New Beryl MT1300n plug in USB HD nothing happens?
Hi… bought this to connect USB drive so I can view files over SMB on windows or watch videos from the HD on my Oculus Quest.
I thought it was simple plug and play but doesn’t seem so.
The same 2 HD’s can be plugged into my BT home router and shows up in SMB without any issues.
I have tried powering the HD externally but still doesn’t show up.
On my windows and Oculusd I see the folder GL-Samba but its empty and nothing else.
Driving me nuts… but I’m guessing its a simple issue and I’m missing something. Please help
Have you followed the tutorial? LMGTFY: File Sharing - GL.iNet Docs
Did you set up sharing in the UI?
To make sure your HDD is mounted correctly, ssh to the router and use the following command
mount
df
Yes I have followed this, the HD just doesn’t show up, tried different HD and SSDs
I’ll try tonight. So just SSH into router. “mount” then press enter? Then “df” enter?
I did this and this is what I see -
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 14592 14592 0 100% /rom
tmpfs 126564 1336 125228 1% /tmp
/dev/mtdblock6 15936 3996 11940 25% /overlay
overlayfs:/overlay 15936 3996 11940 25% /
tmpfs 512 0 512 0% /dev
What does it mean?
I have an SD card and a USD HD plugged in
I have again reset the device. Followed the guide again exactly on file sharing.
I manage to get into \192.168.8.1 in both windows and android and in both I do not see whatever USB drive I plus in, all I see is the folder GL-Samba
I am very close to returning this. Please help troubleshoot
From your output, your USB HD is not recoginized.
Pls use get the log using the following command. You can also get the log in Luci (advanced settings)
dmesg
logread
Here is what it says after dmesg -
[11278.352146] scan_ch_restore,central ch=42,bw=2
[11278.352146]
[11278.505466] AP SETKEYS DONE - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=5 from E0:D4:E8:37:9A:A6
[11278.505466]
[11281.697158] /home/zjh/openwrt/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/mt7615-5.0.3.0/mt_wifi_ap/…/mt_wifi/embedded/common/scan.c:99 assert (ch != 0)failed
[11281.712263] CPU: 1 PID: 2629 Comm: RtmpMlmeTask Not tainted 4.14.221 #0
[11281.718848] Stack : 00000000 00532158 00000001 8007345c 80600000 8059f784 00000000 00000000
[11281.727188] 8056912c 8c25bdd4 8fd1631c 805dc9c7 80563ec0 00000001 8c25bd78 ac07f5c4
[11281.735522] 00000000 00000000 80740000 00016128 00000000 000012ab 00000007 00000000
[11281.743853] 00000000 805e0000 000ade47 00000000 00000000 80600000 00000000 00000000
[11281.752188] c11b44b8 8d72b6ec 00000001 00532158 00000002 802c34c0 00000004 80740004
[11281.760523] …
[11281.762961] Call Trace:
[11281.765427] [<8000c7b0>] show_stack+0x58/0x100
[11281.769874] [<8049cf04>] dump_stack+0xa4/0xe0
[11281.775464] [<8d50747c>] scan_ch_restore+0x84/0x4bc [mt_wifi]
[11281.781972] [<8d4f2d04>] MlmeHandler+0x58c/0x760 [mt_wifi]
[11281.788298] [<8d4f2e68>] MlmeHandler+0x6f0/0x760 [mt_wifi]
After logread -
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 0.000000] Linux version 4.14.221 (zjh@ubuntu) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11306-c4a6851c72)) #0 SMP Mon Feb 15 15:22:37 2021
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] SoC Type: MediaTek MT7621 ver:1 eco:3
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] CPU0 revision is: 0001992f (MIPS 1004Kc)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] MIPS: machine is GL-MT1300
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Determined physical RAM map:
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] memory: 10000000 @ 00000000 (usable)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] VPE topology {2,2} total 4
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.000000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Zone ranges:
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x000000000fffffff]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] HighMem empty
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Movable zone start for each node
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Early memory node ranges
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x000000000fffffff]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000000fffffff]
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 0.000000] On node 0 totalpages: 65536
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 80603fa0, node_mem_map 81003000
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 0.000000] Normal zone: 512 pages used for memmap
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 0.000000] Normal zone: 65536 pages, LIFO batch:15
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x9c/0x4c4 with crng_init=0
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] percpu: Embedded 14 pages/cpu s26224 r8192 d22928 u57344
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 0.000000] pcpu-alloc: s26224 r8192 d22928 u57344 alloc=144096
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65024
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Writing ErrCtl register=00058803
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Readback ErrCtl register=00058803
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Memory: 251880K/262144K available (4844K kernel code, 251K rwdata, 1064K rodata, 1252K init, 261K bss, 10264K reserved, 0K cma-reserved, 0K highmem)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] Hierarchical RCU implementation.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] NR_IRQS: 256
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] CPU Clock: 880MHz
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] clocksource: GIC: mask: 0xffffffffffffffff max_cycles: 0xcaf478abb4, max_idle_ns: 440795247997 ns
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 4343773742 ns
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.000010] sched_clock: 32 bits at 440MHz, resolution 2ns, wraps every 4880645118ns
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.007853] Calibrating delay loop… 586.13 BogoMIPS (lpj=2930688)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.074002] pid_max: default: 32768 minimum: 301
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.078790] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.085300] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.094603] Hierarchical SRCU implementation.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.099920] smp: Bringing up secondary CPUs …
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.106073] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.106082] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.106096] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.106259] CPU1 revision is: 0001992f (MIPS 1004Kc)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.164707] Synchronize counters for CPU 1: done.
