I am looking for a table which show the different Open VPN speed of GL.iNet router.
It can be i have seen a table on old gl-inet webpage. Dont find again.
See also:
Collectet information about VPN speed, see the follow collected data:
The VPN speed is limited by some thinks like:
100 MBit Ethernet to max 12 MB/s
1000 MBit Ethernet to max 120 MB/s
your internet connection
CPU of GL router
aso.
GL.iNet 6416A, Atheros AR9331 @400 MHz: ? MB/s
MT300A, MTK 7620A @580Mhz : ? MB/s
MT300N, MTK 7620N @580Mhz : 6 MB/s
AR-150, Atheros AR9331 @400 MHz: Ethernet and WiFi up to 8 MB/s
MT300M-V2, @580 MHz CPU: 6-10 MB/s download and upload 3-6 MB/s
GL-AR300, Atheros 9344 74kc @(560 MHz ?) CPU:
AR-300M/M-16/MD, Qualcomm Atheros QCA9531 @650 MHz, 8 to 12 MB/s
AR-750, QCA9531 WiSoC @650MHz CPU: 10 to 12 MB/s
GL-B1300, Qualcomm IPQ4028, 4 cores @ 717MHz, 12 to 18 MB/s
AR750S, Qualcomm Atheros QCA9563@775MHz (4Cores?): up to 17 MB/s
The data are found on forum. Its not clear the data are true and its not clear the speed is shown by UDP or TCP. All processors looking like without hardware crypto
If you see mistakes on my small table, please tell.
If they are a official table about Open VPN Speed, please tell a link.
Source of router data: https://wikidevi.com/w/index.php?search=GL.iNet&title=Special%3ASearch&go=Go
alzhao
September 3, 2018, 8:27am
#3
I have some data. Will upload to the wikidevi
GL VPN Speed List from 2020-06
The tecnical limitation of VPN speed of router:
100 MBit/s Ethernet = 12 MB/s
1000 MBit/s Ethernet = 120 MB/s
CPU of GL router
aso.
What different sources on internet say:
GL.iNet 6416A, Atheros AR9331 @400 MHz: ? MBit/s
MT300A, MTK 7620A @580Mhz : ? MBit/s
MT300N, MTK 7620N @580Mhz : 6 MBit/s
MT300M-V2, @580 MHz CPU: 6-10 MBit/s download and upload 3-6 MBit/s
What gl say:
GL-USB150: 7 MBit/s Open VPN, WireGuard VPN 35 MBit/s, source GL-USB150 / microuter - GL.iNet
GL-AR150: 7 MBit/s Open VPN, WireGuard VPN 35 MBit/s, source GL-AR150 / White - GL.iNet
GL-AR300M Series: 15 MBit/s Open VPN, WireGuard VPN 50 MBit/s, source GL-AR300M Series / Shadow - GL.iNet
GL-AR750: 15 MBit/s Open VPN, WireGuard VPN 50 MBit/s, source GL-AR750 / Creta - GL.iNet
GL-AR750s: 17 MBit/s Open VPN, WireGuard VPN 68 MBit/s, source GL-AR750S-Ext / Slate - GL.iNet
GL-MV1000 / GL-MV1000W: 97 MBit/s Open VPN, WireGuard VPN 280 MBit/s, source GL-MV1000 / Brume - GL.iNet
By the way:
