:20:17Z)
	    Originator - Transmit Timestamp: 3973328417.125217127 (2025-11-28T14:20:17Z)
09:20:17.125966 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 20214, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x9abe!] NTPv4, Server, length 48
	  Originator Timestamp: 3973328417.125217127 (2025-11-28T14:20:17Z)
	  Receive Timestamp:    3973328417.125865271 (2025-11-28T14:20:17Z)
	  Transmit Timestamp:   3973328417.125929800 (2025-11-28T14:20:17Z)
	    Originator - Receive Timestamp:  +0.000648143
	    Originator - Transmit Timestamp: +0.000712672
09:20:19.125803 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 22275, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.000076, Reference-ID: (unspec)
	  Originator Timestamp: 3973328417.125929800 (2025-11-28T14:20:17Z)
	  Receive Timestamp:    3973328417.126893991 (2025-11-28T14:20:17Z)
	  Transmit Timestamp:   3973328419.125210672 (2025-11-28T14:20:19Z)
	    Originator - Receive Timestamp:  +0.000964190
	    Originator - Transmit Timestamp: +1.999280872
09:20:19.125925 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 58991, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0xc473!] NTPv4, Server, length 48
	  Reference Timestamp:  3973328418.880425119 (2025-11-28T14:20:18Z)
	  Originator Timestamp: 3973328419.125210672 (2025-11-28T14:20:19Z)
	  Receive Timestamp:    3973328419.125826187 (2025-11-28T14:20:19Z)
	  Transmit Timestamp:   3973328419.125888659 (2025-11-28T14:20:19Z)
	    Originator - Receive Timestamp:  +0.000615515
	    Originator - Transmit Timestamp: +0.000677986
09:20:21.125783 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 22665, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.000106, Reference-ID: (unspec)
	  Originator Timestamp: 3973328419.125888659 (2025-11-28T14:20:19Z)
	  Receive Timestamp:    3973328419.126209860 (2025-11-28T14:20:19Z)
	  Transmit Timestamp:   3973328421.125222294 (2025-11-28T14:20:21Z)
	    Originator - Receive Timestamp:  +0.000321201
	    Originator - Transmit Timestamp: +1.999333635
09:20:21.125903 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 7824, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x4b50!] NTPv4, Server, length 48
	  Originator Timestamp: 3973328421.125222294 (2025-11-28T14:20:21Z)
	  Receive Timestamp:    3973328421.125801904 (2025-11-28T14:20:21Z)
	  Transmit Timestamp:   3973328421.125862763 (2025-11-28T14:20:21Z)
	    Originator - Receive Timestamp:  +0.000579610
	    Originator - Transmit Timestamp: +0.000640469
09:20:23.125739 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 23168, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.000137, Reference-ID: (unspec)
	  Originator Timestamp: 3973328421.125862763 (2025-11-28T14:20:21Z)
	  Receive Timestamp:    3973328421.125803062 (2025-11-28T14:20:21Z)
	  Transmit Timestamp:   3973328423.125190593 (2025-11-28T14:20:23Z)
	    Originator - Receive Timestamp:  -0.000059701
	    Originator - Transmit Timestamp: +1.999327829
09:20:23.125888 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 43291, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x7b43!] NTPv4, Server, length 48
	  Originator Timestamp: 3973328423.125190593 (2025-11-28T14:20:23Z)
	  Receive Timestamp:    3973328423.125776520 (2025-11-28T14:20:23Z)
	  Transmit Timestamp:   3973328423.125840695 (2025-11-28T14:20:23Z)
	    Originator - Receive Timestamp:  +0.000585927
	    Originator - Transmit Timestamp: +0.000650102
Looks like the file that requires the CONNMAN NTP setting to manual is the following
[root@glkvm:/etc/kvmd/user/connman]# cat settings
[global]
OfflineMode=false
TimeUpdates=manual
[Wired]
Enable=true
Tethering=false
Tethering.Freq=2412
Setting it in the main.conf file does nothing.
[root@glkvm:/etc/connman]# cat main.conf
[General]
TimeUpdates=manual
No way. The /etc/kvmd/user/connman directory isn't included in the firmware. This is dynamically generated by Connman, and there's no way to automatically add something to it.
Fuck it, I'll just disable it by modifying the connman source code directly.