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.206305] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.206314] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.206322] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.206404] CPU2 revision is: 0001992f (MIPS 1004Kc)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.256016] Synchronize counters for CPU 2: done.
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.287368] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.287376] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.287383] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.287477] CPU3 revision is: 0001992f (MIPS 1004Kc)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.341206] Synchronize counters for CPU 3: done.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.371068] smp: Brought up 1 node, 4 CPUs
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.378955] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.388771] futex hash table entries: 1024 (order: 3, 32768 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.395156] pinctrl core: initialized pinctrl subsystem
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 0.402124] NET: Registered protocol family 16
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 0.417870] FPU Affinity set after 11720 emulations
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.418878] pull PCIe RST: RALINK_RSTCTRL = 4000000
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.724158] release PCIe RST: RALINK_RSTCTRL = 7000000
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.729192] ***** Xtal 40MHz *****
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.732567] release PCIe RST: RALINK_RSTCTRL = 7000000
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.737675] Port 0 N_FTS = 1b102800
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.741117] Port 1 N_FTS = 1b102800
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 0.744571] Port 2 N_FTS = 1b102800
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 1.899755] PCIE1 no card, disable it(RST&CLK)
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 1.904101] PCIE2 no card, disable it(RST&CLK)
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 1.908506] → 21007f2
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 1.910937] PCIE0 enabled
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.913532] PCI host bridge /pcie@1e140000 ranges:
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.918290] MEM 0x0000000060000000…0x000000006fffffff
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.923474] IO 0x000000001e160000…0x000000001e16ffff
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 1.928641] PCI coherence region base: 0xbfbf8000, mask/settings: 0x60000000
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.947145] mt7621_gpio 1e000600.gpio: registering 32 gpios
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.953006] mt7621_gpio 1e000600.gpio: registering 32 gpios
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.958839] mt7621_gpio 1e000600.gpio: registering 32 gpios
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.966222] i2c-mt7621 1e000900.i2c: clock 100KHz, re-start not support
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.973534] PCI host bridge to bus 0000:00
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.977568] pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fffffff]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.984414] pci_bus 0000:00: root bus resource [io 0xffffffff]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.990251] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 1.997007] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.004912] pci 0000:00:00.0: [0e8d:0801] type 01 class 0x060400
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.004957] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x7fffffff]
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.004968] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.005038] pci 0000:00:00.0: supports D1
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.005047] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.005362] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.013507] pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.013581] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit]
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.013933] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.013960] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.014044] pci 0000:00:00.0: BAR 0: no space for [mem size 0x80000000]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.020562] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x80000000]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.027500] pci 0000:00:00.0: BAR 8: assigned [mem 0x60000000-0x600fffff]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.034209] pci 0000:00:00.0: BAR 1: assigned [mem 0x60100000-0x6010ffff]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.040979] pci 0000:01:00.0: BAR 0: assigned [mem 0x60000000-0x600fffff 64bit]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.048223] pci 0000:00:00.0: PCI bridge to [bus 01]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.053150] pci 0000:00:00.0: bridge window [mem 0x60000000-0x600fffff]
