Did you try to disable the "auto-connect"?
@yuxin.zou any updates about 4.6 for E750v2? Any approximate date?
done that now and i'll feedback if there is an issue
edit: got fed up with no autoconnect so i gave up
I was also thinking the same for MT3000. Can someone chime into what happened to the beta? Been working well for me but now it is gone.
Hi, team!
Can you please add toggle to disable SSH? Not much users really need it. Moreover password protected SSH can be used to breach devices. Or even brick it if person doesn’t know what they are doing.
I think toggle should be placed to “Advanced settings”. And have warning “Enable only if you know what you are doing!”
We'll be talking about that, and that includes LuCI as well.
Sorry, there is no clear timeline yet…
Do you want to disable local ssh ?
Remote ssh is disabled by default.
- Does wireguard_watchdog work with you on 4.6 when the router is connected to a WireGuard server on a dynamic dns and the ip changes?
- Is there any way to disable VPN first policy? I have set up a selection of domains only to be routed via vpn but if the vpn service goes down I lose name resolution on all my clients.
Good day! Will the Op24 4.6.0 firmware for MT6000 will get new updates / patches from the fixes included in the Owrt's drivers? Its been almost 2 months since it received new patches. Thanks!
Same question for MT3000 Beryl AX. Can you please update that too. Thanks
@yuxin.zou any news about E750? When (approximately) it be updated?
We are fixing a leak bug.
It was a bit long in the tooth ...... sorry.
I'm not sure if the E750 is still upgraded to 4.6 yet.
Since version 4.7 will add some new features to Cellular, it may be upgraded to 4.7 along with the X3000/XE3000.
Op24 firmware for Beryl AX which is in beta has wireguard client DNS issue for me. It seems DNS does not work times out, my config has the IP address of the DNS servers. Any solution to this? Same configuration works fine on 4.6.3
I'm trying to look for the 4.7 beta for my GL-MT3000. It is no longer available on the download page.
When will this version be available for the Marble?
On the List of current feature requests 2023 I see this one the roadmap:
Since we 're on 4.6.2, is there any ETA for this implementation?
Are network flows in the future release? I'd like to see where my devices are talking too. Right now I use a Firewalla Red to see where the devices are talking too but the Firewalla Red is EOL.. looking for something similar in Firewalla.
The Red has about 512mb of RAM, so it doesn't take alot of resources to get network flows in a table. ![]()
Looking for something similar as well. Have you checked out NetData?