I performed a local upgrade and kept previous settings. Maybe the directory persists if you keep settings.
BTW, still have to disable the LED status to stop bombarding public DNS servers with ICMP pings. I also block all internet traffic from the GL-RM1 since it keeps phoning home even with cloud access disabled.
[root@glkvm:/etc/kvmd/user/scripts]# cat S10block_icmp.sh
#! /bin/sh
# Stop DNS ping flood
/bin/sh /etc/init.d/S23led stop
# Allow LAN
iptables -I OUTPUT 1 -s 192.168.69.60 -d 192.168.69.0/24 -j ACCEPT
# Block everything else
iptables -I OUTPUT 2 -s 192.168.69.60 -j DROP
We're unlikely to modify ICMP anymore. Even if we switch to HTTP packets for network detection, it would only make packet sniffing more difficult. In fact,CONNMAN itself already implements similar functionality.
new firmeware has been uploaded https://fw.gl-inet.com/kvm/rm1/release/glkvm-RM1-1.7.2-1128-1764342299.img
Thanks for the quick turn. Although CONNMAN NTP appears to be disabled, NTPD is still bombarding my NTP server and can’t sync time.
[root@glkvm:~]# date
Wed Dec 31 19:04:08 -05 1969
10:31:03.144748 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 10782, offset 0, flags [DF], proto UDP (17), length 76)
    192.168.69.60.123 > 162.159.200.123.123: [udp sum ok] NTPv4, Client, length 48
	Root Delay: 0.000000, Root dispersion: 0.003005, Reference-ID: (unspec)
	  Transmit Timestamp:   2208989015.390779318 (1970-01-01T00:03:35Z)
	    Originator - Transmit Timestamp: 2208989015.390779318 (1970-01-01T00:03:35Z)
10:31:04.144670 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 19834, offset 0, flags [DF], proto UDP (17), length 76)
    192.168.69.60.123 > 119.28.230.190.123: [udp sum ok] NTPv4, Client, length 48
	Root Delay: 0.000000, Root dispersion: 0.003021, Reference-ID: (unspec)
	  Transmit Timestamp:   2208989016.390716892 (1970-01-01T00:03:36Z)
	    Originator - Transmit Timestamp: 2208989016.390716892 (1970-01-01T00:03:36Z)
10:31:05.144662 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 933, offset 0, flags [DF], proto UDP (17), length 76)
    192.168.69.60.123 > 45.79.51.42.123: [udp sum ok] NTPv4, Client, length 48
	Root Delay: 0.000000, Root dispersion: 0.003036, Reference-ID: (unspec)
	  Transmit Timestamp:   2208989017.390738020 (1970-01-01T00:03:37Z)
	    Originator - Transmit Timestamp: 2208989017.390738020 (1970-01-01T00:03:37Z)
10:32:08.145028 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 34151, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.003982, Reference-ID: (unspec)
	  Transmit Timestamp:   2208989080.391825366 (1970-01-01T00:04:40Z)
	    Originator - Transmit Timestamp: 2208989080.391825366 (1970-01-01T00:04:40Z)
10:32:10.143905 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 29849, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.004013, Reference-ID: (unspec)
	  Transmit Timestamp:   2208989082.390750617 (1970-01-01T00:04:42Z)
	    Originator - Transmit Timestamp: 2208989082.390750617 (1970-01-01T00:04:42Z)
10:32:10.143966 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 20133, offset 0, flags [DF], proto UDP (17), length 76)
	  Transmit Timestamp:   2208989082.390893395 (1970-01-01T00:04:42Z)
	    Originator - Transmit Timestamp: 2208989082.390893395 (1970-01-01T00:04:42Z)
10:33:14.143115 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 24038, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.004974, Reference-ID: (unspec)
	  Transmit Timestamp:   2208989146.390742437 (1970-01-01T00:05:46Z)
	    Originator - Transmit Timestamp: 2208989146.390742437 (1970-01-01T00:05:46Z)
10:33:15.143123 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 44935, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.004989, Reference-ID: (unspec)
	  Transmit Timestamp:   2208989147.390757772 (1970-01-01T00:05:47Z)
	    Originator - Transmit Timestamp: 2208989147.390757772 (1970-01-01T00:05:47Z)
10:33:17.143088 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 34563, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000000, Root dispersion: 0.005020, Reference-ID: (unspec)
	  Transmit Timestamp:   2208989149.390767604 (1970-01-01T00:05:49Z)
	    Originator - Transmit Timestamp: 2208989149.390767604 (1970-01-01T00:05:49Z)
I had to manually reboot the GL-RM1 after the firmware update. Now it seems to sync time.