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.061571] clocksource: Switched to clocksource GIC
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.068480] NET: Registered protocol family 2
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.073694] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.080586] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.087032] TCP: Hash tables configured (established 2048 bind 2048)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.093466] UDP hash table entries: 256 (order: 1, 8192 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.099241] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.105737] NET: Registered protocol family 1
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 2.110065] PCI: CLS 0 bytes, default 32
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.341507] 4 CPUs re-calibrate udelay(lpj = 2924544)
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 2.348248] Crashlog allocated RAM at address 0x3f00000
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.353733] workingset: timestamp_bits=30 max_order=16 bucket_order=0
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.364905] random: fast init done
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.371384] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.377243] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.390788] io scheduler noop registered
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.394701] io scheduler deadline registered (default)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.401007] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.410840] console [ttyS0] disabled
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.414466] 1e000c00.uartlite: ttyS0 at MMIO 0x1e000c00 (irq = 19, base_baud = 3125000) is a 16550A
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.423465] console [ttyS0] enabled
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.430318] bootconsole [early0] disabled
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.439184] 1e000e00.uartlite3: ttyS1 at MMIO 0x1e000e00 (irq = 20, base_baud = 3125000) is a 16550A
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 2.450937] MediaTek Nand driver init, version v2.1 Fix AHB virt2phys error
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.458495] spi-mt7621 1e000b00.spi: sys_freq: 220000000
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.465022] m25p80 spi0.0: mx25l25635f (32768 Kbytes)
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.470114] 4 fixed-partitions partitions found on MTD device spi0.0
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.476484] Creating 4 MTD partitions on “spi0.0”:
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.481262] 0x000000000000-0x000000030000 : “u-boot”
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.487410] 0x000000030000-0x000000040000 : “u-boot-env”
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.493816] 0x000000040000-0x000000050000 : “factory”
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.499864] 0x000000050000-0x000002000000 : “firmware”
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.506417] 2 uimage-fw partitions found on MTD device firmware
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.512375] Creating 2 MTD partitions on “firmware”:
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.517329] 0x000000000000-0x0000001f2381 : “kernel”
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.523527] 0x0000001f2381-0x000001fb0000 : “rootfs”
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.529589] mtd: device 5 (rootfs) set to be root filesystem
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.535415] 1 squashfs-split partitions found on MTD device rootfs
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 2.541620] 0x000001020000-0x000001fb0000 : “rootfs_data”
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.549047] libphy: Fixed MDIO Bus: probed
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 2.623622] libphy: mdio: probed
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.026618] mtk_soc_eth 1e100000.ethernet: loaded mt7530 driver
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.033429] mtk_soc_eth 1e100000.ethernet eth0: mediatek frame engine at 0xbe100000, irq 23
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.045047] NET: Registered protocol family 10
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.051319] Segment Routing with IPv6
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.055162] NET: Registered protocol family 17
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.059672] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.072598] 8021q: 802.1Q VLAN Support v1.8
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.079668] hctosys: unable to open rtc device (rtc0)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.093985] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 4.107103] Freeing unused kernel memory: 1252K
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 4.111667] This architecture does not have kernel memory protection.
