Question:
DD-WRT for ar300m NAND available ? It can be GL.iNet ar300m NAND, are equal router from other company.
https://www.dd-wrt.com/wiki/index.php/Supported_Devices#GL.iNet
Question:
After DD-WRT or other 3`rt party firmware, its possible to restore original GL-iNet Firmware by Uboot Web UI?
rk47
April 28, 2018, 6:06am
2
Yes, but the last time I checked, DD-WRT did not support DNSSEC / DNScrypt so I dont see a compelling reason to use it since there is no package manager.
https://www.reddit.com/r/networking/comments/8emrwb/hijack_of_amazons_internet_domain_service_used_to/
https://blog.thousandeyes.com/amazon-route-53-dns-and-bgp-hijack/
Is there any way the dnscrypt-proxy package on the gl-inet repository could be updated?
It’s currently pushing v 1.4.3, whereas the author’s github makes v 1.9.4 available. v 1.4.3 seems to have issues binding its socket on some hardware (I’ve been trying to get it to work on the ‘azure’ all day) and consequently won’t operate as designed; this is reported to be resolved in subsequent package updates.
Many thanks,
Support DNSSEC / DNScrypt by Open WRT sound interresting. A I dont find a menue for this on Open WRT.
menue like the follow will be ideal:
Many thanks,
Support of non dangerous NTP version will be great feature on Open WRT too.
For v2.27 firmware, dnscrypt-proxy has update to 1.9.4.
Ok, the dnscrypt-proxy has update to 1.9.4. Thats sounds good.
A how to find releated menues like the follow for config?
Please add support for DNScrypt + DNSSEC from DNScrypt.nl !
Or make it work like Tomato firmware, with easy menu:
[DNScrypt menu - Tomato firmware]
It doesn’t support now, we will consider adding this feature.
Secure DNS and NTP by web menue will be a great value feature.
2.27 has given me nothing but problems for real