10:35:13.484824 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 19176, offset 0, flags [DF], proto UDP (17), length 76)
	  Transmit Timestamp:   2208988818.170635416 (1970-01-01T00:00:18Z)
	    Originator - Transmit Timestamp: 2208988818.170635416 (1970-01-01T00:00:18Z)
10:35:13.485025 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 2511, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0xb9d1!] NTPv4, Server, length 48
	  Reference Timestamp:  3973332906.886961214 (2025-11-28T15:35:06Z)
	  Originator Timestamp: 2208988818.170635416 (1970-01-01T00:00:18Z)
	  Receive Timestamp:    3973332913.484878113 (2025-11-28T15:35:13Z)
	  Transmit Timestamp:   3973332913.484928420 (2025-11-28T15:35:13Z)
	    Originator - Receive Timestamp:  +1764344095.314242696
	    Originator - Transmit Timestamp: +1764344095.314293003
10:35:15.484707 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 19254, offset 0, flags [DF], proto UDP (17), length 76)
	  Originator Timestamp: 3973332913.484928420 (2025-11-28T15:35:13Z)
	  Receive Timestamp:    2208988818.171292474 (1970-01-01T00:00:18Z)
	  Transmit Timestamp:   2208988820.170541870 (1970-01-01T00:00:20Z)
	    Originator - Receive Timestamp:  -1764344095.313635945
	    Originator - Transmit Timestamp: -1764344093.314386550
10:35:15.484833 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 9706, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x4133!] NTPv4, Server, length 48
	  Reference Timestamp:  3973332914.877505955 (2025-11-28T15:35:14Z)
	  Originator Timestamp: 2208988820.170541870 (1970-01-01T00:00:20Z)
	  Receive Timestamp:    3973332915.484736444 (2025-11-28T15:35:15Z)
	  Transmit Timestamp:   3973332915.484784313 (2025-11-28T15:35:15Z)
	    Originator - Receive Timestamp:  +1764344095.314194574
	    Originator - Transmit Timestamp: +1764344095.314242443
10:35:17.484603 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 19263, offset 0, flags [DF], proto UDP (17), length 76)
	  Originator Timestamp: 3973332915.484784313 (2025-11-28T15:35:15Z)
	  Receive Timestamp:    2208988820.171120574 (1970-01-01T00:00:20Z)
	  Transmit Timestamp:   2208988822.170439082 (1970-01-01T00:00:22Z)
	    Originator - Receive Timestamp:  -1764344095.313663738
	    Originator - Transmit Timestamp: -1764344093.314345231
10:35:17.484747 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 43118, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x7b5e!] NTPv4, Server, length 48
	  Originator Timestamp: 2208988822.170439082 (1970-01-01T00:00:22Z)
	  Receive Timestamp:    3973332917.484630080 (2025-11-28T15:35:17Z)
	  Transmit Timestamp:   3973332917.484700083 (2025-11-28T15:35:17Z)
	    Originator - Receive Timestamp:  +1764344095.314190998
	    Originator - Transmit Timestamp: +1764344095.314261001
10:35:19.484642 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 19331, offset 0, flags [DF], proto UDP (17), length 76)
	  Originator Timestamp: 3973332917.484700083 (2025-11-28T15:35:17Z)
	  Receive Timestamp:    2208988822.171058961 (1970-01-01T00:00:22Z)
	  Transmit Timestamp:   2208988824.170507424 (1970-01-01T00:00:24Z)
	    Originator - Receive Timestamp:  -1764344095.313641122
	    Originator - Transmit Timestamp: -1764344093.314192659
10:35:19.484750 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 59145, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0xa4b0!] NTPv4, Server, length 48
	  Originator Timestamp: 2208988824.170507424 (1970-01-01T00:00:24Z)
	  Receive Timestamp:    3973332919.484666974 (2025-11-28T15:35:19Z)
	  Transmit Timestamp:   3973332919.484714451 (2025-11-28T15:35:19Z)
	    Originator - Receive Timestamp:  +1764344095.314159550