Thu Dec 2 14:11:46 2021 user.info kernel: [ 4.990755] init: Console is alive
Thu Dec 2 14:11:46 2021 user.info kernel: [ 4.994576] init: - watchdog -
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 6.335782] mtk_soc_eth 1e100000.ethernet eth0: port 4 link up
Thu Dec 2 14:11:46 2021 user.info kernel: [ 8.432234] kmodloader: loading kernel modules from /etc/modules-boot.d/
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.728029] usbcore: registered new interface driver usbfs
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.733669] usbcore: registered new interface driver hub
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.739074] usbcore: registered new device driver usb
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.748617] exFAT: Version 1.2.9
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.783470] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 8.797703] SCSI subsystem initialized
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.806168] ehci-platform: EHCI generic platform driver
Thu Dec 2 14:11:46 2021 kern.debug kernel: [ 8.822515] libata version 3.00 loaded.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.828821] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.836641] ohci-platform: OHCI generic platform driver
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.844263] uhci_hcd: USB Universal Host Controller Interface driver
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 8.858439] xhci-mtk 1e1c0000.xhci: 1e1c0000.xhci supply vbus not found, using dummy regulator
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 8.867236] xhci-mtk 1e1c0000.xhci: 1e1c0000.xhci supply vusb33 not found, using dummy regulator
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.876220] xhci-mtk 1e1c0000.xhci: xHCI Host Controller
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.881586] xhci-mtk 1e1c0000.xhci: new USB bus registered, assigned bus number 1
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.891763] xhci-mtk 1e1c0000.xhci: hcc params 0x01401198 hci version 0x96 quirks 0x0000000000210010
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.900946] xhci-mtk 1e1c0000.xhci: irq 22, io mem 0x1e1c0000
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.907852] hub 1-0:1.0: USB hub found
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.911748] hub 1-0:1.0: 2 ports detected
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.916499] xhci-mtk 1e1c0000.xhci: xHCI Host Controller
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.921862] xhci-mtk 1e1c0000.xhci: new USB bus registered, assigned bus number 2
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.929327] xhci-mtk 1e1c0000.xhci: Host supports USB 3.0 SuperSpeed
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.935969] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.945044] hub 2-0:1.0: USB hub found
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 8.948877] hub 2-0:1.0: 1 port detected
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 9.024249] sdhci: Secure Digital Host Controller Interface driver
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 9.030432] sdhci: Copyright(c) Pierre Ossman
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 9.036886] sdhci-pltfm: SDHCI platform and OF driver helper
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 9.045728] usbcore: registered new interface driver usb-storage
Thu Dec 2 14:11:46 2021 user.info kernel: [ 9.054888] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Thu Dec 2 14:11:46 2021 user.info kernel: [ 9.071967] init: - preinit -
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 10.559823] mtk_soc_eth 1e100000.ethernet: PPE started
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 13.874444] random: crng init done
Thu Dec 2 14:11:46 2021 kern.notice kernel: [ 13.957534] jffs2: notice: (526) jffs2_build_xattr_subsystem: complete building xattr subsystem, 8 of xdatum (3 unchecked, 5 orphan) and 112 of xref (4 dead, 50 orphan) found.
Thu Dec 2 14:11:46 2021 user.info kernel: [ 13.976690] mount_root: switching to jffs2 overlay
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 14.030290] overlayfs: upper fs does not support tmpfile.
Thu Dec 2 14:11:46 2021 user.warn kernel: [ 14.044511] urandom-seed: Seeding with /etc/urandom.seed
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 14.165761] mtk_soc_eth 1e100000.ethernet: 0x100 = 0x6060000c, 0x10c = 0x80818
Thu Dec 2 14:11:46 2021 user.info kernel: [ 14.181940] procd: - early -
Thu Dec 2 14:11:46 2021 user.info kernel: [ 14.184933] procd: - watchdog -
Thu Dec 2 14:11:46 2021 user.info kernel: [ 14.981815] procd: - watchdog -
Thu Dec 2 14:11:46 2021 user.info kernel: [ 14.985402] procd: - ubus -
Thu Dec 2 14:11:46 2021 user.info kernel: [ 15.153960] procd: - init -
Thu Dec 2 14:11:46 2021 user.info kernel: [ 16.711041] kmodloader: loading kernel modules from /etc/modules.d/*
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 16.838696] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 16.855324] tun: Universal TUN/TAP device driver, 1.6
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 16.873693] ip6_tables: (C) 2000-2006 Netfilter Core Team
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 16.896415] nf_conntrack version 0.5.0 (4096 buckets, 16384 max)
Thu Dec 2 14:11:46 2021 user.info kernel: [ 16.917434] urngd: v1.0.2 started.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 16.989878] Netfilter messages via NETLINK v0.30.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 16.998730] ip_set: protocol 6
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 17.048394] i2c /dev entries driver
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 17.061485] Mirror/redirect action on
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 17.084192] u32 classifier
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 17.086931] input device check on
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 17.090578] Actions configured
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 17.115408] GACT probability on
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 17.127518] Simple TC action Loaded
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 17.178035] fuse init (API version 7.26)
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.732292] register mt_drv
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.735204] bus=0x1, slot = 0x0, irq=0x0
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.739132] PCI: Enabling device 0000:00:00.0 (0004 → 0006)
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.781325]
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.781325] == pAd = c0c81000, size = 6947776, Status=0 ==
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.788328] pAd->PciHif.CSRBaseAddress =0xc0b80000, csr_addr=0xc0b80000!
