We are pleased to announce Beta Testing of our GoodCloud platform www.goodcloud.xyz. Your feedback will be highly appreciated.
Core features:
- Check live router status, including online/offline, RAM, system load, LTE Signal etc.
- Set up router remotely, e.g. changing SSID and Key.
- Monitoring clients connected to your router. You can also see real-time traffic of each client (need to enable in router first) or block specific client.
- Operate routers in batch, e.g. batch reboot, upgrade etc.
- Manage routers in groups and list routers in one page.
- Site to Site.
How to enable and use this service:
Note: You have to upgrade to firmware v3.021 manually. Please check instructions below.
Note: To enable GoodCloud service, please check the docs here : https://docs.gl-inet.com/en/3/app/cloud/.
Here is the screenshot of Web Admin Panel.
Her is the screenshot of GoodCloud.
Firmware download:
GL-X750(Spitz) testing firmware download
GL-AR750S(Slate) testing firmware download
GL-AR750(Creta) testing firmware download
GL-B1300(Convexa-B) testing firmware download
GL-AR150(White) testing firmware download
GL-AR300M(Shadow) testing firmware download
GL-MT300N-V2(Mango) testing firmware download
GL-MT300A testing firmware download
GL-MT300N testing firmware download
For GL-USB150, it can use GoodCloud too, but it only can be binded to GoodCloud by “Auto discover”
GL-USB150 testing firmware download
About Security:
- The data transmission between the router and the cloud is encrypted.
- Your WiFi key and other password will not be upload to the cloud.
- Only basic setting of your router is not stored in the cloud. Most of your settings is set to your router directly.
- There are three regions (server clusters) for you to choose: Europe, America and Global (rest of the world). Data are not shared across regions. So you need to bind your device only to one region. It will not appear in other regions.
- You can turn off GoodCloud service any time on your router. Your router will display if your device is bound by any users.
Another thread about GoodCloud