	    Originator - Transmit Timestamp: +1764344095.314207026
10:35:23.484711 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 20010, offset 0, flags [DF], proto UDP (17), length 76)
	  Transmit Timestamp:   3973332923.484395402 (2025-11-28T15:35:23Z)
	    Originator - Transmit Timestamp: 3973332923.484395402 (2025-11-28T15:35:23Z)
10:35:23.484850 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 41775, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x3486!] NTPv4, Server, length 48
	  Reference Timestamp:  3973332922.877506761 (2025-11-28T15:35:22Z)
	  Originator Timestamp: 3973332923.484395402 (2025-11-28T15:35:23Z)
	  Receive Timestamp:    3973332923.484735173 (2025-11-28T15:35:23Z)
	  Transmit Timestamp:   3973332923.484813234 (2025-11-28T15:35:23Z)
	    Originator - Receive Timestamp:  +0.000339770
	    Originator - Transmit Timestamp: +0.000417831
10:35:25.484812 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 20563, offset 0, flags [DF], proto UDP (17), length 76)
	  Originator Timestamp: 3973332923.484813234 (2025-11-28T15:35:23Z)
	  Receive Timestamp:    3973332923.485429444 (2025-11-28T15:35:23Z)
	  Transmit Timestamp:   3973332925.484507473 (2025-11-28T15:35:25Z)
	    Originator - Receive Timestamp:  +0.000616209
	    Originator - Transmit Timestamp: +1.999694239
10:35:25.484941 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 33345, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x2523!] NTPv4, Server, length 48
	  Originator Timestamp: 3973332925.484507473 (2025-11-28T15:35:25Z)
	  Receive Timestamp:    3973332925.484838577 (2025-11-28T15:35:25Z)
	  Transmit Timestamp:   3973332925.484888586 (2025-11-28T15:35:25Z)
	    Originator - Receive Timestamp:  +0.000331103
	    Originator - Transmit Timestamp: +0.000381113
10:35:27.484793 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 21140, offset 0, flags [DF], proto UDP (17), length 76)
	  Originator Timestamp: 3973332925.484888586 (2025-11-28T15:35:25Z)
	  Receive Timestamp:    3973332925.485576504 (2025-11-28T15:35:25Z)
	  Transmit Timestamp:   3973332927.484522447 (2025-11-28T15:35:27Z)
	    Originator - Receive Timestamp:  +0.000687917
	    Originator - Transmit Timestamp: +1.999633860
10:35:27.484905 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 39811, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x060b!] NTPv4, Server, length 48
	  Originator Timestamp: 3973332927.484522447 (2025-11-28T15:35:27Z)
	  Receive Timestamp:    3973332927.484813954 (2025-11-28T15:35:27Z)
	  Transmit Timestamp:   3973332927.484869570 (2025-11-28T15:35:27Z)
	    Originator - Receive Timestamp:  +0.000291507
	    Originator - Transmit Timestamp: +0.000347122
10:35:29.484563 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 21419, offset 0, flags [DF], proto UDP (17), length 76)
	  Originator Timestamp: 3973332927.484869570 (2025-11-28T15:35:27Z)
	  Receive Timestamp:    3973332927.485582858 (2025-11-28T15:35:27Z)
	  Transmit Timestamp:   3973332929.484309210 (2025-11-28T15:35:29Z)
	    Originator - Receive Timestamp:  +0.000713288
	    Originator - Transmit Timestamp: +1.999439639
10:35:29.484689 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 46274, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x45ad!] NTPv4, Server, length 48
	  Originator Timestamp: 3973332929.484309210 (2025-11-28T15:35:29Z)
	  Receive Timestamp:    3973332929.484583856 (2025-11-28T15:35:29Z)
	  Transmit Timestamp:   3973332929.484652993 (2025-11-28T15:35:29Z)
	    Originator - Receive Timestamp:  +0.000274646
	    Originator - Transmit Timestamp: +0.000343783