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.795016] RTMPInitPCIeDevice():device_id=0x7615
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.799706] mt_pci_chip_cfg(): HWVer=0x8a10, FWVer=0x8a10, pAd->ChipID=0x7615
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.806818] mt_pci_chip_cfg(): HIF_SYS_REV=0x76150001
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.811856] AP Driver version-5.0.2.0
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.815504] RtmpChipOpsHook(223): Not support for HIF_MT yet! MACVersion=0x0
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.822527] mt7615_init()–>
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.825395] Use the default ePAeLNA bin image!
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.829813] Use the default /etc_ro/wlan/MT7615E_EEPROM1.bin bin image!
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.836429] <–mt7615_init()
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.845157] ← RTMPAllocTxRxRingMemory, Status=0
Thu Dec 2 14:11:46 2021 kern.warn kernel: [ 19.852768] RtmpOSFileOpen(): Error 2 opening /etc/wireless/l1profile.dat
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 19.877791] usbcore: registered new interface driver cdc_acm
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 19.883504] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 19.893978] usbcore: registered new interface driver cdc_wdm
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 19.903030] Loading modules backported from Linux version v4.19.161-0-gdaefdc9eb24b
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 19.910713] Backport generated by backports.git v4.19.161-1-0-g4bb568fe
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 19.936369] Ebtables v2.0 registered
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 19.943789] ip_tables: (C) 2000-2006 Netfilter Core Team
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 19.952756] usbcore: registered new interface driver ipheth
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.045497] ctnetlink v0.93: registering with nfnetlink.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.165634] nf_tables: (c) 2007-2009 Patrick McHardy
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.226640] usbcore: registered new interface driver usbserial
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.232675] usbcore: registered new interface driver usbserial_generic
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.239257] usbserial: USB Serial support registered for generic
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.250690] wireguard: WireGuard 1.0.20200611 loaded.
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.259179] wireguard: Copyright (C) 2015-2019 Jason
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.309589] xt_time: kernel timezone is -0000
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.316884] usbcore: registered new interface driver cdc_ether
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.326757] usbcore: registered new interface driver cdc_ncm
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.364373] usbcore: registered new interface driver cp210x
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.370124] usbserial: USB Serial support registered for cp210x
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.381228] usbcore: registered new interface driver huawei_cdc_ncm
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.440890] PPP generic driver version 2.4.2
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.446929] PPP MPPE Compression module registered
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.453454] NET: Registered protocol family 24
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.460855] usbcore: registered new interface driver qmi_wwan
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.469758] usbcore: registered new interface driver rndis_host
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.491728] usbcore: registered new interface driver sierra
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.497423] usbserial: USB Serial support registered for Sierra USB modem
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.506716] usbcore: registered new interface driver sierra_net
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.518614] usbcore: registered new interface driver option
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.524446] usbserial: USB Serial support registered for GSM modem (1-port)
Thu Dec 2 14:11:46 2021 kern.info kernel: [ 20.551774] usbcore: registered new interface driver rt2800usb
Thu Dec 2 14:11:46 2021 user.info kernel: [ 20.558168] kmodloader: done loading kernel modules from /etc/modules.d/*
Thu Dec 2 14:11:47 2021 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Thu Dec 2 14:11:47 2021 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: started, version 2.80 cachesize 150
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: DNS service limited to local subnets
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: using local addresses only for domain test
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: using local addresses only for domain onion
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: using local addresses only for domain localhost
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: using local addresses only for domain invalid
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: using local addresses only for domain bind
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: using local addresses only for domain lan
Thu Dec 2 14:11:48 2021 daemon.warn dnsmasq[1417]: no servers found in /tmp/resolv.conf.auto, will retry
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: read /etc/hosts - 4 addresses
Thu Dec 2 14:11:48 2021 daemon.info dnsmasq[1417]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Thu Dec 2 14:11:48 2021 authpriv.info dropbear[1450]: Not backgrounding
Thu Dec 2 14:11:52 2021 kern.info kernel: [ 27.660821] mtk_soc_eth 1e100000.ethernet eth0: port 4 link down
Thu Dec 2 14:11:52 2021 user.notice : Added device handler type: 8021ad
Thu Dec 2 14:11:52 2021 user.notice : Added device handler type: 8021q
Thu Dec 2 14:11:52 2021 user.notice : Added device handler type: macvlan
Thu Dec 2 14:11:52 2021 user.notice : Added device handler type: veth
Thu Dec 2 14:11:52 2021 user.notice : Added device handler type: bridge
I pasted as much as I could… could you tell anything from this?
