https://dl.gl-inet.com/?model=axt1800&type=beta
V4.0.1 Beta 1 is out for AXT1800 Slate AX.
Bug Fix:
Fix the problem that the VPN Danshboard cannot be configured.
Fixed the issue that the wireless power could not be modified in some cases.
Fix the problem that THE 5G channel cannot be set to 149-165.
Rectify the error of collecting statistics about the size of network storage files.
Fix the problem that glinet management page cannot be accessed after luci plug-in is installed.
Fixed unauthorized access via RTTY.
New features:
LUCI supports Chinese by default.
Supports IPV6 DDNS.
Bypass mode is supported.
Remaining issues:
WIFI crash when repeater reaches part of hotspot.
Some SD cards cannot be identified.
