When this issue occurs, please help to check the following information:
ifconfig rmnet_mhi0
gl_modem -B 0001:01:00.0 AT AT+CGPADDR
ifconfig rmnet_mhi0
root@GL-X3000:~# ifconfig rmnet_mhi0
rmnet_mhi0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:100.66.136.217 Mask:255.255.255.252
inet6 addr: fe80::ab1f:b2cd:246e:101b/64 Scope:Link
UP RUNNING NOARP MTU:1500 Metric:1
RX packets:193 errors:0 dropped:0 overruns:0 frame:0
TX packets:16633 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:44708 (43.6 KiB) TX bytes:1025525 (1001.4 KiB)
root@GL-X3000:~# gl_modem -B 0001:01:00.0 AT AT+CGPADDR
+CGPADDR: 1,"100.90.94.123","36.2.25.128.4.44.0.204.0.0.0.0.0.0.0.1"
+CGPADDR: 2,"36.2.25.128.131.91.78.3.0.0.0.0.0.0.0.1"
+CGPADDR: 3,"0.0.0.0","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0"
OK
root@GL-X3000:~#
i turned the router off this morning, when you asked me to check, i powered up the router and it still stay offline
i did another ‘manual setup’ then the internet comes back
Hi bOcy:
Thank you very much!
You cloud upgdate this firmware:
https://dl.gl-inet.com/?model=x3000&type=beta
funny no disconnects since my last message, anyway i will try the latest beta
This beta works fine so far (10403)
Thank you very much.
I was having similar disconnect issue as bOcy; however, loading the beta firmware has resolved my issue. Before the firmware, it would not stay on Cellular (T-Mobile) for longer than 2-3 hours before I would have to go through the Cellular setup again. After the beta firmware, I tested it for 5 days rebooting it once in between because I had to move the GL-X3000. It has been very stable during that time. I had only had the router for a few days, and was thinking of sending it back before the beta firmware. Thank you for the fix!!!
@robsonline what firmware version were you on when having the issues before you installed the beta firmware?
It was the last stable release: 4.0-release50402
I have the same issue as described by bOcy. The connection (5G NSA) works fine for few hours and then no internet any more. Then I have to press “disconnect” and “auto setup” in the cellular configuration page. I am on firmware 0406release1.
I wanted to try the beta-firmware (10403) that seemed to solve the issue for others, but this is not available any more from the download page.
This bug makes the router virtual useless for me because if the internet is down (the 5g/4g connection) I can not remotely log-in to do “disconnect” and "auto setup’ trick to get it back online. This can only be done if you are locally around and can log-in from the LAN.
I could try to write a cron-job to detect this situation, but I would need some help for this:
1/ how to detect in a script that internet is down?
2/ how to simulate cellular “disconnect” and “auto-config” in a script?
Thanks!
I have some more info. When the connection goes down, the two network adresses don’t seem to match:
ifconfig → 100.116.242.183
AT+CGPADDR → 100.72.42.193
When the internet connection is restorted these network adresses do match.
I seem to be able to restore the internet by doing:
ifdown modem_0001
ifup modem_0001
See the commands here below which show the mismatch in ip-adress when the internet via 5G is not working:
BusyBox v1.33.2 (2024-01-23 07:12:18 UTC) built-in shell (ash)
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
OpenWrt 21.02-SNAPSHOT, r15812+879-46b6ee7ffc
inet addr:100.116.242.183 Mask:255.255.255.240
inet6 addr: fe80::REMOVED_FOR_PRIVACY Scope:Link
RX packets:402666 errors:0 dropped:0 overruns:0 frame:0
TX packets:455135 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4396034868 (4.0 GiB) TX bytes:301614968 (287.6 MiB)
AT+CGPADDR
+CGPADDR: 1,"100.72.42.193","42.2.24.8.0.1.28.238.0.0.0.0.0.0.0.1"
+CGPADDR: 2,"0.0.0.0","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0"
OK
root@GL-X3000:~#
Hi. I really hope someone from Gl.inet support staff is looking into this. It would be nice to have this solved in some future fw update ![]()
Have you upgraded the cellular modem firmware by chance?
I used these instructions, but manually downloaded the lastest firmware version from:
I had to adjust the commands for the different filename, but otherwise worked just fine. Rebooted the router at the end. Not sure if it will address your particular issue, though.
@packetmonkey Thanks for the suggestion. But the router is installed in a remote place, so for the moment I refrain from going down the route of upgrading the FW of the modem itself. Once I am close to my router I will certainly try this :).
This makes me wonder, can a router-fw upgrade also come with an automatic modem-fw upgrade? Or do I always have to upgrade the fw of the modem manually?
It has to be done manually - GL staff confirmed in another thread that the modem fw won’t get updated with the router’s fw updates.
Hi SpitzAX3000,
I did search for your AT commands manual but i didn’t find it, i search on your posts and also no success. can you please link it here, will be much apreciated.
Linked in the middle of this post.
Thank you, i’ve tried but without success, the problem i have is that my X3000 is working fine, but in a few hours of work, downgrade the 5g or 4g+ to 3d using WCDMA.
there is any at command that can solve this to not downgrade to 3g?
Did you upgrade the cellular modem firmware?