I have no idea what it means
Dunno if this helps but I went into Luci and looked at Kernel logs
Unplugged USB and then plugged in
[12638.175109] usb 2-1: USB disconnect, device number 4
[12642.848055] AP SETKEYS DONE - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=5 from E0:D4:E8:37:9A:A6
[12642.848055]
[12660.213981] usb 2-1: new SuperSpeed USB device number 5 using xhci-mtk
[12660.273533] hub 2-1:1.0: USB hub found
[12660.278296] hub 2-1:1.0: 4 ports detected
[12660.413899] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[12660.607266] hub 1-1:1.0: USB hub found
[12660.611439] hub 1-1:1.0: 4 ports detected
[12660.954103] usb 2-1.1: new SuperSpeed USB device number 6 using xhci-mtk
what is the HD disk device type? can you make some picture, show the HD disk information?
  1. Samsung 830 SSD 256 gb in a UGreen type-C enclosure
  2. HGST 1TB in a typc-C enclosure
Both NTFS formatted
I did suspect a powering issues so I added a Orico 4-port USB3.0 hub which has external power. The HGST 1TB drive fails to boot up simply plugged into the router but using the hub with external power, it boots up fine.
It is best not to add a hub for now to keep things simple and just test with the Samsung SSD which is low-powered.
You can give this a try:
For NTFS, you may may also have to remove the kmod-fs-ntfs package:
OK I have tried to follow your suggestions
For the first sugggestion I installed luci-app-samba. I go to the Luci Gui and log in but under system menu I do not see Mount Points. Please see below screenshot -
If I look under network share I see the below which shows the GL-Samba folder which I have been talking about. When I //192.168.8.1/ all I see is this GL-Samba folder
I then tried method 2 and removed kmod-fs-ntfs and this made no difference. I restarted device and still nothing.
When I go back to the Luci GUI and look under Kernal Log I see the below when I unplug and plug in my USB HD. So it is definitely detected -
[ 1166.389268] usb 2-1: USB disconnect, device number 3
[ 1168.299044] usb 2-1: new SuperSpeed USB device number 4 using xhci-mtk
[ 1168.333976] scsi host0: uas
[ 1168.338954] xhci-mtk 1e1c0000.xhci: ERROR Transfer event for unknown stream ring slot 1 ep 6
[ 1168.347394] xhci-mtk 1e1c0000.xhci: @000000000f7a1a90 0d17d000 00000000 05000000 01078001
[ 1168.355537] xhci-mtk 1e1c0000.xhci: ERROR Transfer event for unknown stream ring slot 1 ep 2
[ 1168.363939] xhci-mtk 1e1c0000.xhci: @000000000f7a1aa0 0d17d100 00000000 05000000 01038001
[ 1173.983200] 49b, flush one!
Can you confirm that the following packages are installed and install them if they are available:
block-mount
kmod-usb-storage
kmod-usb-storage-uas
usbutils
If the System → Mount Points menu still does not show up, then you may have to it the hard way in SSH (Post 18 in the same thread) :
The GL-iNet UI sets up a default share for name GL-Samba and directory /mnt. The LuCi UI sees this also, but LuCI is more powerful and allows multiple shares and mount points with your own names and directories.
You can confirm that the USB drive is mounted before you can share it, either in LuCI → System → Mount Points (above post) or in SSH (should show lines for USB drive):
block detect
mount
df
Regarding, removing kmod-fs-ntfs, only do that if both the kmod-fs-ntfs and ntfs-3g packages are installed because they have a conflict.
maybe the system not recognized the USB device, we get the engineer to solve it now, take some time, general one week;
OK block-mount was not installed, the rest were. So i installed block-mount and restarted router.
Now in Luci gui I see Mount Points under system. I now go back to previous post to follow the guide.
/dev/sda1 does not show up so I continue to the second half of the guide which says -
“If /dev/sda1 does not show up in the Device box, the you have to go into SSH and type the command “block detect”, which will detect the USB drive and display its UUID”
I entered command block detect with USB plugged in and without. I get the following -
Capture
The same result and no UUID