10:36:01.484197 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 23526, offset 0, flags [DF], proto UDP (17), length 76)
	Leap indicator: clock unsynchronized (192), Stratum 2 (secondary reference), poll 6 (64s), precision -20
	Root Delay: 0.000869, Root dispersion: 0.939239, Reference-ID: 0xc0a84505
	  Reference Timestamp:  3973332929.485261087 (2025-11-28T15:35:29Z)
	  Originator Timestamp: 3973332929.484652993 (2025-11-28T15:35:29Z)
	  Receive Timestamp:    3973332929.485261087 (2025-11-28T15:35:29Z)
	  Transmit Timestamp:   3973332961.484380083 (2025-11-28T15:36:01Z)
	    Originator - Receive Timestamp:  +0.000608093
	    Originator - Transmit Timestamp: +31.999727089
10:36:01.484458 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 44275, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x2e48!] NTPv4, Server, length 48
	  Reference Timestamp:  3973332954.882265653 (2025-11-28T15:35:54Z)
	  Originator Timestamp: 3973332961.484380083 (2025-11-28T15:36:01Z)
	  Receive Timestamp:    3973332961.484263968 (2025-11-28T15:36:01Z)
	  Transmit Timestamp:   3973332961.484340583 (2025-11-28T15:36:01Z)
	    Originator - Receive Timestamp:  -0.000116115
	    Originator - Transmit Timestamp: -0.000039499
10:37:03.483494 94:83:c4:bb:17:1f > 64:62:66:21:c8:41, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 38944, offset 0, flags [DF], proto UDP (17), length 76)
	Root Delay: 0.000564, Root dispersion: 0.440139, Reference-ID: 0xc0a84505
	  Reference Timestamp:  3973332961.485028116 (2025-11-28T15:36:01Z)
	  Originator Timestamp: 3973332961.484340583 (2025-11-28T15:36:01Z)
	  Receive Timestamp:    3973332961.485028116 (2025-11-28T15:36:01Z)
	  Transmit Timestamp:   3973333023.484356274 (2025-11-28T15:37:03Z)
	    Originator - Receive Timestamp:  +0.000687533
	    Originator - Transmit Timestamp: +62.000015690
10:37:03.483708 64:62:66:21:c8:40 > 94:83:c4:bb:17:1f, ethertype IPv4 (0x0800), length 90: (tos 0xb8, ttl 64, id 16739, offset 0, flags [none], proto UDP (17), length 76)
    192.168.69.5.123 > 192.168.69.60.123: [bad udp cksum 0x0bdc -> 0x7a7f!] NTPv4, Server, length 48
	  Reference Timestamp:  3973333018.892446509 (2025-11-28T15:36:58Z)
	  Originator Timestamp: 3973333023.484356274 (2025-11-28T15:37:03Z)
	  Receive Timestamp:    3973333023.483574236 (2025-11-28T15:37:03Z)
	  Transmit Timestamp:   3973333023.483627079 (2025-11-28T15:37:03Z)
	    Originator - Receive Timestamp:  -0.000782037
	    Originator - Transmit Timestamp: -0.000729194
So, it worked?
Only after a second reboot.
Looks like CONNMAN is still generating the files upon boot up, but before time is sync’ed, thus the files have a time stamp from Unix epoch time of December 31, 1969
[root@glkvm:/etc/kvmd/user/connman]# ls -l --full-time
total 8
drwx------ 2 root root 4096 1969-12-31 19:00:16.106668271 -0500 ethernet_9483c4bb171f_cable
-rw------- 1 root root  103 1969-12-31 19:00:08.403334164 -0500 settings
Based on feedback from another user, I updated the online firmware. You may not receive the push notification.
If you're interested, you can manually flash this firmware.
https://drive.google.com/file/d/1S5fFGPWa-iUH-If5K5lbqyiERZj4vncc/view?usp=sharing
the version number is the same
I downloaded from the previous link you provided.
MD5SUMs are different
m1mbp:Downloads$ md5sum update\ \(6\).img
fe794cf4b7844b36bf7ac54e92991d09  update (6).img
m1mbp:Downloads$ md5sum glkvm-RM1-1.7.2-1128-1764342299.img
b5b32776a0c81d2697f5084cd48a4ea6  glkvm-RM1-1.7.2-1128-1764342299.img
m1mbp:Downloads$ md5sum glkvm-RM1-1.7.1-1128-1764293143.img
3df487b978f748ab9755e0064d798c5f  glkvm-RM1-1.7.1-1128-1764293143.img
m1mbp:Downloads$
yeah , I add a path but doesn’t change the version number
