AXT1800 Open WRT 24 release to setup a net bird VXLAN
Hello
I have 2 AXT1800 glinet router and I would like use Netbird VPN but apparently I need to have Open WRT 24 can you tell me When it will be released on AXT1800?
On the current GL firmware v4.8.2 of AXT1800/AX1800, Netbird can be installed, here you go:
Hello
the tutorial doesn’t work.
the terminal say: arch: not found
Hello I had to installa nano to try to install the customfeeds
but it’s Impossible to download the packages wget return 8
I’m in 23.05.SNAPSHOT can you send me a valid link for the packages?
if you are fluent with CLI , you could try vanilla OpenWRT:
Snapshots do not include web GUI Luci, which you can install with:
apk update; apk add luci nano
Checked in my AX1800, netbrid installed normally:
root@GL-AX1800:~# opkg update
Downloading https://archive.openwrt.org/releases/23.05.0/packages/aarch64_cortex-a53/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/package
Downloading https://archive.openwrt.org/releases/23.05.0/packages/aarch64_cortex-a53/base/Packages.gz
Updated list of available packages in /var/opkg-lists/base
Downloading https://archive.openwrt.org/releases/23.05.0/packages/aarch64_cortex-a53/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/luci
Downloading https://archive.openwrt.org/releases/23.05.0/packages/aarch64_cortex-a53/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/routing
Downloading https://archive.openwrt.org/releases/23.05.0/packages/aarch64_cortex-a53/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/telephony
Downloading https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/kmod-5.4.164/aarch64_cortex-a53_neon-vfpv4/ipq60xx/Packages.gz
Updated list of available packages in /var/opkg-lists/glinet_core
Downloading https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/packages-5.0/aarch64_cortex-a53_neon-vfpv4/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/opnwrt_packages
Updating database.
Database update completed.
root@GL-AX1800:~#
root@GL-AX1800:~# opkg install netbird
Installing netbird (0.24.3-1) to root...
Downloading https://archive.openwrt.org/releases/23.05.0/packages/aarch64_cortex-a53/packages/netbird_0.24.3-1_aarch64_cortex-a53.ipk
Configuring netbird.
Updating database.
root@GL-AX1800:~# netbird version
0.24.3
Did you complete step two in that tutorial?
